cgal-discuss - Re: [cgal-discuss] is_simple() precondition in Polygon_2 algorithms
  • To:
  • Subject: Re: [cgal-discuss] is_simple() precondition in Polygon_2 algorithms
  • Date: Thu, 30 Sep 2010 18:44:55 +0200
The simple and relatively simple properties are used to characterize polygons that are operands of operations provided by the 2D Regularized Boolean Set Operation package. All these operations construct an arrangement from the input polygons. The knowledge of these properties can be used to expedite the construction.
The bounded_side() operation is not provided by the 2D Regularized Boolean Set Operation package, so it may have other preconditions.
Quoting Remi
Hi, by relatively simple I mean what's in here:
http://www.cgal.org/Manual/3.6.1/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html#Section_19.2
"A *Relatively simple* polygon allows vertices with a degree>2, but all of
its edges are disjoint in their interior."
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
