- To:
- Subject: Re: [cgal-discuss] Runtime error with only CImage3 included
- Date: Fri, 6 Aug 2010 11:08:07 +0200
On Friday 06 August 2010 09:48:00 jcsouplet wrote:
> Good-morning,
> I tried to use CGAL with a cmake project with qt-creator to generate mesh.
> I performed this task but when I am closing my program I have the runtime
> error message.
> I removed all cgal code and include. The runtime error was removed.
> I add #include <CGAL/Image_3.h> and the runtime error came back.
> Do you have any suggestion to remove this error ?
Link with libCGAL_ImageIO.
If you want further help, please post a small .cpp program than one can
compile, and explain how you compile your program. That way, everybody on
this
list will be able to try reproducing your error and find a fix.
Laurent Rineau, PhD
- [cgal-discuss] Runtime error with only CImage3 included, jcsouplet, 08/06/2010
- Re: [cgal-discuss] Runtime error with only CImage3 included, Sebastien Loriot (GeometryFactory), 08/06/2010
- Re: [cgal-discuss] Runtime error with only CImage3 included, Jean-Christophe Souplet, 08/06/2010
- Re: [cgal-discuss] Runtime error with only CImage3 included, Laurent Rineau (GeometryFactory), 08/06/2010
