[cgal-discuss] Contibution for CGAL: Complex_3_in_triangulation_3_polyhedron_builder.h
- To:
- Subject: [cgal-discuss] Contibution for CGAL: Complex_3_in_triangulation_3_polyhedron_builder.h
- Date: Fri, 30 Jul 2010 13:41:53 +0300
Hi!
This seems to be now fully working, without complaining any skipped triangles.
Feel free to improve and import into CGAL.
Lehtonen, Matti
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Life is complex. It has real and imaginary parts.
// Copyright (c) 2003-2007 INRIA Sophia-Antipolis (France). // Copyright (c) 2008 GeometryFactory (France) // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.6-branch/Surface_mesher/include/CGAL/IO/Complex_3_in_triangulation_3_polyhedron_builder.h $ // $Id: Complex_3_in_triangulation_3_polyhedron_builder.h,v 1.1.2.10 2010-07-29 23:39:52 lehtomat Exp $ // // // Author(s) : Matti Lehtonen, based on work of Laurent Rineau #ifndef CGAL_IO_COMPLEX_3_IN_TRIANGULATION_3_POLYHEDRON_BUILDER_H #define CGAL_IO_COMPLEX_3_IN_TRIANGULATION_3_POLYHEDRON_BUILDER_H #include <CGAL/Modifier_base.h> #include <CGAL/Polyhedron_incremental_builder_3.h> namespace CGAL { template <class C3T3, class Polyhedron_> class Complex_3_in_triangulation_3_polyhedron_builder : public CGAL::Modifier_base<typename Polyhedron_::HalfedgeDS> { public: typedef C3T3 C3t3; typedef typename C3t3::Subdomain_index Subdomain_index; typedef Polyhedron_ Polyhedron; typedef typename Polyhedron::HalfedgeDS HDS; private: Subdomain_index const subdomain; Subdomain_index const surface; C3t3 const & c3t3; typedef CGAL::Modifier_base<typename Polyhedron::HalfedgeDS> Base; typedef typename C3t3::Triangulation Tr; typedef typename C3t3::Facet_iterator Facet_iterator; typedef typename Tr::Facet Facet; typedef typename Tr::Vertex_handle Vertex_handle; typedef typename Tr::Geom_traits::Vector_3 Vector; bool define_orientation ( Tr const & tr, Facet_iterator first, Facet_iterator end ) { // Orients the whole mesh towards outside: // - find the facet with max z Facet top_facet = *first; double top_z = ( top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 0 ) )->point().z() + top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 1 ) )->point().z() + top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 2 ) )->point().z() ) / 3.; for( Facet_iterator fit = first; fit != end; ++fit ) { double z = ( fit->first->vertex( tr.vertex_triple_index( fit->second, 0 ) )->point().z() + fit->first->vertex( tr.vertex_triple_index( fit->second, 1 ) )->point().z() + fit->first->vertex( tr.vertex_triple_index( fit->second, 2 ) )->point().z() ) / 3.; if( top_z < z ) { top_facet = *fit; top_z = z; } } // - orient the facet with max z towards +Z axis static Vector const Z( 0, 0, 1 ); Vertex_handle const v0 = top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 0 ) ); Vertex_handle const v1 = top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 1 ) ); Vertex_handle const v2 = top_facet.first->vertex( tr.vertex_triple_index( top_facet.second, 2 ) ); Vector const normal = cross_product( v1->point() - v0->point(), v2->point() - v1->point() ); bool const regular_orientation = ( Z * normal >= 0 ); return regular_orientation; } size_t construct_surface_from_faces ( CGAL::Polyhedron_incremental_builder_3<HDS> & builder, Tr const & tr, std::vector<Facet> const & oriented_set, bool const regular_orientation ) { typedef typename Tr::Vertex Vertex; typedef typename Tr::Point Point; // Map finite vertices of faces std::map<Vertex_handle, size_t> V; for( typename std::vector<Facet>::const_iterator fi = oriented_set.begin(); fi != oriented_set.end(); ++fi ) { for( unsigned i = 0; i < 3; ++i ) { Vertex_handle const & vh = fi->first->vertex( tr.vertex_triple_index( fi->second, i ) ); if( V.find( vh ) == V.end() ) { // Update later V[ vh ] = 0; } } } // Begin surface builder.begin_surface( V.size(), oriented_set.size() ); // Add points size_t counter = 0; for( typename std::map<Vertex_handle, size_t>::const_iterator vi = V.begin(); vi != V.end(); ++vi ) { Vertex_handle const & vh = vi->first; Point const & p = vh->point(); // Update now, in correct order V[ vh ] = counter++; builder.add_vertex( p ); } size_t skipped = 0; for( typename std::vector<Facet>::const_iterator fit = oriented_set.begin(); fit != oriented_set.end(); ++fit ) { size_t indices[ 3 ]; for( int i = 0; i < 3; i++ ) { indices[ i ] = V[ fit->first->vertex( tr.vertex_triple_index( fit->second, i ) ) ]; } // Test std::vector<size_t> list; list.push_back( indices[ 0 ] ); list.push_back( regular_orientation ? indices[ 1 ] : indices[ 2 ] ); list.push_back( regular_orientation ? indices[ 2 ] : indices[ 1 ] ); list.push_back( indices[ 0 ] ); if( builder.test_facet_indices( list ) ) { builder.begin_facet(); builder.add_vertex_to_facet( list[ 0 ] ); builder.add_vertex_to_facet( list[ 1 ] ); builder.add_vertex_to_facet( list[ 2 ] ); builder.end_facet(); } else { #if 0 builder.begin_facet(); builder.add_vertex_to_facet( list[ 2 ] ); builder.add_vertex_to_facet( list[ 1 ] ); builder.add_vertex_to_facet( list[ 0 ] ); builder.end_facet(); #else // Test again, counterwise list.clear(); list.push_back( indices[ 0 ] ); list.push_back( regular_orientation ? indices[ 2 ] : indices[ 1 ] ); list.push_back( regular_orientation ? indices[ 1 ] : indices[ 2 ] ); list.push_back( indices[ 0 ] ); if( builder.test_facet_indices( list ) ) { builder.begin_facet(); builder.add_vertex_to_facet( list[ 0 ] ); builder.add_vertex_to_facet( list[ 1 ] ); builder.add_vertex_to_facet( list[ 2 ] ); builder.end_facet(); } else { // Crap! ++skipped; } #endif } } builder.end_surface(); return skipped; } // Maybe this function should be a template parameter or virtual function inline bool accept_face ( Subdomain_index const subdomain, Subdomain_index const surface, Facet const & f ) { if( ( c3t3.subdomain_index( f.first ) == subdomain ) && ( ( c3t3.surface_index( f ).first == surface ) || ( c3t3.surface_index( f ).second == surface ) ) ) { return true; } return false; } inline bool on_selection ( std::set<Facet> const & processed_set, Facet const & f ) { // Surface selection // Already processed? return accept_face( subdomain, surface, f ) && ///( f.first->is_facet_on_surface( f.second ) ) && ( processed_set.find( f ) == processed_set.end() ); } inline void do_selection ( std::stack<Facet> & stack, std::set<Facet> & processed_set, Facet const & f, Facet const & fm ) { if( on_selection( processed_set, f ) ) { processed_set.insert( f ); stack.push( f ); } else if( on_selection( processed_set, fm ) ) { processed_set.insert( fm ); stack.push( fm ); } } public: Complex_3_in_triangulation_3_polyhedron_builder ( Subdomain_index const subdomain, Subdomain_index const surface, C3t3 const & c3t3 ) : Base(), subdomain( subdomain ), surface( surface ), c3t3( c3t3 ) {} void operator() ( HDS& hds ) { typedef typename Tr::Edge Edge; typedef typename Tr::Facet_circulator Facet_circulator; CGAL::Polyhedron_incremental_builder_3<HDS> builder( hds, true ); Tr const & tr = c3t3.triangulation(); bool const regular_orientation = define_orientation( tr, c3t3.facets_begin(), c3t3.facets_end() ); std::set<Facet> processed_set; std::vector<Facet> oriented_set; // Ordered set std::stack<Facet> stack; size_t rejected = 0; for( Facet_iterator fit = c3t3.facets_begin(); fit != c3t3.facets_end(); ++fit ) { do_selection( stack, processed_set, *fit, tr.mirror_facet( *fit ) ); // Locate all faces that are some way connected to faces in stack while( !stack.empty() ) { Facet f = stack.top(); stack.pop(); oriented_set.push_back( f ); // Process neighbor faces of f for( int ih = 0 ; ih < 3 ; ++ih ) { int const i1 = tr.vertex_triple_index( f.second, tr. cw( ih ) ); int const i2 = tr.vertex_triple_index( f.second, tr.ccw( ih ) ); Facet_circulator fc = tr.incident_facets( Edge( f.first, i1, i2 ), f ); Facet_circulator done( fc ); CGAL_For_all( fc, done ) { Facet const & fn = *fc; do_selection( stack, processed_set, fn, tr.mirror_facet( fn ) ); } } } // Process the oriented set rejected += construct_surface_from_faces( builder, tr, oriented_set, regular_orientation ); oriented_set.clear(); } if( rejected ) { std::cerr << "Warning: skipped " << rejected << " triangle" << ( rejected == 1 ? "" : "s" ) << std::endl; builder.remove_unconnected_vertices(); } } // end operator() }; // end Complex_3_in_triangulation_3_polyhedron_builder } // end namespace CGAL #endif // CGAL_IO_COMPLEX_3_IN_TRIANGULATION_3_POLYHEDRON_BUILDER_H
- [cgal-discuss] Contibution for CGAL: Complex_3_in_triangulation_3_polyhedron_builder.h, Lehtonen, Matti/HIIT, 07/30/2010
