[cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
- To:
- Subject: [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
- Date: Thu, 2 Sep 2010 16:06:43 -0700 (PDT)
I wouldn't know what to do here. Also I am not sure how you calculate the
direction of a facet but I can give you a word of warning - when I saved the
3d mesh as medit .mesh file with CGAL, the facet directions were random. I
had to edit the File_medit_IO.h (or smth like that, don't remember its name
now) such that the facet norms were consistent - all pointing outside the
meshed domain.
mparusinski wrote:
> Did you get any problem regarding identifying the direction of each
> facets. I am trying to see for each facet if it is pointing towards x
> positive, x negative, y positive, y negative, z positive or z
> negative, using normals to facets. Identifying the x,y and z direction
> is fine, however identifying the positive and negative bit is quite
> vulnerable to floating point arithmetic imprecision. I rely on using
> the normal to a facet and the tetrahedra it is on. Any advice on that?
> On 1 September 2010 23:34, Ianic
> wrote:
>> Check the bottom of this thread:
>> http://cgal-discuss.949826.n4.nabble.com/Neighbours-list-in-3D-meshing-td2075323.html#a2132298
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/CGAL-3d-Mesh-Triangulation-Facets-with-too-many-neighbors-facets-tp2332420p2429072.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/CGAL-3d-Mesh-Triangulation-Facets-with-too-many-neighbors-facets-tp2332420p2524911.html
- Re: [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets., Michal Parusinski, 09/01/2010
- [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets., Ianic, 09/02/2010
- Re: [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets., Michal Parusinski, 09/02/2010
- [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets., Ianic, 09/03/2010
- Re: [cgal-discuss] Re: CGAL 3d Mesh Triangulation. Facets with too many neighbors facets., Michal Parusinski, 09/03/2010
