- To:
- Subject: Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3
- Date: Tue, 13 Jul 2010 16:10:36 +0200
Mohamed Yousef wrote:
is this still not considered bug ? what is the current status nowWhat you described is not a bug in the Polyhedron traits but a bug in Parameterization_polyhedron_adaptor_3.
I joint a temporary fix.
S.
Thanks,
On 8 July 2010 23:47, Mohamed Yousef < <mailto:>> wrote:
On 8 July 2010 11:57, Sebastien Loriot (GeometryFactory) <sloriot.ml
<http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Mohttps://mail.google.com/mail/?hl=ar&shva=1#inbox/129ad8d0ec704d3fhamed
<http://mail.google.com/mail/?hl=ar&shva=1#inbox/129ad8d0ec704d3fhamed>
Yousef wrote:
suppose we want to define a Polyhedron that has the plane
support , depending on Polyhedron_traits_with_
normals_3 as traits , we would do
typedef CGAL::Exact_predicates_inexact_constructions_kernel
Kernel;
typedef CGAL::Polyhedron_traits_with_normals_3<Kernel> Traits;
typedef CGAL::Polyhedron_3<Traits> Polyhedron;
and then use Polyhedron normally , the problem is our
Polyhedron now lacks many things already been in Kernel (in
fact everything but Point_3 and Plane_3 ) this hindered me
and i found the solution used elsewhere in cgal is to
inherit the specilizing kernel , thus you are adding to it
In which context? the kernel is still available using
Polyhedron::Traits::Kernel.
this is true if I'm the only user of it , but the problem becomes
clear when we hook Polyhedron_traits_with_normals_3 into other parts
of a cgal puzzle , parts assuming this as a standard behavior
specifically i faced the problem when trying to use
Polyhedron_traits_with_normals_3 with the parametrization package
Please provide a minimal example that highlighting your problem.
If We
cannot reproduce a bug it is hard to correct.
take for example the first example of the parametrization package,
modified to use Polyhedron_traits_with_normals_3 , it will refuse
compiling asking for FT , which isn't here as Polyhedron traits
doesn't have (because it doesn't inherit from it's kernel )
#include <CGAL/Polyhedron_traits_with_normals_3.h>
#include <CGAL/Cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Parameterization_polyhedron_adaptor_3.h>
#include <CGAL/parameterize.h>
#include <iostream>
#include <fstream>
// Private types
typedef CGAL::Cartesian<double> Kernel;
// main()
int main(int argc, char * argv[])
std::cerr << "PARAMETERIZATION" << std::endl;
std::cerr << " Floater parameterization" << std::endl;
std::cerr << " Circle border" << std::endl;
std::cerr << " OpenNL solver" << std::endl;
// decode parameters
if (argc-1 != 1)
std::cerr << "Usage: " << argv[0] << " input_file.off" <<
std::endl;
return(EXIT_FAILURE);
// File name is:
const char* input_filename = argv[1];
// Read the mesh
// Read the mesh
std::ifstream stream(input_filename);
Polyhedron mesh;
stream >> mesh;
if(!stream || !mesh.is_valid() || mesh.empty())
std::cerr << "Error: cannot read OFF file " <<
input_filename << std::endl;
return EXIT_FAILURE;
// Create Polyhedron adaptor
// Note: no cutting => we support only
// meshes that are topological disks
typedef CGAL::Parameterization_polyhedron_adaptor_3<Polyhedron>
Parameterization_polyhedron_adaptor;
Parameterization_polyhedron_adaptor mesh_adaptor(mesh);
// Floater Mean Value Coordinates parameterization
// (defaults are circular border and OpenNL solver)
typedef
CGAL::Parameterizer_traits_3<Parameterization_polyhedron_adaptor>
Parameterizer; // Type
that defines the error codes
Parameterizer::Error_code err = CGAL::parameterize(mesh_adaptor);
switch(err) {
case Parameterizer::OK: // Success
break;
case Parameterizer::ERROR_EMPTY_MESH: // Input mesh not supported
case Parameterizer::ERROR_NON_TRIANGULAR_MESH: case Parameterizer::ERROR_NO_TOPOLOGICAL_DISC: case Parameterizer::ERROR_BORDER_TOO_SHORT: std::cerr << "Input mesh not supported: " <<
Parameterizer::get_error_message(err) << std::endl;
break;
default: // Error
std::cerr << "Error: " <<
break;
// Output
// Raw output: dump (u,v) pairs
Polyhedron::Vertex_const_iterator pVertex;
for (pVertex = mesh.vertices_begin();
pVertex != mesh.vertices_end();
pVertex++)
// (u,v) pair is stored in any halfedge
double u = mesh_adaptor.info
<http://mesh_adaptor.info>(pVertex->halfedge())->uv().x();
double v = mesh_adaptor.info
<http://mesh_adaptor.info>(pVertex->halfedge())->uv().y();
std::cout << "(u,v) = (" << u << "," << v << ")" << std::endl;
return EXIT_SUCCESS;
On 8 July 2010 10:08, Sebastien Loriot (GeometryFactory)
<sloriot.ml <http://sloriot.ml>
Sorry but I still don't get your point.
