[cgal-discuss] BUG: In CGAL/Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h Was: Simplification: Borders not honored
- To: "Lehtonen, Matti/HIIT" <>
- Cc:
- Subject: [cgal-discuss] BUG: In CGAL/Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h Was: Simplification: Borders not honored
- Date: Sun, 05 Sep 2010 11:04:33 +0300
HI!
Versions of files:
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.5-branch/Surface_mesh_simplification/include/CGAL/Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h
// $Id: halfedge_collapse_Polyhedron_3.h 50078 2009-06-25 15:12:52Z fcacciola
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.5-branch/Surface_mesh_simplification/include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h
// $Id: Edge_collapse_impl.h 50078 2009-06-25 15:12:52Z fcacciola $
Sympton:
The border were broken after edge collapse, even the border were constrained.
See:
http://picasaweb.google.fi/mmalehtonen/SimplificationBorderNotHonored?authkey=Gv1sRgCKTirofBua60GQ&feat=directlink
Description:
In Edge_collapse_impl.h, line 358, an edge is rejected if vertices P *and* Q
are
on border allowing case were vertex P is on border and vertex Q is not (and
vice-versa). However, in halfedge_collapse_Polyhedron_3.h, lines 145-150,
vertex
P is always removed without checking.
Correct fix:
In halfedge_collapse_Polyhedron_3.h it should be checked that vertex P isn't
on
border and vertex Q should be removed instead, if P is on border. However, it
is
currently impossible, because vertex_descriptor don't have is_border() method
or
it is next to impossible to call bool EdgeCollapse<...>::is_border(...) for
vertex.
Quick fix:
In Edge_collapse_impl.h, line 358, change "&&" to "||" or reject edges that
have
any vertex on border. However, this prevents edges to be collapsed by removing
vertex Q.
Lehtonen, Matti
Quoting "Lehtonen, Matti/HIIT"
> Codebase: plain 3.5.1
> Sympton:
> I have simplified surfaces extracted from C3T3 volume(s). For some reason, I
> cannot get borders honored (not modified during simplification process),
> even
> thought they should be.
> See:
> Question: How to solve this problem?
> Code samples:
> * Simplification:
> int r = CGAL::Surface_mesh_simplification::edge_collapse( P,
> stop,
> CGAL::vertex_index_map( boost::get( CGAL::vertex_external_index, P
> .edge_index_map (boost::get(CGAL::edge_external_index, P ) )
> .edge_is_border_map( constrains_map )
> .get_cost(
> CGAL::Surface_mesh_simplification::Edge_length_cost<Polyhedron>()
> .get_placement(
> CGAL::Surface_mesh_simplification::Midpoint_placement<Polyhedron>() )
> .visitor( vis ) );
> * Constraint map:
> reference
> operator[]
> key_type const & e
> const
> key_type const & oe = opposite_edge( e, polyhedron );
> return e->is_border() ||
> /* Without opposite edge checking, even less is honored */
> oe->is_border() /* ||
> is_constrained( e ) || is_constrained( oe ) */;
> * stop predicate:
> bool
> operator()
> FT const & aCurrentCost __attribute__((unused)),
> Profile const& aEdgeProfile __attribute__((unused)),
> size_type aInitialCount __attribute__((unused)),
> size_type aCurrentCount __attribute__((unused))
> const
> return aCurrentCost > _aParam ;
> Data files:
https://docs.google.com/uc?id=0B0XXln5ZRT1xMTczZWFkMmQtNTJjNy00MzA3LTg2MzgtYmIyMjNiYjJkZjU0&authkey=CMCXweAE&hl=en
> Thx,
> Lehtonen, Matti
> Researcher, head programmer - Helsinki Institute for Information Technology
> HIIT
> http://www.hiit.fi/
> Life is complex. It has real and imaginary parts.
HIIT
http://www.hiit.fi/
- [cgal-discuss] Simplification: Borders not honored, Lehtonen, Matti/HIIT, 09/01/2010
- [cgal-discuss] BUG: In CGAL/Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h Was: Simplification: Borders not honored, Lehtonen, Matti/HIIT, 09/05/2010
