- To:
- Subject: [cgal-discuss] ISR and missing edges
- Date: Thu, 08 Jul 2010 13:19:39 -0400
Hi y'all,
I took my code to create an arrangement_2 from segments (source data is OSM road map data) and ran it through the snap_rounding package.
It appears that some small segments are being omitted.
If I have a poly-line in my source data (represented as a series of line segments that have equal value vertices), does snap rounding guarantee that the rounding will happen the same way for each segment? (If not, then my use of it is invalid...)
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] ISR and missing edges, Ben Supnik, 07/08/2010
- Re: [cgal-discuss] ISR and missing edges, Ophir Setter, 07/09/2010
- Re: [cgal-discuss] ISR and missing edges, Ben Supnik, 07/09/2010
- Re: [cgal-discuss] ISR and missing edges, Ophir Setter, 07/12/2010
