cgal-discuss - [cgal-discuss] Conversion between Polyhedron and Nef_Polyhedron with Polyhedron having extended vertices,facets etc
  • To:
  • Subject: [cgal-discuss] Conversion between Polyhedron and Nef_Polyhedron with Polyhedron having extended vertices,facets etc
  • Date: Mon, 16 Aug 2010 06:10:15 -0700 (PDT)
Hi all,
I have additional attributes for Polyhedron facets,vertices etc so i have
following declaration for kernel of Polyhedron:
typedef CGAL::Polyhedron_3<Kernel,My_items> Polyhedron;
Where My_items defines structure derived from Polyhedron_items_3 class.
I wanted to convert this Polyhedron to Nef_polyhedron so that i can perform
CSG (3D boolean operations) based operations. But unfortunately i am getting
errors while i try to do so.
In the reference manual of Nef_polyhedron its been written that the second
parameter and the third parameter(in template of class Nef_polyhedron_3) are
for future considerations and hence i am getting errors i guess.
Please let me know if i am correct on above post and if there is any
alternative to my problem i.e to perform CSG based operation on Polyhedrons
(with extended vertices, facets etc) in present or any future release of
CGAL.
Thank you in advance.
Kind regards
Parmeet
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Conversion-between-Polyhedron-and-Nef-Polyhedron-with-Polyhedron-having-extended-vertices-facets-etc-tp2326851p2326851.html
  • [cgal-discuss] Conversion between Polyhedron and Nef_Polyhedron with Polyhedron having extended vertices,facets etc, Parmeet, 08/16/2010
