cgal-discuss - Re: Re: [cgal-discuss] CGAL+GMP and multithreading crash
  • To:
  • Subject: Re: Re: [cgal-discuss] CGAL+GMP and multithreading crash
  • Date: Fri, 16 Jul 2010 19:04:13 +0200 (CEST)
On Fri, 16 Jul 2010,
wrote:
Do you have any news on this ? I'm having the same issue with multithreading
and the Simple_cartesian<Gmpq> kernel. Do you plan to fix it someday ?
It is an old thread, you could give some context ;-)
It is not possible to make reference-counting thread-safe without slowing down single-threaded applications, so this hasn't been done yet. It is safe to use different Gmpq in different threads (as opposed to Gmpzf which may only be used in a single thread), but not to share one between threads.
I am assuming that you need an exact construction kernel, or you wouldn't be using this one.
You could try to use a type that does not use reference counting (mpq_class (from gmpxx.h) instead of Gmpq).
You could also make copies of all the objects that may be accessed (even read-only) by several threads, before starting the extra threads, and make sure each thread uses a different copy.
Or you could try making Gmpq thread-safer (there used to be a prototype there:
http://www.loria.fr/~glisse/tmp/atomic_counter/
but it probably doesn't even compile anymore)
Good luck,
Marc Glisse
