- To:
- Subject: Re: [cgal-discuss] problem with using Search_traits_vertex_handle_3
- Date: Thu, 22 Jul 2010 11:53:41 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ZKshyjQUyZyT+S3RXWHv2/nRuSYT0Py84lxC/PVZvqSE915RDxH1xmedLPQFZ0mrNs 07iEscokE2Wkw3QFFBey1P5kzYYnz96ocdacW8PXwNZBcF4+ceTAogkcyYzCA9VMo+Yc iYAepeKnbHXUsqntQTzz5VG7I1ti1E6ddKyeo=
Here is a minimal example that failed to compile, which made me think I have to use Fuzzy_sphere
typedef CGAL::Cartesian<double> K;
typedef K::Point_3 Point_3;
typedef CGAL::Search_traits_3<K> Traits;
typedef CGAL::Kd_tree<Traits> Tree;
typedef CGAL::Fuzzy_sphere<Traits> Fuzzy_sphere;
typedef CGAL::Sphere_3<K> Sphere;
std::vector<Point_3> points;
points.push_back(Point_3(1,1,1));
Tree tree(points.begin(), points.end());
//Fuzzy_sphere fs(Point_3(0,0,0), 5.0);
Sphere fs(Point_3(0,0,0),5.0);
tree.search(std::ostream_iterator<Point_3>(std::cout, "\n"), fs);
Basically, I tried to modify http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_59.3.4
Yifei
On Thu, Jul 22, 2010 at 11:17 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Yifei Li wrote:Maybe I answered too fast. Can you please post a minimal example
Sebastien,
What template parameter should I use for Sphere_3?
showing the problem?Which example did you try to modify?
Actually, when I followed a spatial search example which uses Fuzzy_sphere, I was thinking about if I can use Sphere_3 instead of Fuzzy_sphere. But I got some compilation errors.
Yifei
On Thu, Jul 22, 2010 at 2:45 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Yifei Li wrote:
Hi folks,
I have a set of points and for each point p, I need to find all
the neighbouring points in the ball centered at p with radius r.
Also I need to know the indices for those neighbouring points,
which is why I use Search_traits_vertex_handle_3
Here is how I do it:
typedef CGAL::Search_traits_vertex_handle_3<unsigned int> Traits;
Tree tree(V.begin(), V.end()); // Kd tree
Fuzzy_sphere fs(Point(10.0,10.0,10.0,0), 15, 0);
tree.search(std::ostream_iterator<Point>(std::cout, "\n"), fs);
However, I got the following compile error:
opt/local/include/CGAL/Fuzzy_sphere.h:50: error: ‘struct
CGAL::Point_vertex_handle_3<unsigned int>’ has no member named
‘dimension’
Any help is appreciated.
Yifei
Why are you using Fuzzy_sphere which is a d-dimensional sphere?
What about using Sphere_3 instead?
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] problem with using Search_traits_vertex_handle_3, Yifei Li, 07/21/2010
- Re: [cgal-discuss] problem with using Search_traits_vertex_handle_3, Sebastien Loriot (GeometryFactory), 07/22/2010
- Re: [cgal-discuss] problem with using Search_traits_vertex_handle_3, Yifei Li, 07/22/2010
