cgal-discuss - Re: [cgal-discuss] How to improve the speed of polygonsoffsettinginCGAL?
  • To:
  • Subject: Re: [cgal-discuss] How to improve the speed of polygonsoffsettinginCGAL?
  • Date: Tue, 31 Aug 2010 17:03:11 +0800
i use the Microsoft visual studio 2008 for code ,
the cgal version is CGAL3.6
------------------ 原始邮件 ------------------
>From: "Laurent Rineau (GeometryFactory)"
>Reply-To:
>To:
>Date: Tue, 31 Aug 2010 10:58:12 +0200
>On Tuesday 31 August 2010 10:37:15 罗恒 wrote:
>> Hi,thank you for your reply.i have done that as you said,#define
>> _SECURE_SCL 0 #define NDEBUG are in the first line and second line before
>> other codes,but the speed is the same,it doesn't change at all. what
>> should i do now?please give me help. The .cpp file and the data are
>> attached in the email. Best regards!
>What are the compilation flags Visual Studio used to compile the application?
>Laurent Rineau, PhD
>R&D Engineer at GeometryFactory http://www.geometryfactory.com/
>Release Manager of the CGAL Project http://www.cgal.org/
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
