cgal-discuss - [cgal-discuss] is there a vtk-to-CGAL converter?
  • To:
  • Subject: [cgal-discuss] is there a vtk-to-CGAL converter?
  • Date: Wed, 13 Oct 2010 11:41:19 -0400
Dear CGAL developers,
I saw that the CGAL code has C3T3 and C2T3 to VTK converters, but I was wondering if the reverse converter exists somewhere. I am using MINC-formatted segmented volumes as input, which VTK can process but CGAL cannot. Moreover, these volumes have thin cracks (one or more sulci that I want to account for) that apparently gave problems to the CGAL polyhedral surface extraction (which I attempted after a conversion from MINC to Analyze), so I'm trying vtkMarchingCubes first, then would like to attempt the edge-collapse decimation,  and compare with VTK decimation methods. I need to either convert from a vtk surface output to CGAL C2T3, or use the vtkPolyData info to construct a CGAL polyhedral surface. Is there an example somewhere that I can use to achieve this?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
  • [cgal-discuss] is there a vtk-to-CGAL converter?, Michel Audette, 10/13/2010