The activation of the plane support is done within a
class model of
PolyhedronItems_3.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Concept_PolyhedronItems_3.html#Cross_link_anchor_1096
Can you please state clearly what you would like to do.
S.
simply if you want to use it as usual to extend a
kernel by
adding plane support , you will lack all additional
things the
kernel provides
the way for this to go (done in other traits , every
where in
cgal ) is to inherit from specializing kernel , thus
you have
your kernel with additional support of plane
Regards,
Mohamed Yousef
On 8 July 2010 08:52, Sebastien Loriot (GeometryFactory)
<sloriot.ml <http://sloriot.ml> <http://sloriot.ml>
Hello,
i think the class
"Polyhedron_traits_with_normals_3" should
inherit from Kernel_
Thanks,
Reading the documentation I see no reason why it
should.
The concept PolyhedronTraits_3 is quite simple and
Polyhedron_traits_with_normals_3 seems to be a
model of it.
What leads you to think there is a bug?
S.
-- You are currently subscribed to cgal-discuss.
// Copyright (c) 2005 INRIA (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh:///svn/cgal/branches/CGAL-3.6-branch/Surface_mesh_parameterization/include/CGAL/Parameterization_polyhedron_adaptor_3.h $ // $Id: Parameterization_polyhedron_adaptor_3.h 48430 2009-03-18 08:59:29Z lsaboret $ // // // Author(s) : Laurent Saboret, Pierre Alliez, Bruno Levy #ifndef CGAL_PARAMETERIZATION_POLYHEDRON_ADAPTOR3_H #define CGAL_PARAMETERIZATION_POLYHEDRON_ADAPTOR3_H #include <CGAL/iterator.h> #include <CGAL/circulator.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/surface_mesh_parameterization_assertions.h> #include <CGAL/Convertible_iterator_project.h> #include <CGAL/Convertible_circulator_project.h> #include <list> CGAL_BEGIN_NAMESPACE /// Parameterization_polyhedron_adaptor_3 is an adaptor class to access to a Polyhedron /// 3D mesh using the ParameterizationPatchableMesh_3 interface. /// Among other things, this concept defines the accessor to the (u,v) values /// computed by parameterizations methods. /// /// Note that these interfaces are decorators that add "on the fly" /// the necessary fields to unmodified CGAL data structures (using STL maps). /// For performance reasons, it is recommended to use CGAL data structures /// enriched with the proper fields. /// /// A ParameterizationMesh_3 surface consists of vertices, /// facets and an incidence relation on them. /// No notion of edge is requested. /// /// ParameterizationMesh_3 meshes can have any genus, arity or number of components. /// /// It can have have any number of borders. Its "main border" /// will be the mesh's longest border (if there is at least one border). /// /// It has also the ability to support patches and virtual seams. /// "Patches" are a subset of a 3D mesh. "Virtual seams" are the ability /// to behave exactly as if the surface was cut following a certain path. /// /// @heading Is Model for the Concepts: /// Model of ParameterizationPatchableMesh_3 concept, whose purpose is to allow /// the Surface_mesh_parameterization package to access meshes in a uniform manner. /// /// @heading Design Pattern: /// Parameterization_polyhedron_adaptor_3 is an Adaptor [GHJV95]: it changes the /// Polyhedron interface to match the ParameterizationPatchableMesh_3 concept. template<class Polyhedron_3_> class Parameterization_polyhedron_adaptor_3 { // Forward references public: class Halfedge_info; class Vertex_info; private: struct Less; struct Project_halfedge_vertex; struct Project_vertex_handle_vertex; struct Project_opposite_halfedge_vertex; // Private types private: /// Halfedge typedef typename Polyhedron_3_::Halfedge Halfedge; typedef typename Polyhedron_3_::Halfedge_handle Halfedge_handle; typedef typename Polyhedron_3_::Halfedge_const_handle Halfedge_const_handle; typedef typename Polyhedron_3_::Halfedge_iterator Halfedge_iterator; typedef typename Polyhedron_3_::Halfedge_const_iterator Halfedge_const_iterator; typedef typename Polyhedron_3_::Halfedge_around_vertex_circulator Halfedge_around_vertex_circulator; typedef typename Polyhedron_3_::Halfedge_around_vertex_const_circulator Halfedge_around_vertex_const_circulator; typedef typename Polyhedron_3_::Halfedge_around_facet_circulator Halfedge_around_facet_circulator; typedef typename Polyhedron_3_::Halfedge_around_facet_const_circulator Halfedge_around_facet_const_circulator; /// Additional info attached to halfedges typedef typename std::map<Halfedge_const_handle, Halfedge_info, Less> Halfedge_info_map; /// Additional info attached to vertices typedef typename std::map<typename Polyhedron_3_::Vertex_const_handle, Vertex_info, Less> Vertex_info_map; // Public types public: //******************************************************************* /// @name INTERFACE SPECIFIC TO Parameterization_polyhedron_adaptor_3 //******************************************************************* //@{ /// Export template