- To:
- Subject: Re: [cgal-discuss] Re: Bezier curve arrangement error
- Date: Thu, 09 Dec 2010 10:56:42 +0100
Hello Gene,
Can you try the following patched file and tell us whether it solves
your problem?
(you must replace the one in include/CGAL/Arr_geometry_traits or change
the include path to use this one instead).
S.
the diff is:
CGAL-3.7/include/CGAL/Arr_geometry_traits/Bezier_x_monotone_2.h 2010-08-02 21:00:11.000000000 +0200
@@ -1741,7 +1741,7 @@
if (CGAL::sign (denom1) == CGAL::ZERO)
- inf_slope1 = CGAL::sign (numer1);
+ inf_slope1 = is_directed_right() ? CGAL::sign (numer1) :
+ CGAL::opposite( CGAL::sign (numer1) );
// If both derivatives are zero, we cannot perform the comparison:
if (inf_slope1 == CGAL::ZERO)
@@ -1764,7 +1764,7 @@
if (CGAL::sign (denom2) == CGAL::ZERO)
- inf_slope2 = CGAL::sign (numer2);
+ inf_slope2 = cv.is_directed_right() ? CGAL::sign (numer2) :
+ CGAL::opposite( CGAL::sign (numer2) );
if (inf_slope2 == CGAL::ZERO)
Gene wrote:
Thanks, using version 3.7, the error no longer appears. However, this
example came from a larger data set that gives a different error
now--one which is harder to localize. Therefore, I have included the
larger dataset along with a new test program.
The error I get is:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: ! _predP->is_valid() || comp_f(object, _predP->object) != SMALLER
File: /usr/local/include/CGAL/Multiset.h
Line: 2142
Abort
The error only appears if I load the curves using the iterator version
of `insert'. When I load the curves one at a time, it USUALLY works,
but sometimes I get the following error:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: CGAL::compare (pt_org->point_bound().t_max,
ps_org->point_bound().t_min) == SMALLER
File: /usr/local/include/CGAL/Arr_geometry_traits/Bezier_x_monotone_2.h
Line: 2564
Abort
When this error appears, it is not attached to a specific point, but
it may appear at different times during loading. Obviously, it's
disturbing that it only appears sometimes and not all the time.
http://cgal-discuss.949826.n4.nabble.com/file/n3067817/test_curve2.cpp
test_curve2.cpp http://cgal-discuss.949826.n4.nabble.com/file/n3067817/curves.dat curves.dat http://cgal-discuss.949826.n4.nabble.com/file/n3067817/arr_print.h
arr_print.h
// Copyright (c) 2006 Tel-Aviv University (Israel). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Bezier_x_monotone_2.h $ // $Id: Bezier_x_monotone_2.h 57724 2010-08-02 14:53:10Z lrineau $ // // // Author(s) : Ron Wein <> // Iddo Hanniel <> #ifndef CGAL_BEZIER_X_MONOTONE_2_H #define CGAL_BEZIER_X_MONOTONE_2_H /*! \file * Header file for the _Bezier_x_monotone_2 class. */ #include <CGAL/Arr_geometry_traits/Bezier_curve_2.h> #include <CGAL/Arr_geometry_traits/Bezier_point_2.h> #include <CGAL/Arr_geometry_traits/Bezier_cache.h> #include <ostream> namespace CGAL { /*! \class * Representation of an x-monotone Bezier subcurve, specified by a Bezier curve * and two end points. */ template <class Rat_kernel_, class Alg_kernel_, class Nt_traits_, class Bounding_traits_> class _Bezier_x_monotone_2 { public: typedef Rat_kernel_ Rat_kernel; typedef Alg_kernel_ Alg_kernel; typedef Nt_traits_ Nt_traits; typedef Bounding_traits_ Bounding_traits; typedef _Bezier_curve_2<Rat_kernel, Alg_kernel, Nt_traits, Bounding_traits> Curve_2; typedef _Bezier_point_2<Rat_kernel, Alg_kernel, Nt_traits, Bounding_traits> Point_2; typedef _Bezier_x_monotone_2<Rat_kernel, Alg_kernel, Nt_traits, Bounding_traits> Self; typedef _Bezier_cache<Nt_traits> Bezier_cache; private: typedef typename Alg_kernel::Point_2 Alg_point_2; typedef typename Rat_kernel::Point_2 Rat_point_2; typedef typename Nt_traits::Integer Integer; typedef typename Nt_traits::Rational Rational; typedef typename Nt_traits::Algebraic Algebraic; typedef typename Nt_traits::Polynomial Polynomial; typedef typename Point_2::Originator Originator; typedef typename Point_2::Originator_iterator Originator_iterator; typedef typename Bounding_traits::Bez_point_bound Bez_point_bound; typedef typename Bounding_traits::Bez_point_bbox Bez_point_bbox; // Type definition for the vertical tangency-point mapping. typedef typename Bezier_cache::Curve_id Curve_id; typedef std::pair<Curve_id, Curve_id> Curve_pair; typedef typename Bezier_cache::Vertical_tangency_list Vert_tang_list; typedef typename Bezier_cache::Vertical_tangency_iter Vert_tang_iter; // Type definition for the intersection-point mapping. typedef typename Bezier_cache::Intersection_list Intersect_list; typedef typename Bezier_cache::Intersection_iter Intersect_iter; // Representation of an intersection point with its multiplicity: typedef std::pair<Point_2, unsigned int> Intersection_point_2; /*! \class Less_intersection_point * Comparison functor for intersection points. */ class Less_intersection_point { private: Bezier_cache *p_cache; public: Less_intersection_point (Bezier_cache& cache) : p_cache (&cache) {} bool operator() (const Intersection_point_2& ip1, const Intersection_point_2& ip2) const { // Use an xy-lexicographic comparison. return (ip1.first.compare_xy (ip2.first, *p_cache) == SMALLER); } }; // Type definition for the bounded intersection-point mapping. typedef std::list<Point_2> Intersection_list; /*! \struct Less_curve_pair * An auxiliary functor for comparing a pair of curve IDs. */ struct Less_curve_pair { bool operator() (const Curve_pair& cp1, const Curve_pair& cp2) const { // Compare the pairs of IDs lexicographically. return (cp1.first < cp2.first || (cp1.first == cp2.first && cp1.second < cp2.second)); } }; /*! \struct Subcurve * For the usage of the _exact_vertical_position() function. */ struct Subcurve { std::list<Rat_point_2> control_points; Rational