cgal-discuss - [cgal-discuss] dD Delaunay triangulation highly inefficient
  • To:
  • Subject: [cgal-discuss] dD Delaunay triangulation highly inefficient
  • Date: Thu, 5 Aug 2010 09:00:47 +0200
Hi all. I've been using the Delaunay_d CGAL code for a while to do 3D
triangulations, which has worked very well. I recently tried to step it up
to 4D and 5D triangulations, and things are not going so well. CGAL is
causing a segfault because it is blowing through the maximum stack size
(which is 8 MB on OS X) around the 790th 5D point added to the triangulation.
I tried giving it 16 MB of stack to give it more headroom, but then it just
blows through it a little later (around the 1250th point added). It also
gets extremely slow at adding points compared to the 3D case; adding 16384
points in 3D takes just a couple of minutes total on my machine, but adding
4D or 5D points gets to taking as long as a minute per point added (before it
causes the segfault). I was hoping to add as many as 100,000 points to my 5D
triangulation, but clearly this is not going to work.
Is this known / expected? Maybe doing triangulations in more than three
dimensions is inherently extremely difficult; but it kind of feels like the
CGAL code might be switching algorithms "under the hood" for >3 dimensions,
and maybe the algorithm it switches to is not so good. Or have others been
successful doing this kind of thing, and there is something about the way I'm
using CGAL that is causing problems?
Ben Haller
McGill University