parameter. typedef Polyhedron_3_ Polyhedron; /// Additional info attached to halfedges. class Halfedge_info { public: typedef typename Polyhedron_3_::Traits::Kernel::Point_2 Point_2; private: int m_tag; ///< general purpose tag bool m_is_parameterized; ///< is parameterized? int m_seaming; ///< seaming status Point_2 m_uv; ///< texture coordinates int m_index; ///< unique index public: /// Default constructor. Halfedge_info() { m_tag = -1; // uninitialized m_uv = Point_2(0, 0); m_index = -1; // uninitialized m_seaming = -1; // uninitialized m_is_parameterized = false; } // Default destructor, copy constructor and operator =() are fine /// Access to general purpose tag. int tag() const { return m_tag; } void tag(int tag) { m_tag = tag; } /// Access to 'seaming status' field. int seaming() const { return m_seaming; } void seaming(int seaming) { m_seaming = seaming; } /// Access to texture coordinates. Point_2 uv() const { return m_uv; } void uv(Point_2 uv) { m_uv = uv; } /// Access to "parameterized?" field. bool is_parameterized() const { return m_is_parameterized; } void is_parameterized(bool is) { m_is_parameterized = is; } /// Access to 'index' field. int index() const { return m_index; } void index(int i) { m_index = i; } }; /// Additional info attached to vertices. class Vertex_info { private: int m_tag; ///< general purpose tag int m_seaming; ///< seaming status int m_index; ///< unique index public: /// Default constructor. Vertex_info() { m_index = -1; // uninitialized m_tag = -1; // uninitialized m_seaming = -1; // uninitialized } // Default destructor, copy constructor and operator =() are fine. /// Access to 'index' field. int index() const { return m_index; } void index(int i) { m_index = i; } /// Access to 'tag' field. int tag() const { return m_tag; } void tag(int tag) { m_tag = tag; } /// Access to 'seaming status' field. int seaming() const { return m_seaming; } void seaming(int seaming) { m_seaming = seaming; } }; //@} // end of INTERFACE SPECIFIC TO Parameterization_polyhedron_adaptor_3 //******************************************************************* /// @name ParameterizationMesh_3 INTERFACE //******************************************************************* //@{ /// Number type to represent coordinates. typedef typename Polyhedron::Traits::Kernel::FT NT; /// 2D point that represents (u,v) coordinates computed /// by parameterization methods. Must provide X() and Y() methods. typedef typename Polyhedron::Traits::Kernel::Point_2 Point_2; /// 3D point that represents vertices coordinates. Must provide X() and Y() methods. typedef typename Polyhedron::Traits::Kernel::Point_3 Point_3; /// 2D vector. Must provide X() and Y() methods. typedef typename Polyhedron::Traits::Kernel::Vector_2 Vector_2; /// 3D vector. Must provide X() and Y() methods. typedef typename Polyhedron::Traits::Kernel::Vector_3 Vector_3; /// Opaque type representing a facet of the 3D mesh. No methods are expected. typedef typename Polyhedron::Facet Facet; /// Handle to a facet. Model of the Handle concept. typedef typename Polyhedron::Facet_handle Facet_handle; typedef typename Polyhedron::Facet_const_handle Facet_const_handle; /// Iterator over all mesh facets. Model of the ForwardIterator concept. typedef typename Polyhedron::Facet_iterator Facet_iterator; typedef typename Polyhedron::Facet_const_iterator Facet_const_iterator; /// Opaque type representing a vertex of the 3D mesh. No methods are expected. typedef typename Polyhedron::Vertex Vertex; /// Handle to a vertex. Model of the Handle concept. typedef typename Polyhedron::Vertex_handle Vertex_handle; typedef typename Polyhedron::Vertex_const_handle Vertex_const_handle; /// Iterator over all vertices of a mesh. Model of the ForwardIterator concept. typedef typename Polyhedron::Vertex_iterator Vertex_iterator; typedef typename Polyhedron::Vertex_const_iterator Vertex_const_iterator; /// Iterator over vertices of the mesh "main border". /// Model of the ForwardIterator concept. typedef CGAL::Convertible_iterator_project<typename std::list<Vertex_handle>::iterator, Project_vertex_handle_vertex, Vertex_const_handle, Vertex_handle> Border_vertex_iterator; typedef CGAL::Convertible_iterator_project<typename std::list<Vertex_handle>::const_iterator, Project_vertex_handle_vertex, Vertex_const_handle> Border_vertex_const_iterator; /// Counter-clockwise circulator over a facet's vertices. /// Model of the BidirectionalCirculator concept. typedef CGAL::Convertible_circulator_project<Halfedge_around_facet_circulator, Project_halfedge_vertex, Vertex&, Vertex*, Vertex_const_handle, Vertex_handle> Vertex_around_facet_circulator; typedef CGAL::Convertible_circulator_project<Halfedge_around_facet_const_circulator, Project_halfedge_vertex, const Vertex&, const Vertex*, Vertex_const_handle> Vertex_around_facet_const_circulator; /// Clockwise circulator over the vertices incident to a vertex. /// Model of the BidirectionalCirculator