- To:
- Subject: Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3
- Date: Thu, 8 Jul 2010 23:47:05 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Hnsu1oE6uHsJOxaBznoQhShnOZeY7arxwhqsZzYDmu1mEPfCszL4mLY6cbhCh3fWEh D4ueFSPtsFUm553T7I/s/XmYAT3AxMO9nl7+ouhGMNw77/20na8c7trOLjOSptGynfom 6FX9xB/ap8E06Gi42IKjIXL1zVBC2M412L4AI=
On 8 July 2010 11:57, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
this is true if I'm the only user of it , but the problem becomes clear when we hook Polyhedron_traits_with_normals_3 into other parts of a cgal puzzle , parts assuming this as a standard behavior
specifically i faced the problem when trying to use Polyhedron_traits_with_normals_3 with the parametrization package
take for example the first example of the parametrization package, modified to use Polyhedron_traits_with_normals_3 , it will refuse compiling asking for FT , which isn't here as Polyhedron traits doesn't have (because it doesn't inherit from it's kernel )
#include <CGAL/Polyhedron_traits_with_normals_3.h>
#include <CGAL/Cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Parameterization_polyhedron_adaptor_3.h>
#include <CGAL/parameterize.h>
#include <iostream>
#include <fstream>
// Private types
typedef CGAL::Cartesian<double> Kernel;
typedef CGAL::Polyhedron_traits_with_normals_3<Kernel> Traits;
typedef CGAL::Polyhedron_3<Traits> Polyhedron;
// main()
int main(int argc, char * argv[])
std::cerr << "PARAMETERIZATION" << std::endl;
std::cerr << " Floater parameterization" << std::endl;
std::cerr << " Circle border" << std::endl;
std::cerr << " OpenNL solver" << std::endl;
// decode parameters
if (argc-1 != 1)
std::cerr << "Usage: " << argv[0] << " input_file.off" << std::endl;
return(EXIT_FAILURE);
// File name is:
const char* input_filename = argv[1];
// Read the mesh
// Read the mesh
std::ifstream stream(input_filename);
Polyhedron mesh;
stream >> mesh;
if(!stream || !mesh.is_valid() || mesh.empty())
std::cerr << "Error: cannot read OFF file " << input_filename << std::endl;
return EXIT_FAILURE;
// Create Polyhedron adaptor
// Note: no cutting => we support only
// meshes that are topological disks
typedef CGAL::Parameterization_polyhedron_adaptor_3<Polyhedron>
Parameterization_polyhedron_adaptor;
Parameterization_polyhedron_adaptor mesh_adaptor(mesh);
// Floater Mean Value Coordinates parameterization
// (defaults are circular border and OpenNL solver)
typedef CGAL::Parameterizer_traits_3<Parameterization_polyhedron_adaptor>
Parameterizer; // Type that defines the error codes
Parameterizer::Error_code err = CGAL::parameterize(mesh_adaptor);
switch(err) {
case Parameterizer::OK: // Success
break;
case Parameterizer::ERROR_EMPTY_MESH: // Input mesh not supported
case Parameterizer::ERROR_NON_TRIANGULAR_MESH:
case Parameterizer::ERROR_NO_TOPOLOGICAL_DISC:
case Parameterizer::ERROR_BORDER_TOO_SHORT:
std::cerr << "Input mesh not supported: " << Parameterizer::get_error_message(err) << std::endl;
break;
default: // Error
std::cerr << "Error: " << Parameterizer::get_error_message(err) << std::endl;
break;
// Output
// Raw output: dump (u,v) pairs
Polyhedron::Vertex_const_iterator pVertex;
for (pVertex = mesh.vertices_begin();
pVertex != mesh.vertices_end();
pVertex++)
// (u,v) pair is stored in any halfedge
double u = mesh_adaptor.info(pVertex->halfedge())->uv().x();
double v = mesh_adaptor.info(pVertex->halfedge())->uv().y();
std::cout << "(u,v) = (" << u << "," << v << ")" << std::endl;
return EXIT_SUCCESS;
Mohttps://mail.google.com/mail/?hl=ar&shva=1#inbox/129ad8d0ec704d3fhamed Yousef wrote:In which context? the kernel is still available using Polyhedron::Traits::Kernel.
suppose we want to define a Polyhedron that has the plane support , depending on Polyhedron_traits_with_
normals_3 as traits , we would do
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
and then use Polyhedron normally , the problem is our Polyhedron now lacks many things already been in Kernel (in fact everything but Point_3 and Plane_3 ) this hindered me and i found the solution used elsewhere in cgal is to inherit the specilizing kernel , thus you are adding to it
Please provide a minimal example that highlighting your problem. If We
cannot reproduce a bug it is hard to correct.
#include <iostream>
#include <fstream>
// Private types
// main()
if (argc-1 != 1)
// File name is:
// Read the mesh
// Read the mesh
Polyhedron mesh;
stream >> mesh;
switch(err) {
break;
break;
default: // Error
break;
// Output
pVertex++)
On 8 July 2010 10:08, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:<sloriot.ml <http://sloriot.ml> <http://sloriot.ml>@gmail.com
Sorry but I still don't get your point.
The activation of the plane support is done within a class model of
PolyhedronItems_3.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Concept_PolyhedronItems_3.html#Cross_link_anchor_1096
Can you please state clearly what you would like to do.
S.
Mohamed Yousef wrote:
simply if you want to use it as usual to extend a kernel by
adding plane support , you will lack all additional things the
kernel provides
the way for this to go (done in other traits , every where in
cgal ) is to inherit from specializing kernel , thus you have
your kernel with additional support of plane
Regards,
Mohamed Yousef
On 8 July 2010 08:52, Sebastien Loriot (GeometryFactory)
Hello,
i think the class "Polyhedron_traits_with_normals_3" should
inherit from Kernel_
Thanks,
Reading the documentation I see no reason why it should.
The concept PolyhedronTraits_3 is quite simple and
Polyhedron_traits_with_normals_3 seems to be a model of it.
What leads you to think there is a bug?
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/07/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/13/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/13/2010
