- To:
- Subject: Re: [cgal-discuss] random points
- Date: Sun, 26 Sep 2010 01:28:27 +0200
Le dimanche 26 septembre 2010 01:18:21, sara123 a écrit :
> hi,
> i have a simple polygon (cgal manual, page 4070) and i want to produce some
> random points in (interior) the polygon. how can i do that?
It depends what distributions of point you want in the polygon.
If you want a uniform distribution, you can produce random points in the
bounding box of the polygon, and discard those that are outside the polygon.
That method will not be efficient if the shape of the polygon is thin (area
of
the polygon small compared to the area of the bounding box).
Laurent Rineau, PhD
- [cgal-discuss] random points, sara123, 09/26/2010
- Re: [cgal-discuss] random points, Laurent Rineau (GeometryFactory), 09/26/2010
- Re: [cgal-discuss] random points, Yang Liu, 09/26/2010
- Re: [cgal-discuss] random points, Bo Zhou, 09/26/2010
- [cgal-discuss] Re: random points, sara123, 09/27/2010
- Re: [cgal-discuss] Re: random points, Andreas Fabri, 09/27/2010
- [cgal-discuss] Re: random points, sara123, 09/29/2010