t_min; Rational t_max; /*! Get the rational bounding box of the subcurve. */ void bbox (Rational& x_min, Rational& y_min, Rational& x_max, Rational& y_max) const { typename std::list<Rat_point_2>::const_iterator pit = control_points.begin(); CGAL_assertion (pit != control_points.end()); x_min = x_max = pit->x(); y_min = y_max = pit->y(); for (++pit; pit != control_points.end(); ++pit) { if (CGAL::compare (x_min, pit->x()) == LARGER) x_min = pit->x(); else if (CGAL::compare (x_max, pit->x()) == SMALLER) x_max = pit->x(); if (CGAL::compare (y_min, pit->y()) == LARGER) y_min = pit->y(); else if (CGAL::compare (y_max, pit->y()) == SMALLER) y_max = pit->y(); } return; } }; public: typedef std::map<Curve_pair, Intersection_list, Less_curve_pair> Intersection_map; typedef typename Intersection_map::value_type Intersection_map_entry; typedef typename Intersection_map::iterator Intersection_map_iterator; private: // Data members: Curve_2 _curve; /*!< The supporting Bezier curve. */ unsigned int _xid; /*!< The serial number of the basic x-monotone subcurve of the Bezier curve. */ Point_2 _ps; /*!< The source point. */ Point_2 _pt; /*!< The target point. */ bool _dir_right; /*!< Is the subcurve directed right (or left). */ bool _inc_to_right; /*!< Does the parameter value increase when traversing the subcurve from left to right. */ bool _is_vert; /*!< Is the subcurve a vertical segment. */ public: /*! Default constructor. */ _Bezier_x_monotone_2 () : _xid(0), _dir_right (false), _is_vert (false) {} /*! * Constructor given two endpoints. * \param B The supporting Bezier curve. * \param xid The serial number of the x-monotone subcurve with respect to * the parameter range of the Bezier curve. * For example, if B is split to two x-monotone subcurves at t', * the subcurve defined over [0, t'] has a serial number 1, * and the other, defined over [t', 1] has a serial number 2. * \param ps The source point. * \param pt The target point. * \param cache Caches the vertical tangency points and intersection points. * \pre B should be an originator of both ps and pt. * \pre xid is a non-zero serial number. */ _Bezier_x_monotone_2 (const Curve_2& B, unsigned int xid, const Point_2& ps, const Point_2& pt, Bezier_cache& cache); /*! * Get the supporting Bezier curve. */ const Curve_2& supporting_curve () const { return (_curve); } /*! * Get the x-monotone ID of the curve. */ unsigned int xid () const { return (_xid); } /*! * Get the source point. */ const Point_2& source () const { return (_ps); } /*! * Get the target point. */ const Point_2& target () const { return (_pt); } /*! * Get the left endpoint (the lexicographically smaller one). */ const Point_2& left () const { return (_dir_right ? _ps : _pt); } /*! * Get the right endpoint (the lexicographically larger one). */ const Point_2& right () const { return (_dir_right ? _pt : _ps); } /*! * Check if the subcurve is a vertical segment. */ bool is_vertical () const { return (_is_vert); } /*! * Check if the subcurve is directed from left to right. */ bool is_directed_right () const { return (_dir_right); } /*! * Get the approximate parameter range defining the curve. * \return A pair of t_src and t_trg, where B(t_src) is the source point * and B(t_trg) is the target point. */ std::pair<double, double> parameter_range () const; /*! * Get the relative position of the query point with respect to the subcurve. * \param p The query point. * \param cache Caches the vertical tangency points and intersection points. * \pre p is in the x-range of the arc. * \return SMALLER if the point is below the arc; * LARGER if the point is above the arc; * EQUAL if p lies on the arc. */ Comparison_result point_position (const Point_2& p, Bezier_cache& cache) const; /*! * Compare the relative y-position of two x-monotone subcurve to the right * of their intersection point. * \param cv The other subcurve. * \param p The intersection point. * \param cache Caches the vertical tangency points and intersection points. * \pre p is incident to both subcurves, and both are defined to its right. * \return SMALLER if (*this) lies below cv to the right of p; * EQUAL in case of an overlap (should not happen); * LARGER if (*this) lies above cv to the right of p. */ Comparison_result compare_to_right (const Self& cv, const Point_2& p, Bezier_cache& cache) const; /*! * Compare the relative y-position of two x-monotone subcurve to the left * of their intersection point. * \param cv The other subcurve. * \param p The intersection point. * \param cache Caches the vertical tangency points and intersection points. * \pre p is incident to both subcurves, and both are defined to its left. * \return SMALLER if (*this) lies below cv to the right of p; * EQUAL in case of an overlap (should not happen); * LARGER if (*this) lies above cv to the right of p. */ Comparison_result compare_to_left (const Self& cv, const Point_2& p, Bezier_cache& cache) const; /*! * Check whether the two subcurves are equal (have the same graph). * \param cv The other subcurve. * \param cache Caches the vertical tangency points and intersection points. * \return (true) if the two subcurves have the same graph; * (false) otherwise. */ bool equals (const Self& cv, Bezier_cache& cache) const; /*! * Compute the intersections with the given subcurve. * \param cv The other subcurve. * \param inter_map Caches the bounded intersection points. * \param cache Caches the vertical tangency points and intersection points. * \param oi The output iterator. * \return The past-the-end iterator. */ template<class OutputIterator> OutputIterator intersect (const Self& cv, Intersection_map& inter_map, Bezier_cache& cache, OutputIterator oi) const { // In case we