concept. typedef CGAL::Convertible_circulator_project<Halfedge_around_vertex_circulator, Project_opposite_halfedge_vertex, Vertex&, Vertex*, Vertex_const_handle, Vertex_handle> Vertex_around_vertex_circulator; typedef CGAL::Convertible_circulator_project<Halfedge_around_vertex_const_circulator, Project_opposite_halfedge_vertex, const Vertex&, const Vertex*, Vertex_const_handle> Vertex_around_vertex_const_circulator; //@} // end of ParameterizationMesh_3 INTERFACE // Public operations public: //******************************************************************* /// @name INTERFACE SPECIFIC TO Parameterization_polyhedron_adaptor_3 //******************************************************************* //@{ /// Create an adaptator for an existing Polyhedron_3 mesh. /// The input mesh can be of any genus. /// It can have have any number of borders. Its "main border" /// will be the mesh's longest border (if there is at least one border). Parameterization_polyhedron_adaptor_3(Polyhedron& mesh) // Store reference to adapted mesh : m_polyhedron(mesh) { typedef typename Halfedge_info_map::value_type Halfedge_info_pair; typedef typename Vertex_info_map::value_type Vertex_info_pair; // Allocate extra info for each halfedge Halfedge_iterator he; for (he = m_polyhedron.halfedges_begin(); he != m_polyhedron.halfedges_end(); he++) m_halfedge_info.insert( Halfedge_info_pair(he, Halfedge_info()) ); // Allocate extra info for each vertex Vertex_iterator vtx; for (vtx = m_polyhedron.vertices_begin(); vtx != m_polyhedron.vertices_end(); vtx++) m_vertex_info.insert( Vertex_info_pair(vtx, Vertex_info()) ); // Extract mesh's longest border m_main_border = extract_longest_border(mesh); #ifndef CGAL_NDEBUG // Index vertices right away to ease debugging index_mesh_vertices(); #endif } // Default destructor, copy constructor and operator =() are fine /// Get the adapted mesh. Polyhedron& get_adapted_mesh() { return m_polyhedron; } const Polyhedron& get_adapted_mesh() const { return m_polyhedron; } /// Get halfedge from source and target vertices. /// Will assert if such a halfedge doesn't exist. typename Polyhedron::Halfedge_const_handle get_halfedge( Vertex_const_handle source, Vertex_const_handle target) const { CGAL_surface_mesh_parameterization_precondition(source != NULL); CGAL_surface_mesh_parameterization_precondition(target != NULL); Halfedge_around_vertex_const_circulator cir = target->vertex_begin(), cir_end = cir; CGAL_For_all(cir, cir_end) if (cir->opposite()->vertex() == source) return cir; // we should not get here CGAL_error(); return NULL; } typename Polyhedron::Halfedge_handle get_halfedge( Vertex_handle source, Vertex_handle target) { Halfedge_const_handle halfedge = get_halfedge((Vertex_const_handle)source, (Vertex_const_handle)target); return const_cast<Halfedge*>(&*halfedge); } /// Access to additional info attached to halfedges. const Halfedge_info* info(Halfedge_const_handle halfedge) const { typename Halfedge_info_map::const_iterator it = m_halfedge_info.find(halfedge); CGAL_surface_mesh_parameterization_assertion(it != m_halfedge_info.end()); return &it->second; } Halfedge_info* info(Halfedge_const_handle halfedge) { typename Halfedge_info_map::iterator it = m_halfedge_info.find(halfedge); CGAL_surface_mesh_parameterization_assertion(it != m_halfedge_info.end()); return &it->second; } /// Access to additional info attached to vertices. const Vertex_info* info(Vertex_const_handle vertex) const { typename Vertex_info_map::const_iterator it = m_vertex_info.find(vertex); CGAL_surface_mesh_parameterization_assertion(it != m_vertex_info.end()); return &it->second; } Vertex_info* info(Vertex_const_handle vertex) { typename Vertex_info_map::iterator it = m_vertex_info.find(vertex); CGAL_surface_mesh_parameterization_assertion(it != m_vertex_info.end()); return &it->second; } //@} // end of INTERFACE SPECIFIC TO Parameterization_polyhedron_adaptor_3 //******************************************************************* /// @name ParameterizationMesh_3 INTERFACE //******************************************************************* //@{ // MESH INTERFACE /// Indicate if the mesh matches the ParameterizationMesh_3 concept. bool is_valid() const { return m_polyhedron.is_valid(); } /// Get iterator over first vertex of mesh. Vertex_iterator mesh_vertices_begin() { return m_polyhedron.vertices_begin(); } Vertex_const_iterator mesh_vertices_begin() const { return m_polyhedron.vertices_begin(); } /// Get iterator over past-the-end vertex of mesh. Vertex_iterator mesh_vertices_end() { return m_polyhedron.vertices_end(); } Vertex_const_iterator mesh_vertices_end() const { return m_polyhedron.vertices_end(); } /// Count the number of vertices of the mesh. int count_mesh_vertices() const { int index = 0; for (Vertex_const_iterator it=mesh_vertices_begin(); it!