- To:
- Subject: Re: [cgal-discuss] error when compiling mesh 3 example
- Date: Fri, 16 Jul 2010 14:01:48 +0200
Hulusi wrote:
Hi everybody,
I have these errors when I want to compile the mesh 3 example:
Could anyone help me to fix it? Thanks!
Hulusi
These errors tell that you did not link with the library CGAL_ImageIO.
How did you proceed to compile the example?
I have a look at the CMakeLists.txt provided with the Mesh_3 examples,
and linking with ImageIO is well specified.
S.
CGAL_ImageIO-vc90-mt-gd.lib(all_files.obj) : error LNK2019: symbole externe
non résolu
__imp__glEnd@0
référencé dans la fonction "public: void
__thiscall CGAL::Image_3::gl_draw(float,unsigned char,unsigned char,unsigned
char)"
(?gl_draw@Image_3@CGAL@@QAEXMEEE@Z)
1>CGAL_ImageIO-vc90-mt-gd.lib(all_files.obj) : error LNK2019: symbole
externe non résolu
__imp__glVertex3d@24
void __thiscall CGAL::Image_3::gl_draw(float,unsigned char,unsigned
char,unsigned char)"
externe non résolu
__imp__glBegin@4
char)"
externe non résolu
__imp__glColor3ub@12
externe non résolu
__imp__glPointSize@4
externe non résolu
__imp__glLineWidth@4
void __thiscall CGAL::Image_3::gl_draw_bbox(float,unsigned char,unsigned
(?gl_draw_bbox@Image_3@CGAL@@QAEXMEEE@Z)
1>C:\Users\Bouttout\Documents\Visual Studio
2008\Projects\exemp1\Debug\exemp1.exe : fatal error LNK1120: 6 externes non
résolus
- [cgal-discuss] error when compiling mesh 3 example, Hulusi, 07/16/2010
- Re: [cgal-discuss] error when compiling mesh 3 example, Sebastien Loriot (GeometryFactory), 07/16/2010
