cgal-discuss - Re: [cgal-discuss] VTK support
  • To:
  • Subject: Re: [cgal-discuss] VTK support
  • Date: Thu, 9 Sep 2010 11:05:28 +0200
On Wednesday 08 September 2010 21:46:12 Dominik Szczerba wrote:
> Thank you for the response.
> I need to load my own image buffer available in memory as an array of
> unsigned chars and sized NI*NJ*NK. I can not want to use the INR
> format. I tried to study the image::read function, but it is quite
> complicated. I would be most grateful if you could point me to a
> relevant code section.
Hi Dominik,
As far as I understand, you do not really need VTK support.
Anyway, have a look at the implementation of the following function:
bool Image_3::read_vtk_image_data(vtkImageData* vtk_image)
in src/CGALimageIO/Image_3.cpp in CGAL. You will find out how to construct a
CGAL::Image_3 from an array of char and meta-data. I can give you hints if
you
cannot easily reverse-engineer that code.
Laurent Rineau, PhD