=mesh_vertices_end(); it++) index++; return index; } // Index vertices of the mesh from 0 to count_mesh_vertices()-1 void index_mesh_vertices () { #ifdef DEBUG_TRACE fprintf(stderr," index Parameterization_polyhedron_adaptor vertices:\n"); #endif int index = 0; for (Vertex_iterator it=mesh_vertices_begin(); it!=mesh_vertices_end(); it++) { Point_3 position = get_vertex_position(it); /*#ifdef DEBUG_TRACE fprintf(stderr, " %d=(%f,%f,%f)\n", index, (float)position.x(), (float)position.y(), (float)position.z()); #endif*/ set_vertex_index(it, index++); } #ifdef DEBUG_TRACE fprintf(stderr," ok\n"); #endif } /// Get iterator over first vertex of mesh's "main border". Border_vertex_iterator mesh_main_border_vertices_begin() { return Border_vertex_iterator(m_main_border.begin()); } Border_vertex_const_iterator mesh_main_border_vertices_begin() const { return Border_vertex_const_iterator(m_main_border.begin()); } /// Get iterator over past-the-end vertex of mesh's "main border". Border_vertex_iterator mesh_main_border_vertices_end() { return Border_vertex_iterator(m_main_border.end()); } Border_vertex_const_iterator mesh_main_border_vertices_end() const { return Border_vertex_const_iterator(m_main_border.end()); } /// Return the border containing seed_vertex. /// Return an empty list if not found. std::list<Vertex_handle> get_border(Vertex_handle seed_vertex) { std::list<Vertex_handle> border; // returned list Halfedge_around_vertex_circulator pHalfedge = seed_vertex->vertex_begin(); Halfedge_around_vertex_circulator end = pHalfedge; // if isolated vertex if (pHalfedge == NULL) { border.push_back(seed_vertex); return border; } // Get seed_vertex' border halfedge Halfedge_handle seed_halfedge = NULL; CGAL_For_all(pHalfedge,end) { if(pHalfedge->is_border()) { seed_halfedge = pHalfedge; break; } } // if inner vertex if (seed_halfedge == NULL) return border; // return empty list // Add seed vertex border.push_back(seed_vertex); // fill border int size = 1; Halfedge_handle current_halfedge = seed_halfedge; do { // Stop if end of loop Halfedge_handle next_halfedge = current_halfedge->next(); Vertex_handle next_vertex = next_halfedge->vertex(); if(next_vertex == seed_vertex) break; // Add vertex border.push_back(next_vertex); current_halfedge = next_halfedge; size++; } while(1); return border; } /// Get iterator over first facet of mesh. Facet_iterator mesh_facets_begin() { return m_polyhedron.facets_begin(); } Facet_const_iterator mesh_facets_begin() const { return m_polyhedron.facets_begin(); } /// Get iterator over past-the-end facet of mesh. Facet_iterator mesh_facets_end() { return m_polyhedron.facets_end(); } Facet_const_iterator mesh_facets_end() const { return m_polyhedron.facets_end(); } /// Count the number of facets of the mesh. int count_mesh_facets() const { int index = 0; for (Facet_const_iterator it=mesh_facets_begin(); it!=mesh_facets_end(); it++) index++; return index; } /// Return true of all mesh's facets are triangles. bool is_mesh_triangular() const { for (Facet_const_iterator it = mesh_facets_begin(); it != mesh_facets_end(); it++) if (count_facet_vertices(it) != 3) return false; return true; // mesh is triangular if we reach this point } /// Count the number of halfedges of the mesh. int count_mesh_halfedges() const { int index = 0; for (Halfedge_iterator pHalfedge = m_polyhedron.halfedges_begin(); pHalfedge != m_polyhedron.halfedges_end(); pHalfedge++) { index++; } return index; } // FACET INTERFACE /// Get circulator over facet's vertices. Vertex_around_facet_circulator facet_vertices_begin(Facet_handle facet) { return Vertex_around_facet_circulator(facet->facet_begin()); } Vertex_around_facet_const_circulator facet_vertices_begin(Facet_const_handle facet) const { return Vertex_around_facet_const_circulator(facet->facet_begin()); } /// Count the number of vertices of a facet. int count_facet_vertices(Facet_const_handle facet) const { int index = 0; Vertex_around_facet_const_circulator cir = facet_vertices_begin(facet), cir_end = cir; CGAL_For_all(cir, cir_end) index++; return index; } // VERTEX INTERFACE /// Get the 3D position of a vertex Point_3 get_vertex_position(Vertex_const_handle vertex) const { return vertex->point(); } /// Get/set the 2D position (u/v pair) of a vertex. Default value is undefined. /// (stored in halfedges sharing the same vertex). Point_2 get_vertex_uv(Vertex_const_handle vertex) const { return get_corners_uv(vertex, NULL, NULL); } void set_vertex_uv(Vertex_handle vertex, const Point_2& uv) { set_corners_uv(vertex, NULL, NULL, uv); } /// Get/set "is parameterized" field of vertex. Default value is undefined. /// (stored in halfedges sharing the same vertex). bool is_vertex_parameterized(Vertex_const_handle vertex) const { return are_corners_parameterized(vertex, NULL, NULL); } void set_vertex_parameterized(Vertex_handle vertex, bool parameterized) { set_corners_parameterized(vertex, NULL, NULL, parameterized); } /// Get/set vertex index. Default value is undefined. /// (stored in Polyhedron vertex for debugging purpose). int get_vertex_index(Vertex_const_handle