- To:
- Subject: Re: [cgal-discuss] hatch fill
- Date: Fri, 03 Dec 2010 17:49:03 +0100
Bellini wrote:
Hello Sebastien...I assume your polygon is simple.
I'm trying to fill a (maybe concave) polygon using a set of vectors with
the
same direction; it's like a raster flood fill but done with vectors...
I'll use it, for example, for fill glyphs of a truetype font using a plotter
(not a printer) as output device.
thanks for your interest
Giampaolo
A simple solution (but maybe not the most efficient one) is to use the following strategy.
Consider your polygon as a set of segments, and consider a set of lines
defining the "hatching lines". For each line, compute the intersection between the set of segments using a sweep line algorithm. For each line,
you always have an even number of points to connect together to have
your internal segments.
For this you can use the function compute_intersection_points documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Sweep_line_2_ref/Function_compute_intersection_points.html#Index_anchor_1549
and using the traits class Arr_linear_traits_2 (used to get Curve_2
type)
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_linear_traits_2.html#Cross_link_anchor_1213
Points will be reported in an increasing xy-lexicographical order, so
you can directly "linked" them by pair.
The boolean report_endpoints should be set to false.
An example is presented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Sweep_line_2/Chapter_main.html
If your polygon is convex, you can directly compute the intersection between all the segments and all the lines.
Have a look here to see how to get a decomposition of your polygon in convex regions (if you use this you will have extra points in the interior of the polygon):
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Partition_2/Chapter_main.html
Notice that in the case a line go through a segment endpoint you have to
tweak a bit.
S.
- [cgal-discuss] hatch fill, Giampaolo Bellini, 12/03/2010
- Re: [cgal-discuss] hatch fill, Sebastien Loriot (GeometryFactory), 12/03/2010
- Re: Re: [cgal-discuss] hatch fill, Bellini, 12/03/2010
