- To:
- Subject: Re: [cgal-discuss] Namespace CGAL::parameters doesn't exist
- Date: Mon, 12 Jul 2010 21:37:24 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=mTP1zLA/OeB6+YtvGkP9W4ffNZWtjUOwcaVCL/QlTxLpLWsW10T6Snmip0PYoa/2as Qm6xPC48stQ8xSsrv3ppJHiscfgzi4lg0Ns6AhooVd0cnfs973aH+JyDlrw3xnS11yHV r33RoSTCAN5flNGykEMK5UDFsKSFY4lOjZeZw=
Hi,
Thanks for your response.
My CGAL version is 3.5.1-1, I just installed it earlier today. I changed the piece of code that didn't compile by the one given in the online documentation proper to my version. It compiled well... but did not execute. I got this error :
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: m_primitives.size() > 1
File: /usr/include/CGAL/AABB_tree.h
Line: 471
Abandon
Is there any way to solve it?what(): CGAL ERROR: assertion violation!
Line: 471
Abandon
By the way, how can I get the latest version of CGAL installed by the command line sudo apt-get...? That would be an alternate solution to my problem since there is no namespace error with Joachim's version (3.6.1-1).
Thanks for any feedback,
Valentin
On Mon, Jul 12, 2010 at 7:35 PM, Joachim Reichel <> wrote:
Hi,
> given here<http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Mesh_3/Chapter_main.html#Subsection_49.3.2>,
> I'm experiencing a weird compilation error while using the piece of code
> which is supposed to create a tetrahedral mesh from a triangular one.unfortunately you do not tell us which version of libcgal-dev you
> When compiling, I get the error that *CGAL::parameters* (line 30) is not a
> namespace, and indeed, when I checked out the includes, no one contained a
> such namespace. I'm a using a too old / too recent version of CGAL? I got it
> by the command line *sudo apt-get install libcgal-dev*. How can I get this
> piece of code working?
installed. It works for me with libcgal-dev 3.6.1-1.
By the way you can also install libcgal-demo which gives you all
examples and demos in /usr/share/doc/libcgal-demo. Maybe you have an
older version of CGAL installed, and the example at the above URL is too
new for you. Older versions contain that example as well, maybe with
minor differences.
Or browse the online documentation and replace "beta" in the URL with
your CGAL version.
Joachim
- [cgal-discuss] Namespace CGAL::parameters doesn't exist, Valentin Leonardi, 07/12/2010
- Re: [cgal-discuss] Namespace CGAL::parameters doesn't exist, Joachim Reichel, 07/12/2010
- Re: [cgal-discuss] Namespace CGAL::parameters doesn't exist, Valentin Leonardi, 07/12/2010
