cgal-discuss - [cgal-discuss] Surface_mesher with new image data: large number of "...anifold edges not initialized,non manifold vertices not initialized", apparently no convergence
  • To:
  • Subject: [cgal-discuss] Surface_mesher with new image data: large number of "...anifold edges not initialized,non manifold vertices not initialized", apparently no convergence
  • Date: Sun, 26 Sep 2010 20:26:21 -0400
Dear CGAL developers,
I'm trying to mesh a labeled volume of a brain that makes explicit a Sylvian fissure within it, giving each voxel in the latter a large negative value to ensure that the surface surrounding it is captured. The software seems to go into a long, probably infinite, loop that displays "...anifold edges not initialized,non manifold vertices not initialized" in verbose mode.
The last set of values is
(150260,150240,0,25934,non manifold vertices not initialized,) (615.2 vertices/s)
Under what circumstances will an image volume trigger such behaviour? With a simple binary volume that does not emphasize this Sylvian fissure, the meshing converges relatively quickly, but does not seem to identify the surface around the Sylvian fissure.
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
  • [cgal-discuss] Surface_mesher with new image data: large number of "...anifold edges not initialized,non manifold vertices not initialized", apparently no convergence, Michel Audette, 09/27/2010