have two x-monotone subcurves of the same Bezier curve, // check if they have a common left endpoint. if (_curve.is_same (cv._curve)) { if (left().is_same (cv.left()) || left().is_same (cv.right())) { *oi = CGAL::make_object (Intersection_point_2 (left(), 0)); ++oi; } } // Compute the intersections of the two sucurves. Note that for caching // purposes we always apply the _intersect() function on the subcurve whose // curve ID is smaller. std::vector<Intersection_point_2> ipts; Self ovlp_cv; bool do_ovlp; if (_curve.id() <= cv._curve.id()) do_ovlp = _intersect (cv, inter_map, cache, ipts, ovlp_cv); else do_ovlp = cv._intersect (*this, inter_map, cache, ipts, ovlp_cv); // In case of overlap, just report the overlapping subcurve. if (do_ovlp) { *oi = CGAL::make_object (ovlp_cv); ++oi; return (oi); } // If we have a set of intersection points, sort them in ascending // xy-lexicorgraphical order, and insert them to the output iterator. typename std::vector<Intersection_point_2>::const_iterator ip_it; std::sort (ipts.begin(), ipts.end(), Less_intersection_point (cache)); for (ip_it = ipts.begin(); ip_it != ipts.end(); ++ip_it) { *oi = CGAL::make_object (*ip_it); ++oi; } // In case we have two x-monotone subcurves of the same Bezier curve, // check if they have a common right endpoint. if (_curve.is_same (cv._curve)) { if (right().is_same (cv.left()) || right().is_same (cv.right())) { *oi = CGAL::make_object (Intersection_point_2 (right(), 0)); ++oi; } } return (oi); } /*! * Split the subcurve into two at a given split point. * \param p The split point. * \param c1 Output: The first resulting arc, lying to the left of p. * \param c2 Output: The first resulting arc, lying to the right of p. * \pre p lies in the interior of the subcurve (not one of its endpoints). */ void split (const Point_2& p, Self& c1, Self& c2) const; /*! * Check if the two subcurves are mergeable. * \param cv The other subcurve. * \return Whether the two subcurves can be merged. */ bool can_merge_with (const Self& cv) const; /*! * Merge the current arc with the given arc. * \param cv The other subcurve. * \pre The two arcs are mergeable. * \return The merged arc. */ Self merge (const Self& cv) const; /*! * Flip the subcurve (swap its source and target points). * \return The flipped subcurve. */ Self flip () const { // Note that we just swap the source and target of the original subcurve // and do not touch the supporting Beizer curve. Self cv = *this; cv._ps = this->_pt; cv._pt = this->_ps; cv._dir_right = ! this->_dir_right; return (cv); } private: /*! * Check if the given t-value is in the range of the subcurve. * \param t The parameter value. * \param cache Caches the vertical tangency points and intersection points. * \return If t in the parameter-range of the subcurve. */ bool _is_in_range (const Algebraic& t, Bezier_cache& cache) const; /*! * Check if the given point lies in the range of this x-monotone subcurve. * \param p The point, which lies on the supporting Bezier curve. * \param is_certain Output: Is the answer we provide is certain. * \return Whether p is on the x-monotone subcurve. */ bool _is_in_range (const Point_2& p, bool& is_certain) const; /*! * Given a point p that lies on the supporting Bezier curve (X(t), Y(t)), * determine whether p lies within the t-range of the x-monotone subcurve. * If so, the value t0 such that p = (X(t0), Y(t0)) is also computed. * \param p The point, which lies on the supporting Bezier curve. * \param cache Caches the vertical tangency points and intersection points. * \param t0 Output: A parameter value such that p = (X(t0), Y(t0)). * \param is_endpoint Output: Whether p equals on the of the endpoints. * \return Whether p lies in the t-range of the subcurve. */ bool _is_in_range (const Point_2& p, Bezier_cache& cache, Algebraic& t0, bool& is_endpoint) const; /*! * Compute a y-coordinate of a point on the x-monotone subcurve with a * given x-coordinate. * \param x0 The given x-coodinate. * \param cache Caches the vertical tangency points and intersection points. * \return The y-coordinate. */ Algebraic _get_y (const Rational& x0, Bezier_cache& cache) const; /*! * Compare the slopes of the subcurve with another given Bezier subcurve at * their given intersection point. * \param cv The other subcurve. * \param p The intersection point. * \param cache Caches the vertical tangency points and intersection points. * \pre p lies of both subcurves. * \pre Neither of the subcurves is a vertical segment. * \return SMALLER if (*this) slope is less than cv's; * EQUAL if the two slopes are equal; * LARGER if (*this) slope is greater than cv's. */ Comparison_result _compare_slopes (const Self& cv, const Point_2& p, Bezier_cache& cache) const; /*! * Get the range of t-value over which the subcurve is defined. * \param cache Caches the vertical tangency points and intersection points. * \return A pair comprised of the t-value for the source point and the * t-value for the target point. */ std::pair<Algebraic, Algebraic> _t_range (Bezier_cache& cache) const; /*! * Compare the relative y-position of two x-monotone subcurve to the right * (or to the left) of their intersection point, whose multiplicity is * greater than 1. * \param cv The other subcurve. * \param p The query point. * \param to_right Should we compare to p's right or to p's left. * \param cache Caches the vertical tangency points and intersection points. * \pre The x-coordinate of the right endpoint of *this is smaller than * (or equal to) the x-coordinate of the right endpoint of cv. * \pre p is a common point of both subcurves. * \pre Neither of the subcurves is a vertical segment. * \return SMALLER if (*this) lies below cv next to