cgal-discuss - Re: [cgal-discuss] Using HDS
  • To:
  • Subject: Re: [cgal-discuss] Using HDS
  • Date: Mon, 19 Jul 2010 16:34:29 +0200
Sandeep Dey wrote:
Hi,
I need to use Half Edge Data structure for storing planar sub-division in 2-D.
I need to store faces. And split face and merge face operations will be required.
How should I create faces and store it?
How are vertex, half edge and face are connected in HDS? is it like by vertex we define half edge and then by collection of half edges we define face.
Many variants of HDS are given:
Halfedge default, HalfedgeDS min base, HalfedgeDS_list, HalfedgeDS_vector...
Any suggestions will be helpful, which one should be used for storing planar sub-division in 2-D and how it should be used?
Thanks and Best Regards,
Sandeep.
Have a look here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html
for simple examples
and here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS_ref/Concept_HalfedgeDS.html#Cross_link_anchor_1102
for complete reference manual of HDS class.
Function you may want to have a closer look are HDS::faces_push_back,
HDS::edges_push_back and HDS::vertices_push_back.
Connectivity in the HDS can be managed using halfedge member function
set_opposite, set_vertex, set_face, set_next, ...