vertex) const { return info(vertex)->index(); } void set_vertex_index(Vertex_handle vertex, int index) { info(vertex)->index(index); } /// Get/set vertex' all purpose tag. Default value is undefined. /// (stored in halfedges sharing the same vertex). int get_vertex_tag(Vertex_const_handle vertex) const { return get_corners_tag(vertex, NULL, NULL); } void set_vertex_tag(Vertex_handle vertex, int tag) { set_corners_tag(vertex, NULL, NULL, tag); } /// Return true if a vertex belongs to ANY mesh's border. bool is_vertex_on_border(Vertex_const_handle vertex) const { Halfedge_around_vertex_const_circulator pHalfedge = vertex->vertex_begin(); Halfedge_around_vertex_const_circulator end = pHalfedge; if(pHalfedge == NULL) // isolated vertex return true; CGAL_For_all(pHalfedge,end) if(pHalfedge->is_border()) return true; return false; } /// Return true if a vertex belongs to the UNIQUE mesh's main border, /// i.e. the mesh's LONGEST border. bool is_vertex_on_main_border(Vertex_const_handle vertex) const { return std::find(m_main_border.begin(), m_main_border.end(), (Vertex*)&*vertex) != m_main_border.end(); } /// Get circulator over the vertices incident to 'vertex'. /// 'start_position' defines the optional initial position of the circulator. Vertex_around_vertex_circulator vertices_around_vertex_begin( Vertex_handle vertex, Vertex_handle start_position = Vertex_handle()) { if (start_position == NULL) return Vertex_around_vertex_circulator(vertex->vertex_begin()); else return Vertex_around_vertex_circulator( Halfedge_around_vertex_circulator( get_halfedge(start_position, vertex))); } Vertex_around_vertex_const_circulator vertices_around_vertex_begin( Vertex_const_handle vertex, Vertex_const_handle start_position = Vertex_const_handle()) const { if (start_position == NULL) return Vertex_around_vertex_const_circulator(vertex->vertex_begin()); else return Vertex_around_vertex_const_circulator( Halfedge_around_vertex_const_circulator( get_halfedge(start_position, vertex))); } //@} // end of ParameterizationMesh_3 INTERFACE //******************************************************************* /// @name ParameterizationPatchableMesh_3 INTERFACE //******************************************************************* //@{ // VERTEX INTERFACE /// Get/set vertex seaming flag. Default value is undefined. int get_vertex_seaming(Vertex_const_handle vertex) const { return info(vertex)->seaming(); } void set_vertex_seaming(Vertex_handle vertex, int seaming) { info(vertex)->seaming(seaming); } // EDGE INTERFACE /// Get/set oriented edge's seaming flag, i.e. position of the oriented edge /// w.r.t. to the UNIQUE main border. int get_halfedge_seaming(Vertex_const_handle source, Vertex_const_handle target) const { return info(get_halfedge(source, target))->seaming(); } void set_halfedge_seaming(Vertex_handle source, Vertex_handle target, int seaming) { info(get_halfedge(source, target))->seaming(seaming); } // CORNER INTERFACE /// Get/set the 2D position (= (u,v) pair) of corners at the "right" /// of the prev_vertex -> vertex -> next_vertex line. /// Default value is undefined. /// (stored in incident halfedges). Point_2 get_corners_uv(Vertex_const_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex) const { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // get (u,v) pair from any incident halfedge return info(vertex->halfedge())->uv(); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // get (u,v) pair from first inner halfedge (clockwise) Halfedge_around_vertex_const_circulator cir( get_halfedge(next_vertex, vertex) ); return info(cir)->uv(); } } void set_corners_uv(Vertex_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex, const Point_2& uv) { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // Loop over all incident halfedges Halfedge_around_vertex_circulator cir = vertex->vertex_begin(), cir_end = cir; CGAL_For_all(cir, cir_end) info(cir)->uv(uv); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // first inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir( get_halfedge((Vertex*)&*next_vertex, vertex) ); // past-the-end inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir_end( get_halfedge((Vertex*)&*prev_vertex, vertex) ); // Loop over incident halfedges at the "right" // of the prev_vertex -> vertex -> next_vertex line CGAL_For_all(cir, cir_end) info(cir)->uv(uv); } } /// Get/set "is parameterized" field of corners at the "right" /// of the prev_vertex -> vertex -> next_vertex line. /// Default value is undefined. /// (stored in incident halfedges). bool are_corners_parameterized(Vertex_const_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex) const { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // get "is parameterized" field from any incident halfedge return info(vertex->halfedge())->is_parameterized(); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // get "is parameterized" field from first inner halfedge (clockwise) Halfedge_around_vertex_const_circulator cir( get_halfedge(next_vertex, vertex) ); return info(cir)->is_parameterized(); } } void set_corners_parameterized(Vertex_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex, bool parameterized) { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // Loop over all incident halfedges Halfedge_around_vertex_circulator cir = vertex->vertex_begin(), cir_end = cir; CGAL_For_all(cir, cir_end) info(cir)->is_parameterized(parameterized); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // first inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir( get_halfedge((Vertex*)&*next_vertex, vertex) ); // past-the-end inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir_end( get_halfedge((Vertex*)&*prev_vertex, vertex) ); // Loop over incident halfedges at the "right" // of the prev_vertex -> vertex -> next_vertex line CGAL_For_all(cir, cir_end) info(cir)->is_parameterized(parameterized); } } /// Get/set index of corners at the "right" /// of the prev_vertex -> vertex -> next_vertex line. /// Default value is undefined. /// (stored in incident halfedges). int get_corners_index(Vertex_const_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex) const { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // get index from any incident halfedge return info(vertex->halfedge())->index(); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // get index from first inner halfedge (clockwise) Halfedge_around_vertex_const_circulator cir( get_halfedge(next_vertex, vertex) ); return info(cir)->index(); } } void set_corners_index(Vertex_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex, int index) { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // Loop over all incident halfedges Halfedge_around_vertex_circulator cir = vertex->vertex_begin(), cir_end = cir; CGAL_For_all(cir, cir_end) info(cir)->index(index); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // first inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir( get_halfedge((Vertex*)&*next_vertex, vertex) ); // past-the-end inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir_end( get_halfedge((Vertex*)&*prev_vertex, vertex) ); // Loop over incident halfedges at the "right" // of the prev_vertex -> vertex -> next_vertex line CGAL_For_all(cir, cir_end) info(cir)->index(index); } } /// Get/set all purpose tag of corners at the "right" /// of the prev_vertex -> vertex -> next_vertex line. /// Default value is undefined. /// (stored in incident halfedges). int get_corners_tag(Vertex_const_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex) const { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // get tag from any incident halfedge return info(vertex->halfedge())->tag(); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // get tag from first inner halfedge (clockwise) Halfedge_around_vertex_const_circulator cir( get_halfedge(next_vertex, vertex) ); return info(cir)->tag(); } } void set_corners_tag(Vertex_handle vertex, Vertex_const_handle prev_vertex, Vertex_const_handle next_vertex, int tag) { // if inner vertex if (prev_vertex == NULL && next_vertex == NULL) { // Loop over all incident halfedges Halfedge_around_vertex_circulator cir = vertex->vertex_begin(), cir_end = cir; CGAL_For_all(cir, cir_end) info(cir)->tag(tag); } else // if seam vertex { CGAL_surface_mesh_parameterization_precondition(prev_vertex != NULL); CGAL_surface_mesh_parameterization_precondition(next_vertex != NULL); // first inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir( get_halfedge((Vertex*)&*next_vertex, vertex) ); // past-the-end inner halfedge (for a clockwise rotation) Halfedge_around_vertex_circulator cir_end( get_halfedge((Vertex*)&*prev_vertex, vertex) ); // Loop over incident halfedges at the "right" // of the prev_vertex -> vertex -> next_vertex line CGAL_For_all(cir, cir_end) info(cir)->tag(tag); } } //@} // end of ParameterizationPatchableMesh_3 INTERFACE // Private operations private: /// Extract mesh's longest border. std::list<Vertex_handle> extract_longest_border(Polyhedron& ) { std::list<Vertex_handle> longest_border; // returned list double max_len = 0; // length of longest_border // Tag all vertices as unprocessed const int tag_free = 0; const int tag_done = 1; for (Vertex_iterator it=mesh_vertices_begin(); it!