cgal-discuss - Re: [cgal-discuss] Re: Help needed reconstructing surfaces from 3D data sets
  • To:
  • Subject: Re: [cgal-discuss] Re: Help needed reconstructing surfaces from 3D data sets
  • Date: Fri, 23 Jul 2010 16:21:56 +0200
  • Organization: INFOTERRA
If you really want to compile TAUCS with gfortran, you should also:
- change LIBBLAS in taucs_full/config/linux64.mk to indicate the name of BLAS libraries on your machine
- remove the libraries precompiled with g77 in taucs_full/external/lib/linux64/
- compile Metis with gfortran and copy libmetis.a in taucs_full/external/lib/linux64/.
Metis is available in TAUCS >> 3.5 >> taucs_external_src.tgz on CGAL download page https://gforge.inria.fr/frs/?group_id=52
- run again configure and make in taucs_full/
Best regards,
Laurent Saboret
bobsta wrote:
Ok. I have installed the recommended version of taucs_full (August 2009)
To recap:
SuSE 11.2 64-bit
gcc (SUSE Linux) 4.4.1 [gcc-4_4-branch revision 150839]
GNU Fortran (SUSE Linux) 4.4.1 [gcc-4_4-branch revision 150839]
blas 3.2.1-2.2-x86_64
lapack 3.2.1-2.2-x86_64
I have slightly edited ../taucs_full/config/linux64.mk so that FC=gfortran
(instead of g77)
I also commented out #LIBF77 = -lg2c as suggested here
http://cgal-discuss.949826.n4.nabble.com/Problems-when-installing-taucs-full-td952828.html
I now receive the following error messages when attempting to make taucs
In file included from src/taucs_sn_llt.c:13:
src/taucs.h:6:32: error: taucs_config_tests.h: No such file or directory
src/taucs.h:83:2: error: #error "taucs_blas_*_test: linking with the BLAS
failed all attempts"
src/taucs.h:837: error: ‘taucs_blas_name’ declared as function returning
a function
src/taucs.h:837: warning: parameter names (without types) in function
declaration
src/taucs.h:838: error: ‘taucs_blas_name’ declared as function returning
a function
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any
contract or obligation, nor its subsidiaries.
