- To:
- Subject: Re: [cgal-discuss] Reinserting spheres in Min_sphere_of_spheres_d
- Date: Fri, 10 Sep 2010 17:05:10 +0200
- Organization: LORIA
On Fri, 10 Sep 2010 16:03:38 +0200
Samuel Hornus
wrote:
> Thank you Bernd,
> l.clear() indeed seems to fix the problem and, as far as I can trust
> gluSphere and my code and my eyes, the patched code correctly computes
> the new miniball(s), and I get a little more than 30% speed-up for
> computing all the balls.
It seems my eyes were not to be trusted, I use the hierarchy for Level
Of Detail visualization. When computing the bounding sphere of each
node from scratch, it works really fine. But when reusing some
Min_sphere_of_sphere_d's... the display of LOD is somewhat erratic, so
there might be more to do than a simple l.clear(), but I will also
investigate if the problem does come from my non-CGAL code or not.
regards,
Samuel
- [cgal-discuss] Reinserting spheres in Min_sphere_of_spheres_d, Samuel Hornus, 09/09/2010
- Re: [cgal-discuss] Reinserting spheres in Min_sphere_of_spheres_d, Bernd Gaertner, 09/10/2010
- Re: [cgal-discuss] Reinserting spheres in Min_sphere_of_spheres_d, Samuel Hornus, 09/10/2010
