cgal-discuss - Re: [cgal-discuss] multiple definitions problem
  • To:
  • Cc: "Laurent Rineau (GeometryFactory)" <>
  • Subject: Re: [cgal-discuss] multiple definitions problem
  • Date: Mon, 06 Sep 2010 13:58:20 +0200
Hi Laurent,
thanks for the quick reply. I just now managed to get my stuff compiling and yes those are the exact two files I had to fix, by inlining the 4 helper functions in QP_functions.h and the operator<< in QP_options.h
I was just wondering because I didn't think I had a very nonstandard use-case there.
Great, if it will be fixed in the next version!!!
regards
Michael
Am 09/06/2010 01:44 PM, schrieb Laurent Rineau (GeometryFactory):
On Monday 06 September 2010 12:51:19 Michael Jäntsch wrote:
Hello everyone,
I'm new to the list as I just started using CGAL last week. I also did
manage to implement my quadratic program without trouble with CGAL, but
now I'm experiencing some trouble. Maybe someone can help me.
Basically the linker complains about multiply defined functions, which
seems absolutely correct as the functions are defined in .h files (. I
already looked at the archives and I found a similar problem reported
twice:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-01/msg00023.html
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-01/msg00020.html
First one was in 2007 and seems to be resolved in the newer version of
CGAL but then the same problem appeared with different functions later.
Generally it seems like in CGAL there is a general problem of
non-template functions being defined in headers. When those headers are
then included in e.g multible cpp's and linked later on there will
always be a problem, or am I missing something??? How are other people
using this???
The error can be reproduced by having two cpp's both containig #include
<CGAL/QP_functions.h>
This will cause the linker error:
[...snip the error log]
I'm not sure how to resolve this. Could somebody please help me?
regards
Michael
Hi Michael,
You are right, there is a bug. That is not really a general problem of CGAL.
We do try to avoid those issue, but only manually: our a test suite is not
(yet) designed to catch such issues.
In you case, I found out that at least two headers have that bug. That will be
fixed in next release CGAL-3.7 (to be published before the end of September,
if everything goes well). In attachment, you can see the two *patched* files
to copy in include/CGAL/ as replacement of the existing ones.
Technische Universität München
Michael Jäntsch
Fakultät für Informatik
Robotics and Embedded Systems
Parkring 13
85748 Garching bei München
Tel: + 49.89.289.17626
Fax: + 49.89.289.17637
www6.in.tum.de