p; * EQUAL in case of an overlap (should not happen); * LARGER if (*this) lies above cv next to p. */ Comparison_result _compare_to_side (const Self& cv, const Point_2& p, bool to_right, Bezier_cache& cache) const; /*! * Clip the control polygon of the supporting Bezier curve such that it * fits the current x-monotone subcurve. * \param ctrl Output: The clipped control polygon. * \param t_min Output: The minimal t-value of the clipped curve. * \param t_max Output: The maximal t-value of the clipped curve. */ void _clip_control_polygon (typename Bounding_traits::Control_points& ctrl, typename Bounding_traits::NT& t_min, typename Bounding_traits::NT& t_max) const; /*! * Approximate the intersection points between the supporting Bezier curves * of the given x-monotone curves. * \param cv The x-monotone curve we intersect. * \param inter_pts Output: An output list of intersection points between * the supporting Bezier curves. * In case (*this) and cv are subcurve of the same * Bezier curve, only the self-intersection points * between the subcurves are approximated. * \return Whether all intersection points where successfully approximated. */ bool _approximate_intersection_points (const Self& cv, std::list<Point_2>& inter_pts) const; /*! * Compute the intersections with the given subcurve. * \param cv The other subcurve. * \param inter_map Caches the bounded intersection points. * \param cache Caches the vertical tangency points and intersection points. * \param ipts Output: A vector of intersection points + multiplicities. * \param ovlp_cv Output: An overlapping subcurve (if exists). * \return Whether an overlap has occured. */ bool _intersect (const Self& cv, Intersection_map& inter_map, Bezier_cache& cache, std::vector<Intersection_point_2>& ipts, Self& ovlp_cv) const; /*! * Compute the exact vertical position of the given point with respect to * the x-monotone curve. * \param p The point. * \param force_exact Sould we force an exact result. * \return SMALLER if the point is below the curve; * LARGER if the point is above the curve; * EQUAL if p lies on the curve. */ Comparison_result _exact_vertical_position (const Point_2& p, bool force_exact) const; }; /*! * Exporter for Bezier curves. */ template <class Rat_kernel, class Alg_kernel, class Nt_traits, class Bounding_traits> std::ostream& operator<< (std::ostream& os, const _Bezier_x_monotone_2<Rat_kernel, Alg_kernel, Nt_traits, Bounding_traits>& cv) { os << cv.supporting_curve() << " [" << cv.xid() << "] | " << cv.source() << " --> " << cv.target(); return (os); } // --------------------------------------------------------------------------- // Constructor given two endpoints. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_Bezier_x_monotone_2 (const Curve_2& B, unsigned int xid, const Point_2& ps, const Point_2& pt, Bezier_cache& cache) : _curve (B), _xid (xid), _ps (ps), _pt (pt), _is_vert (false) { CGAL_precondition (xid > 0); // Get the originators of the point that correspond to the curve B. Originator_iterator ps_org = ps.get_originator (B, _xid); CGAL_precondition (ps_org != ps.originators_end()); Originator_iterator pt_org = pt.get_originator (B, _xid); CGAL_precondition (pt_org != pt.originators_end()); // Check if the subcurve is directed left or right. const Comparison_result res = _ps.compare_x (_pt, cache); if (res == EQUAL) { // We have a vertical segment. Check if the source is below the target. _is_vert = true; _dir_right = (CGAL::compare (_ps.y(), _pt.y()) == SMALLER); } else { _dir_right = (res == SMALLER); } // Check if the value of the parameter t increases when we traverse the // curve from left to right: If the curve is directed to the right, we // check if t_src < t_trg, otherwise we check whether t_src > t_trg. Comparison_result t_res; if (CGAL::compare (ps_org->point_bound().t_max, pt_org->point_bound().t_min) == SMALLER || CGAL::compare (ps_org->point_bound().t_min, pt_org->point_bound().t_max) == LARGER) { // Perform the comparison assuming that the possible parameter // values do not overlap. t_res = CGAL::compare (ps_org->point_bound().t_min, pt_org->point_bound().t_min); } else { // In this case both exact parameter values must be known. // We use them to perform an exact comparison. CGAL_assertion (ps_org->has_parameter() && pt_org->has_parameter()); t_res = CGAL::compare (ps_org->parameter(), pt_org->parameter()); } CGAL_precondition (t_res != EQUAL); if (_dir_right) _inc_to_right = (t_res == SMALLER); else _inc_to_right = (t_res == LARGER); } // --------------------------------------------------------------------------- // Get the approximate parameter range defining the curve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> std::pair<double, double> _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::parameter_range () const { // First try to use the approximate representation of the endpoints. Originator_iterator s_org = _ps.get_originator (_curve, _xid); CGAL_assertion (s_org != _ps.originators_end()); Originator_iterator t_org = _pt.get_originator (_curve, _xid); CGAL_assertion (t_org != _pt.originators_end()); double t_src = (CGAL::to_double (s_org->point_bound().t_min) + CGAL::to_double (s_org->point_bound().t_max)) / 2; double t_trg = (CGAL::to_double (t_org->point_bound().t_min) + CGAL::to_double (t_org->point_bound().t_max)) / 2; return (std::make_pair (t_src, t_trg)); } // --------------------------------------------------------------------------- // Get the relative position of the query point with respect to the subcurve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::point_position (const Point_2& p, Bezier_cache& cache) const { if (p.identical(_ps)) { return EQUAL; } // First