- To:
- Subject: Re: [cgal-discuss] Re: Triangulation_2 face circulator stange behavior
- Date: Fri, 29 Oct 2010 09:57:09 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=vy7vJzzqlWluKBaHVOeeLuz/M05qQ7vr7eFI7IDPFBU2aqZZbS2W/6ILJjN4oISN87 cX8Dui2o1djFa1GIz7NX1cl8FFLbtGC/XoTHrOPhxFQGHZiHAhWvWmFFhcjOYKw/N2fC z2JAb+TGmeF2PoyV5VSYN5SOe2FI8LWjMF3dY=
Michele wrote:
He Sebastien,You are asking for all incident facets to the infinite vertex. Since they are all infinite by definition, nothing is printed.
I tryed it , but now it prints anything. So, does it mean that all the faces
are infinite?
if you use is_infinite at the vertex level (!is_infinite(fc->vertex(i)))
only finite vertices will be considered.
Again, as I said you probably should use Finite_faces_iterator (except if you are interested in only vertices on the convex hull).
S.
I don't think so. I tryed also to put more triangles, but it doesn't change.
Thanks
Michele
- [cgal-discuss] Triangulation_2 face circulator stange behavior, Michele, 10/29/2010
- Re: [cgal-discuss] Triangulation_2 face circulator stange behavior, Sebastien Loriot (GeometryFactory), 10/29/2010
- [cgal-discuss] Re: Triangulation_2 face circulator stange behavior, Michele, 10/29/2010
- Re: [cgal-discuss] Re: Triangulation_2 face circulator stange behavior, Sebastien Loriot (GeometryFactory), 10/29/2010
