cgal-discuss - Re: [cgal-discuss] make_surface_mesh produces degenerate triangles
  • To:
  • Subject: Re: [cgal-discuss] make_surface_mesh produces degenerate triangles
  • Date: Fri, 03 Dec 2010 13:24:22 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=dk7kUGG8oDA0MtyHT4Qp+E6HOvuLVOWlOfOSAbms6dOYbBDkF8xE6UHRyKQsXh0a4B gIBvH+Ad7aHi5yrgHv9o7JrbKfy0bxigbZdvGz4pfKX2jGh1N0cDnC4f46PrA6sUKAET TofQWHt7HA1G7VEy0atyu8vPtqmDhu/37tuQI=
On 12/3/10 11:02 AM, Laurent Rineau (GeometryFactory) wrote:
Your data set has a sharp edge. The Surface Mesh Generator of CGAL do not
handle sharp edges properly.
Losen the third parameter of your CGAL::Surface_mesh_default_criteria_3<Tr>
object, so that the sharp edge is approximated with bigger triangles.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher_ref/Class_Surface_mesh_default_criteria_3.html
Thanks for explanation.
But why it works most of the time and fails at other time ?
Is this related to random number generator's seed ? (http://bit.ly/dJZL6K)
It should not. The one of the example should be correct.
Is it possible to change the kernel it's using to something else or I have to write my own '
Surface_mesh_triangulation_3' ?
