- To:
- Subject: Re: [cgal-discuss] Extracting Voronoi diagram from Regular_triangulation_3
- Date: Thu, 02 Dec 2010 00:21:39 +0100
randooom wrote:
Hi all,this is hard to believe.
I have to do some computation on a Voronoi diagram and therefore I need to
extract the diagram out of the triangulation into a more accessible data
structure.
A colleague has done this some time ago, but his version is incredible slow
(it takes 4 hours! to extract a Voronoi diagram from a triangulation of only
5000 points).
The said data structure consists basically of vertices, faces and cells. TheHere is what I would do:
vertices represent the points and know their adjacent vertices, a face knows
its vertices and a cell its faces.
1) create dual faces of each triangulation edge and maintain the
mapping (usually we use a sorted pair of the two DT vertices as
sorting key)
2) for each triangulation vertex, create its dual cell and for all
finite incident edges, associate the dual faces of the dual cell
3) create dual vertex of each triangulation cell and maintain the
mapping
3) for each triangulation edge, consider all incident_cells to
get the dual vertices of a dual face.
4) for each triangulation cell, consider its neighbor cells to
set the adjacencies between dual vertices.
main doc pages:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3--Cell.html
Triangulation::incident_cells( Edge )
Triangulation::finite_incident_edges ( Vertex_handle , OutputIterator )
Cell::neighbor(int)
S.
If possible I'd like to keep this structure, because some other code depends
on it.
However, the main goal is to make the extraction of the Voronoi diagram
faster.
I would appreciate any ideas or pointers (not the C ones ;)).
Thanks,
Daniel
- [cgal-discuss] Extracting Voronoi diagram from Regular_triangulation_3, randooom, 12/01/2010
- [cgal-discuss] Re: Extracting Voronoi diagram from Regular_triangulation_3, randooom, 12/01/2010
- Re: [cgal-discuss] Re: Extracting Voronoi diagram from Regular_triangulation_3, Bernhard Kornberger, 12/02/2010
- [cgal-discuss] Re: Extracting Voronoi diagram from Regular_triangulation_3, randooom, 12/02/2010
- Re: [cgal-discuss] Extracting Voronoi diagram from Regular_triangulation_3, Sebastien Loriot (GeometryFactory), 12/02/2010
