Re: [cgal-discuss] Re: Always received "unresolved external symbol: void __cdecl boost::detail::set_tss_data(...)"
- To:
- Subject: Re: [cgal-discuss] Re: Always received "unresolved external symbol: void __cdecl boost::detail::set_tss_data(...)"
- Date: Wed, 29 Sep 2010 11:31:28 +0200
Hello,
How did you compile boost? Did you specify the address model?
bjam address-model=64 --with-thread --with-date_time --with-program_options debug release stage
best regards,
andreas
On 29/09/2010 11:21, jcsouplet wrote:
Good-morning,
I have the same error. Did you find an answer ? I am compiling using visual
2010 x64.
I am using boost 1_44 compiling with the windows x64 command tool.
Thank you for your help,
Jean-Christophe
- [cgal-discuss] Re: Always received "unresolved external symbol: void __cdecl boost::detail::set_tss_data(...)", jcsouplet, 09/29/2010
- Re: [cgal-discuss] Re: Always received "unresolved external symbol: void __cdecl boost::detail::set_tss_data(...)", Andreas Fabri, 09/29/2010
