cgal-discuss - Re: [cgal-discuss] Exact_Predicates_Exact_Constructions
  • To:
  • Subject: Re: [cgal-discuss] Exact_Predicates_Exact_Constructions
  • Date: Sun, 24 Oct 2010 19:25:29 +0200 (CEST)
On Sun, 24 Oct 2010, Bernhard Kornberger wrote:
1) I need an exact constructions kernel for the computation
of intersections and orientations. According to an older
posting, Gmpq is not thread-safe. Is this still true?
Yes, in the sense that a Gmpq shouldn't be accessed (even read-only) from different threads. However you can use different Gmpq objects in different threads. So if you first compute a structure and then use it read-only in several threads, you can make one copy of the whole structure per thread and use those instead.
Is a #define necessary to specify thread-safety?
There is no such thing available for Gmpq. But see this link:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Preliminaries/Chapter_main.html#Section_2.6
CGAL::Cartesian<mpq_class> might work for you.
2) I assume that a Gmpq value, written to a file using
outFile<<q and read again is the same? Just to be sure
that the exactness is not lost in this step.
I think so.
Marc Glisse
