cgal-discuss - [cgal-discuss] Re: indices in CGAL::Delaunay_triangulation_2
  • To:
  • Subject: [cgal-discuss] Re: indices in CGAL::Delaunay_triangulation_2
  • Date: Wed, 1 Dec 2010 08:01:59 -0800 (PST)
mr_hell wrote:
> I have some troubles with filling CGAL::Delaunay_triangulation_2 with
> vertices using info() in vertex handle.
> Normally i use this kind of code
> for(int i = 0; i < inp_pointscount; i++){
> Delaunay2::Vertex_handle vert =
> triangulation.insert(DelaunayPoint2(inputpoints[i].x,inputpoints[i].y));
> vert->info() = i;
> but in this case each triangulation.insert call causes triangulation
> recalculation, so i have inp_pointscount triangulation calls instead of
> one, and it takes more time to get result.
> and this code
> triangulation.insert(pointlist.begin(), pointlist.end());
> int count = 0;
> for(Delaunay2::Finite_vertices_iterator v_it =
> triangulation.finite_vertices_begin(); v_it !=
> triangulation.finite_vertices_end(); ++v_it, count++)
> v_it->info() = count;
> doesnt work correctly.
> how to fill info() field, get correct results and call triangulation only
> one time?
Hello list,
I am also having the same problem.
I try to assign unique indices to the Delaunay vertices by using info().
Is there a way to fill the info() field by using the iterator version of the
insert method?
I also would like to know, does the vertex iterator preserve the same order
of vertices/points as I inserted them?
Cheers,
Jens
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/indices-in-CGAL-Delaunay-triangulation-2-tp2851213p3067565.html