check whether p has the same x-coordinate as one of the endpoints. const Comparison_result res1 = p.compare_x (_ps, cache); if (res1 == EQUAL) { // In this case both points must be exact. CGAL_assertion (p.is_exact() && _ps.is_exact()); // If both point are rational, compare their rational y-coordinates. if (p.is_rational() && _ps.is_rational()) { const Rat_point_2& rat_p = (Rat_point_2) p; const Rat_point_2& rat_ps = (Rat_point_2) _ps; return (CGAL::compare (rat_p.y(), rat_ps.y())); } // Compare the algebraic y-coordinates. return (CGAL::compare (p.y(), _ps.y())); } if (p.identical(_pt)) { return EQUAL; } const Comparison_result res2 = p.compare_x (_pt, cache); if (res2 == EQUAL) { // In this case both points must be exact. CGAL_assertion (p.is_exact() && _pt.is_exact()); // If both point are rational, compare their rational y-coordinates. if (p.is_rational() && _pt.is_rational()) { const Rat_point_2& rat_p = (Rat_point_2) p; const Rat_point_2& rat_pt = (Rat_point_2) _pt; return (CGAL::compare (rat_p.y(), rat_pt.y())); } // Compare the algebraic y-coordinates. return (CGAL::compare (p.y(), _pt.y())); } // Make sure that p is in the x-range of our subcurve. CGAL_precondition (res1 != res2); // Check for the case when curve is an originator of the point. Originator_iterator p_org = p.get_originator (_curve, _xid); if (p_org != p.originators_end()) { Originator_iterator ps_org = _ps.get_originator (_curve, _xid); CGAL_assertion (ps_org != _ps.originators_end()); Originator_iterator pt_org = _pt.get_originator (_curve, _xid); CGAL_assertion (pt_org != _pt.originators_end()); // Check if the point is in the parameter range of this subcurve. // First try an approximate check of the parameter bounds. bool correct_res; bool in_range = false; in_range = _is_in_range (p, correct_res); if (! correct_res) { // Perform the comparsion in an exact manner. if (! p.is_exact()) p.make_exact (cache); CGAL_assertion (p_org->has_parameter()); in_range = _is_in_range (p_org->parameter(), cache); } if (in_range) return (EQUAL); } // Call the vertical-position function that uses the bounding-boxes // to evaluate the comparsion result. typename Bounding_traits::Control_points cp; std::copy (_curve.control_points_begin(), _curve.control_points_end(), std::back_inserter(cp)); Originator_iterator ps_org = _ps.get_originator (_curve, _xid); CGAL_assertion (ps_org != _ps.originators_end()); Originator_iterator pt_org = _pt.get_originator (_curve, _xid); CGAL_assertion (pt_org != _pt.originators_end()); Comparison_result res_bound = EQUAL; typename Bounding_traits::NT x_min, y_min, x_max, y_max; bool can_refine; p.get_bbox (x_min, y_min, x_max, y_max); if (CGAL::compare (ps_org->point_bound().t_max, pt_org->point_bound().t_min) == SMALLER) { // Examine the parameter range of the originator of the source point // with respect to the current subcurve B, and make sure that B(t_max) // lies to the left of p if the curve is directed from left to right // (or to the right of p, if the subcurve is directed from right to left). can_refine = ! _ps.is_exact(); do { const Rat_point_2& ps = _curve (ps_org->point_bound().t_max); if ((_dir_right && CGAL::compare (ps.x(), x_min) != LARGER) || (! _dir_right && CGAL::compare (ps.x(), x_max) != SMALLER)) break; if (can_refine) can_refine = _ps.refine(); } while (can_refine); // Examine the parameter range of the originator of the target point // with respect to the current subcurve B, and make sure that B(t_min) // lies to the right of p if the curve is directed from left to right // (or to the left of p, if the subcurve is directed from right to left). can_refine = ! _pt.is_exact(); do { const Rat_point_2& pt = _curve (pt_org->point_bound().t_min); if ((_dir_right && CGAL::compare (pt.x(), x_max) != SMALLER) || (! _dir_right && CGAL::compare (pt.x(), x_min) != LARGER)) break; if (can_refine) can_refine = _pt.refine(); } while (can_refine); // In this case the parameter value of the source is smaller than the // target's, so we compare the point with the subcurve of B defined over // the proper parameter range. res_bound = p.vertical_position (cp, ps_org->point_bound().t_max, pt_org->point_bound().t_min); } else if (CGAL::compare (pt_org->point_bound().t_max, ps_org->point_bound().t_min) == SMALLER) { // Examine the parameter range of the originator of the source point // with respect to the current subcurve B, and make sure that B(t_min) // lies to the left of p if the curve is directed from left to right // (or to the right of p, if the subcurve is directed from right to left). can_refine = ! _ps.is_exact(); do { const Rat_point_2& ps = _curve (ps_org->point_bound().t_min); if ((_dir_right && CGAL::compare (ps.x(), x_min) != LARGER) || (! _dir_right && CGAL::compare (ps.x(), x_max) != SMALLER)) break; if (can_refine) can_refine = _ps.refine(); } while (can_refine); // Examine the parameter range of the originator of the target point // with respect to the current subcurve B, and make sure that B(t_max) // lies to the right of p if the curve is directed from left to right // (or to the left of p, if the subcurve is directed from right to left). can_refine = ! _pt.is_exact(); do { const Rat_point_2& pt = _curve (pt_org->point_bound().t_max); if ((_dir_right && CGAL::compare (pt.x(), x_max) != SMALLER) || (! _dir_right && CGAL::compare (pt.x(), x_min) != LARGER)) break; if (can_refine) can_refine = _pt.refine(); } while (can_refine); // In this case the parameter value of the source is large than the // target's, so we compare the point with the subcurve of B defined over // the proper parameter range. res_bound = p.vertical_position (cp, pt_org->point_bound().t_max, ps_org->point_bound().t_min); } if (res_bound != EQUAL) return (res_bound); // In this case we have to switch to exact computations and check whether // p lies of the given subcurve. We take one of p's originating curves and // compute its intersections with our x-monotone curve. if (! p.is_exact()) p.make_exact (cache); CGAL_assertion (p.originators_begin() != p.originators_end()); // \todo If the point is a rational point (e.g., ray shooting) // use comparison between Y(root_of(X0-X(t))) and Y0. Originator org = *(p.originators_begin()); bool do_ovlp; bool swap_order = (_curve.id() > org.curve().id()); const Intersect_list& inter_list = (! swap_order ? (cache.get_intersections (_curve.id(), _curve.x_polynomial(), _curve.x_norm(), _curve.y_polynomial(), _curve.y_norm(), org.curve().id(), org.curve().x_polynomial(), org.curve().x_norm(), org.curve().y_polynomial(), org.curve().y_norm(), do_ovlp)) : (cache.get_intersections (org.curve().id(), org.curve().x_polynomial(), org.curve().x_norm(), org.curve().y_polynomial(), org.curve().y_norm(), _curve.id(), _curve.x_polynomial(), _curve.x_norm(), _curve.y_polynomial(), _curve.y_norm(), do_ovlp))); if (do_ovlp) return (EQUAL); // Go over the intersection points and look for p there. Intersect_iter iit; for (iit = inter_list.begin(); iit != inter_list.end(); ++iit) { // Get the parameter of the originator and compare it to p's parameter. const Algebraic& s = swap_order ? iit->s : iit->t; if (CGAL::compare (s, org.parameter()) == EQUAL) { // Add this curve as an originator for p. const Algebraic& t = swap_order ? iit->t : iit->s; CGAL_assertion (_is_in_range (t, cache)); Point_2& pt = const_cast<Point_2&> (p); pt.add_originator (Originator (_curve, _xid, t)); // The point p lies on the subcurve. return (EQUAL); } } // We now know that p is not on the subcurve. We therefore subdivide the // curve using exact rational arithmetic, until we reach a separation // between the curve and the point. (This case should be very rare.) // Note that we first try to work with inexact endpoint representation, and // only if we fail we make the endpoints of the x-monotone curves exact. if (! p.is_exact()) p.make_exact (cache); Comparison_result exact_res = _exact_vertical_position (p, false); if (exact_res != EQUAL) return (exact_res); if (! _ps.is_exact()) _ps.make_exact (cache); if (! _pt.is_exact()) _pt.make_exact (cache); return (_exact_vertical_position (p, true)); } // --------------------------------------------------------------------------- // Compare the relative y-position of two x-monotone subcurves to the right // of their intersection point. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::compare_to_right (const Self& cv, const Point_2& p, Bezier_cache& cache) const { CGAL_precondition (p.compare_xy (right(), cache) != LARGER); CGAL_precondition (p.compare_xy (cv.right(), cache) != LARGER); if (this == &cv) return (EQUAL); // Make sure that p is incident to both curves (either equals the left // endpoint or lies in the curve interior). Note that this is important to // carry out these tests, as it assures us the eventually both curves are // originators of p. if (! p.equals (left(), cache)) { if (point_position (p, cache) != EQUAL) { CGAL_precondition_msg (false, "p is not on cv1"); } } if (! p.equals (cv.left(), cache)) { if (cv.point_position (p, cache) != EQUAL) { CGAL_precondition_msg (false, "p is not on cv2"); } } // Check for vertical subcurves. A vertical segment is above any other // x-monotone subcurve to the right of their common endpoint. if (is_vertical()) { if (cv.is_vertical()) // Both are vertical segments with a common endpoint, so they overlap: return (EQUAL); return (LARGER); } else if (cv.is_vertical()) { return (SMALLER); } // Check if both subcurves originate from the same Bezier curve. Nt_traits nt_traits; if (_curve.is_same (cv._curve)) { // Get the originator, and check whether p is a vertical tangency // point of this originator (otherwise it is a self-intersection point, // and we proceed as if it is a regular intersection point). Originator_iterator org = p.get_originator(_curve, _xid); CGAL_assertion (org != p.originators_end()); if (org->point_bound().type == Bez_point_bound::VERTICAL_TANGENCY_PT) { CGAL_assertion (_inc_to_right != cv._inc_to_right); if (! p.is_exact()) { // Comparison based on the control polygon of the bounded vertical // tangency point, using the fact this polygon is y-monotone. const typename Bounding_traits::Control_points& cp = org->point_bound().ctrl; if (_inc_to_right) { return (CGAL::compare (cp.back().y(), cp.front().y())); } else { return (CGAL::compare (cp.front().y(), cp.back().y())); } } // Iddo: Handle rational points (using de Casteljau derivative)? // In this case we know that we have a vertical tangency at t0, so // X'(t0) = 0. We evaluate the sign of Y'(t0) in order to find the // vertical position of the two subcurves to the right of this point. CGAL_assertion (org->has_parameter()); const Algebraic& t0 = org->parameter(); Polynomial polyY_der = nt_traits.derive (_curve.y_polynomial()); const CGAL::Sign sign_der = CGAL::sign (nt_traits.evaluate_at (polyY_der, t0)); CGAL_assertion (sign_der != CGAL::ZERO); if (_inc_to_right) return ((sign_der == CGAL::POSITIVE) ? LARGER : SMALLER); else return ((sign_der == CGAL::NEGATIVE) ? LARGER : SMALLER); } } // Compare the slopes of the two supporting curves at p. In the general // case, the slopes are not equal and their comparison gives us the // vertical order to p's right. Comparison_result slope_res = _compare_slopes (cv, p, cache); if (slope_res != EQUAL) return (slope_res); // Compare the two subcurves by choosing some point to the right of p // and comparing the vertical position there. Comparison_result right_res; if (right().compare_x (cv.right(), cache) != LARGER) { right_res = _compare_to_side (cv, p, true, // Compare to p's right. cache); } else { right_res = cv._compare_to_side (*this, p, true, // Compare to p's right. cache); right_res = CGAL::opposite (right_res); } return (right_res); } // --------------------------------------------------------------------------- // Compare the relative y-position of two x-monotone subcurve to the left // of their intersection point. