Re: [cgal-discuss] How to copy double* X double* Y to std::list<Point_2> points
- To:
- Subject: Re: [cgal-discuss] How to copy double* X double* Y to std::list<Point_2> points
- Date: Tue, 5 Oct 2010 22:42:07 +0200
Le 5 oct. 10 à 15:14, Laurent Rineau (GeometryFactory) a écrit :
On Tuesday 05 October 2010 14:59:23 Benoît Presles wrote:
Hello everybody,
I am looking for a nice way to copy my data: double* X, double* Y to a
list of Point_2.
Here is my code:
//My data (example)
double X[]={1,2,3,5,6};
double Y[]={-10,7,5,9,5};
//My output:
std::list<Point_2> points;
//for loop
for(int i=0; i<5; ++i)
//std::cout << X[i] << " " << Y[i] << std::endl;
points.push_back(Point_2(X[i], Y[i]));
As one can notice, I do a "for loop" to copy my data. It works but I am
looking for a better way. Indeed, when my array X (or Y) is very big,
the code is a bit slow.
You should use std::vector instead of std::list, and reserve the memory:
points.reserve(n);
where n is the size of your arrays.
I am going to try but in fact I was wondering if there is a way to do it without "for loop".
Maybe with the "std::copy" function ?
Thank you very much for your help,
Benoît
- [cgal-discuss] How to copy double* X double* Y to std::list<Point_2> points, Benoît Presles, 10/05/2010
- Re: [cgal-discuss] How to copy double* X double* Y to std::list<Point_2> points, Laurent Rineau (GeometryFactory), 10/05/2010
- Re: [cgal-discuss] How to copy double* X double* Y to std::list<Point_2> points, Benoît Presles, 10/05/2010
