cgal-discuss - Re: [cgal-discuss] gmp-vc90-mt.lib is missing in gmp-5.0.1_and_mpfr-3.0.0_precompiled_i686.zip
  • To:
  • Subject: Re: [cgal-discuss] gmp-vc90-mt.lib is missing in gmp-5.0.1_and_mpfr-3.0.0_precompiled_i686.zip
  • Date: Fri, 13 Aug 2010 11:24:21 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:reply-to:in-reply-to:references:date:message-id :subject:from:to:content-type; b=v/SMwU7v0Aa4S4quPyh89VuaTloGbCZp0E6CajuBnO61VNWp4pAvBsztqM5Csv8dv2 lY2DOyxckVf2D9uzFSXQP4HJ4I7krzaY9skTenmTeN9u8lKc+MTt7WlENLTS1yVLJmXO uuy1lAOSsO4GzHtoADWYdlOCxotfG2BMkTJFU=
Hello!
Have you tried renaming the libs? :) (that trick worked with vs2005)
regards, Pal.
2010/8/13 Parmeet
> Hi all,
> I have downloaded pre-compiled version of gmp and mpfr libraries from
> https://gforge.inria.fr/frs/?group_id=52. I have unzipped the contents in
> gmp directory under the CGAL installed directly. I am using this for
> converting to and from Nef_polyhedrons to polyhedrons as for the kernels of
> Nef_polyhedron.
> When i compiled my program, it says that cannot open file 'gmp-vc90-mt.lib'.
> Than i looked up in gmp directory and there is no such .lib file there.
> Could you please suggest me what should be done in this case.I shall be
> grateful.Looking forward to your replies.
> Thanks and Kind Regards
> Parmeet
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/gmp-vc90-mt-lib-is-missing-in-gmp-5-0-1-and-mpfr-3-0-0-precompiled-i686-zip-tp2323911p2323911.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
