cgal-discuss - Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2"
  • To:
  • Subject: Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2"
  • Date: Fri, 30 Jul 2010 14:54:38 +0200
Can you please try with Exact_predicates_exact_constructions_kernel and tell us whether you still observe the problem?
(this may be an floating point arithmetic problem)
Thanks.
S.
Benoît Presles wrote:
Hello Everybody,
I use the latest version of CGAL and I think a bug could be present in the function "find_optimal_alpha" of the class "Alpha_shape_2".
- First, I use the function "find_optimal_alpha" to find the best alpha to get 1 connected component.
- Second, I set this alpha.
- Third, I use the function "number_of_solid_components" to get the number of solid components of A.
Sometimes, the program gives me 2 connected components instead of 1.
Attached, you can fine the c++ code (basically the same as in the example) and a list of points for which the program doesn't work as expected.
Thank you for your help,
Best Regards,
Ben_P