=mesh_vertices_end(); it++) set_vertex_tag(it, tag_free); // find all closed borders and keep longest one int nb = 0; while (1) { // Find a border tagged as "free" and tag it as "processed" std::list<Vertex_handle> border = find_free_border(tag_free, tag_done); if(border.empty()) break; // compute total len of 'border' double len = 0.0; typename std::list<Vertex_handle>::const_iterator it; for(it = border.begin(); it != border.end(); it++) { // Get next iterator (looping) typename std::list<Vertex_handle>::const_iterator next = it; next++; if (next == border.end()) next = border.begin(); Vector_3 vect = get_vertex_position(*next) - get_vertex_position(*it); len += std::sqrt(vect*vect); } // Keep 'border' if longer if (len > max_len) { longest_border = border; max_len = len; } nb++; } return longest_border; } /// Find a border tagged as "free" and tag it as "processed". /// Return an empty list if not found. std::list<Vertex_handle> find_free_border(int tag_free, int tag_done) { std::list<Vertex_handle> border; // returned list // get any border vertex with "free" tag Vertex_handle seed_vertex = NULL; for (Vertex_iterator pVertex = mesh_vertices_begin(); pVertex != mesh_vertices_end(); pVertex++) { if (is_vertex_on_border(pVertex) && get_vertex_tag(pVertex) == tag_free) { seed_vertex = pVertex; break; } } if (seed_vertex == NULL) return border; // return empty list // Get the border containing seed_vertex border = get_border(seed_vertex); // Tag border vertices as "processed" typename std::list<Vertex_handle>::iterator it; for(it = border.begin(); it != border.end(); it++) set_vertex_tag(*it, tag_done); return border; } // Fields private: /// The adapted mesh (cannot be NULL). Polyhedron& m_polyhedron; /// Additional info attached to halfedges. Halfedge_info_map m_halfedge_info; /// Additional info attached to vertices. Vertex_info_map m_vertex_info; /// Main border of a topological disc inside m_polyhedron (may be empty). std::list<Vertex_handle> m_main_border; // Private types private: /// Functor for operator< for classes lacking this operator. struct Less { /// functor for operator< on Polyhedron::Halfedge_const_handle items bool operator()(const Halfedge_const_handle& _Left, const Halfedge_const_handle& _Right) const { // apply operator< to pointers return (&*_Left < &*_Right); } /// functor for operator< on Polyhedron::Vertex_const_handle items bool operator()(const Vertex_const_handle& _Left, const Vertex_const_handle& _Right) const { // apply operator< to pointers return (&*_Left < &*_Right); } }; /// Utility class to generate the Vertex_around_facet_circulator type. struct Project_halfedge_vertex { typedef Halfedge argument_type; typedef typename Parameterization_polyhedron_adaptor_3::Vertex Vertex; typedef Vertex result_type; /// Get the target vertex of a halfedge Vertex& operator()(Halfedge& h) const { return *(h.vertex()); } const Vertex& operator()(const Halfedge& h) const { return *(h.vertex()); } }; /// Utility class to generate the Border_vertex_iterator type. struct Project_vertex_handle_vertex { typedef Vertex_handle argument_type; typedef typename Parameterization_polyhedron_adaptor_3::Vertex Vertex; typedef Vertex result_type; /// Convert Vertex_handle to Vertex Vertex& operator()(Vertex_handle& vh) const { return *vh; } const Vertex& operator()(const Vertex_handle& vh) const { return *vh; } }; /// This class is used to generate the Vertex_around_vertex_circulator type. struct Project_opposite_halfedge_vertex { typedef Halfedge argument_type; typedef typename Parameterization_polyhedron_adaptor_3::Vertex Vertex; typedef Vertex result_type; /// Get the source vertex of a halfedge Vertex& operator()(Halfedge& h) const { return *(h.opposite()->vertex()); } const Vertex& operator()(const Halfedge& h) const { return *(h.opposite()->vertex()); } }; }; // Parameterization_polyhedron_adaptor_3 CGAL_END_NAMESPACE #endif //CGAL_SURFACE_MESH_PARAMETERIZATION_POLYHEDRON_ADAPTOR3_H
Index: include/CGAL/Parameterization_polyhedron_adaptor_3.h =================================================================== --- include/CGAL/Parameterization_polyhedron_adaptor_3.h (revision 57384) +++ include/CGAL/Parameterization_polyhedron_adaptor_3.h (working copy) @@ -126,7 +126,7 @@ class Halfedge_info { public: - typedef typename Polyhedron_3_::Traits::Point_2 + typedef typename Polyhedron_3_::Traits::Kernel::Point_2 Point_2; private: @@ -210,20 +210,20 @@ //@{ /// Number type to represent coordinates. - typedef typename Polyhedron::Traits::FT NT; + typedef typename Polyhedron::Traits::Kernel::FT NT; /// 2D point that represents (u,v) coordinates computed /// by parameterization methods. Must provide X() and Y() methods. - typedef typename Polyhedron::Traits::Point_2 + typedef typename Polyhedron::Traits::Kernel::Point_2 Point_2; /// 3D point that represents vertices coordinates. Must provide X() and Y() methods. - typedef typename Polyhedron::Traits::Point_3 + typedef typename Polyhedron::Traits::Kernel::Point_3 Point_3; /// 2D vector. Must provide X() and Y() methods. - typedef typename Polyhedron::Traits::Vector_2 + typedef typename Polyhedron::Traits::Kernel::Vector_2 Vector_2; /// 3D vector. Must provide X() and Y() methods. - typedef typename Polyhedron::Traits::Vector_3 + typedef typename Polyhedron::Traits::Kernel::Vector_3 Vector_3; /// Opaque type representing a facet of the 3D mesh. No methods are expected.
- [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/07/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/13/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/13/2010