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::compare_to_left (const Self& cv, const Point_2& p, Bezier_cache& cache) const { CGAL_precondition (p.compare_xy (left(), cache) != SMALLER); CGAL_precondition (p.compare_xy (cv.left(), cache) != SMALLER); if (this == &cv) return (EQUAL); // Make sure that p is incident to both curves (either equals the right // endpoint or lies in the curve interior). Note that this is important to // carry out these tests, as it assures us the eventually both curves are // originators of p. if (! p.equals (right(), cache)) { if (point_position (p, cache) != EQUAL) { CGAL_precondition_msg (false, "p is not on cv1"); } } if (! p.equals (cv.right(), cache)) { if (cv.point_position (p, cache) != EQUAL) { CGAL_precondition_msg (false, "p is not on cv2"); } } // Check for vertical subcurves. A vertical segment is below any other // x-monotone subcurve to the left of their common endpoint. if (is_vertical()) { if (cv.is_vertical()) // Both are vertical segments with a common endpoint, so they overlap: return (EQUAL); return (SMALLER); } else if (cv.is_vertical()) { return (LARGER); } // Check if both subcurves originate from the same Bezier curve. Nt_traits nt_traits; if (_curve.is_same (cv._curve)) { // Get the originator, and check whether p is a vertical tangency // point of this originator (otherwise it is a self-intersection point, // and we proceed as if it is a regular intersection point). Originator_iterator org = p.get_originator (_curve, _xid); CGAL_assertion (org != p.originators_end()); CGAL_assertion (_inc_to_right != cv._inc_to_right); if (org->point_bound().type == Bez_point_bound::VERTICAL_TANGENCY_PT) { if (! p.is_exact()) { // Comparison based on the control polygon of the bounded vertical // tangency point, using the fact this polygon is y-monotone. const typename Bounding_traits::Control_points& cp = org->point_bound().ctrl; if (_inc_to_right) { return (CGAL::compare(cp.front().y(), cp.back().y())); } else { return (CGAL::compare(cp.back().y(), cp.front().y())); } } // Iddo: Handle rational points (using de Casteljau derivative)? // In this case we know that we have a vertical tangency at t0, so // X'(t0) = 0. We evaluate the sign of Y'(t0) in order to find the // vertical position of the two subcurves to the right of this point. CGAL_assertion (org->has_parameter()); const Algebraic& t0 = org->parameter(); Polynomial polyY_der = nt_traits.derive (_curve.y_polynomial()); const CGAL::Sign sign_der = CGAL::sign (nt_traits.evaluate_at (polyY_der, t0)); CGAL_assertion (sign_der != CGAL::ZERO); if (_inc_to_right) return ((sign_der == CGAL::NEGATIVE) ? LARGER : SMALLER); else return ((sign_der == CGAL::POSITIVE) ? LARGER : SMALLER); } } // Compare the slopes of the two supporting curves at p. In the general // case, the slopes are not equal and their comparison gives us the // vertical order to p's right; note that we swap the order of the curves // to obtains their position to the left. Comparison_result slope_res = cv._compare_slopes (*this, p, cache); if (slope_res != EQUAL) return (slope_res); // Compare the two subcurves by choosing some point to the left of p // and compareing the vertical position there. Comparison_result left_res; if (left().compare_x (cv.left(), cache) != SMALLER) { left_res = _compare_to_side (cv, p, false, // Compare to p's left. cache); } else { left_res = cv._compare_to_side (*this, p, false, // Compare to p's left. cache); left_res = CGAL::opposite (left_res); } return (left_res); } // --------------------------------------------------------------------------- // Check whether the two subcurves are equal (have the same graph). // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::equals (const Self& cv, Bezier_cache& cache) const { // Check if the two subcurve have overlapping supporting curves. if (! _curve.is_same (cv._curve)) { // Check whether the two curves have the same support: if (! _curve.has_same_support (cv._curve)) return (false); // Mark that the two curves overlap in the cache. const Curve_id id1 = _curve.id(); const Curve_id id2 = cv._curve.id(); if (id1 < id2) cache.mark_as_overlapping (id1, id2); else cache.mark_as_overlapping (id2, id1); } // Check for equality of the endpoints. return (left().equals (cv.left(), cache) && right().equals (cv.right(), cache)); } // --------------------------------------------------------------------------- // Split the subcurve into two at a given split point. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> void _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::split (const Point_2& p, Self& c1, Self& c2) const { CGAL_precondition (p.get_originator (_curve, _xid) != p.originators_end()); // Duplicate the curve. c1 = c2 = *this; // Perform the split. if (_dir_right) { c1._pt = p; c2._ps = p; } else { c1._ps = p; c2._pt = p; } return; } // --------------------------------------------------------------------------- // Check if the two subcurves are mergeable. