Re: [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity
- To:
- Subject: Re: [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity
- Date: Mon, 02 Aug 2010 07:28:56 +0200
htg20 wrote:
Dear Monique,Copying data from all_edges_begin to all_edges_end (or the finite version) should allow you to get back the connectivity between points.
Thank you. I looked at the IO functionality if triangulation database. However, I
couldn't find anything. This is perhaps because I do not know much of C++.
Nevertheless, I think I would have been nice for such a library like CGAL,
to have simple methods to convert the database into primitive data such as
arrays. This way interfacing with CGAL would be much easier. As I'm saying,
I am just a user.
Cheers
Hossein
If you need to track your original points, use a vertex class such as
Triangulation_vertex_base_with_info_3 and add an integer to each vertex:
(example here http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_37.5.2)
and insert your points one by one to set the index associated to each vertex.
S.
- [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, htg20, 08/01/2010
- Re: [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, Sebastien Loriot (GeometryFactory), 08/02/2010
- [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, htg20, 08/02/2010
- Re: [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, Sebastien Loriot (GeometryFactory), 08/03/2010
- [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, htg20, 08/03/2010
- [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, htg20, 08/05/2010
- Re: [cgal-discuss] Re: Extracting Information to Simple Array Format, Triangulation connectivity, Sebastien Loriot (GeometryFactory), 08/06/2010