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::can_merge_with (const Self& cv) const { // Note that we only allow merging subcurves of the same originating // Bezier curve (overlapping curves will not do in this case). return (_curve.is_same (cv._curve) && _xid == cv._xid && (right().is_same (cv.left()) || left().is_same (cv.right()))); return (false); } // --------------------------------------------------------------------------- // Merge the current arc with the given arc. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Self _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::merge (const Self& cv) const { CGAL_precondition (_curve.is_same (cv._curve)); CGAL_precondition (_xid == cv._xid); Self res = cv; if (right().is_same (cv.left())) { // Extend the subcurve to the right. if (_dir_right) res._pt = cv.right(); else res._ps = cv.right(); } else { CGAL_precondition (left().is_same (cv.right())); // Extend the subcurve to the left. if (_dir_right) res._ps = cv.left(); else res._pt = cv.left(); } return (res); } // --------------------------------------------------------------------------- // Check if the given t-value is in the range of the subcurve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_is_in_range (const Algebraic& t, Bezier_cache& cache) const { // First try to use the approximate representation of the endpoints. Originator_iterator s_org = _ps.get_originator (_curve, _xid); CGAL_assertion (s_org != _ps.originators_end()); Originator_iterator t_org = _pt.get_originator (_curve, _xid); CGAL_assertion (t_org != _pt.originators_end()); Nt_traits nt_traits; bool p_lt_ps = (CGAL::compare (t, nt_traits.convert (s_org->point_bound().t_min)) == SMALLER); bool p_gt_ps = (CGAL::compare (t, nt_traits.convert (s_org->point_bound().t_max)) == LARGER); bool p_lt_pt = (CGAL::compare (t, nt_traits.convert (t_org->point_bound().t_min)) == SMALLER); bool p_gt_pt = (CGAL::compare (t, nt_traits.convert (t_org->point_bound().t_max)) == LARGER); if ((p_gt_ps && p_lt_pt) || (p_lt_ps && p_gt_pt)) { // The point p is definately in the x-range of the subcurve, as its // parameter is between the source and target parameters. return (true); } if ((p_lt_ps && p_lt_pt) || (p_gt_ps && p_gt_pt)) { // The point p is definately not in the x-range of the subcurve, // as its parameter is smaller than both source and target parameter // (or greater than both of them). return (false); } // Obtain the exact t-range of the curve and peform an exact comparison. std::pair<Algebraic, Algebraic> range = _t_range (cache); const Algebraic& t_src = range.first; const Algebraic& t_trg = range.second; const Comparison_result res1 = CGAL::compare (t, t_src); const Comparison_result res2 = CGAL::compare (t, t_trg); return (res1 == EQUAL || res2 == EQUAL || res1 != res2); } // --------------------------------------------------------------------------- // Check if the given point lies in the range of this x-monotone subcurve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_is_in_range (const Point_2& p, bool& is_certain) const { is_certain = true; // Check the easy case that p is one of the subcurve endpoints. if (p.is_same(_ps) || p.is_same(_pt)) return true; // Compare the parameter of p with the parameters of the endpoints. Originator_iterator p_org = p.get_originator (_curve, _xid); if (p_org == p.originators_end()) { CGAL_assertion (p.get_originator (_curve) != p.originators_end()); // In this case a different x-monotone curve of the supporting Bezier // curve is an originator of the point, so we know that p does not // lie in the range of our x-monotone subcurve. return (false); } Originator_iterator s_org = _ps.get_originator (_curve, _xid); CGAL_assertion (s_org != _ps.originators_end()); Originator_iterator t_org = _pt.get_originator (_curve, _xid); CGAL_assertion (t_org != _pt.originators_end()); bool can_refine_p = ! p.is_exact(); bool can_refine_s = ! _ps.is_exact(); bool can_refine_t = ! _pt.is_exact(); while (can_refine_p || can_refine_s || can_refine_t) { bool p_lt_ps = (CGAL::compare (p_org->point_bound().t_max, s_org->point_bound().t_min) == SMALLER); bool p_gt_ps = (CGAL::compare (p_org->point_bound().t_min, s_org->point_bound().t_max) == LARGER); bool p_lt_pt = (CGAL::compare (p_org->point_bound().t_max, t_org->point_bound().t_min) == SMALLER); bool p_gt_pt = (CGAL::compare (p_org->point_bound().t_min, t_org->point_bound().t_max) == LARGER); if ((p_gt_ps && p_lt_pt) || (p_lt_ps && p_gt_pt)) { // The point p is definately in the x-range of the subcurve, as its // parameter is between the source and target parameters. return (true); } if ((p_lt_ps && p_lt_pt) || (p_gt_ps && p_gt_pt)) { // The point p is definately not in the x-range of the subcurve, // as its parameter is smaller than both source and target parameter // (or greater than both of them). return (false); } // Try to refine the points. if (can_refine_p) can_refine_p = p.refine(); if (can_refine_s) can_refine_s = _ps.refine(); if (can_refine_t) can_refine_t = _pt.refine(); } // If we reached here, we do not have a certain answer. is_certain = false; return (false); } // --------------------------------------------------------------------------- // Given a point p that lies on the supporting Bezier curve (X(t), Y(t)), // determine whether p lies within the t-range of the x-monotone subcurve. // If so, the value t0 such that p = (X(t0), Y(t0)) is also computed. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_is_in_range (const Point_2& p, Bezier_cache& cache, Algebraic& t0, bool& is_endpoint) const { // The given point p must be rational, otherwise there is no point checking // whether it lies in the interior of the curve. if (! p.is_rational()) { is_endpoint = false; return (false); } const Rat_point_2& rat_p = (Rat_point_2) p; // Determine the parameter range [t_min, t_max] for our x-monotone // subcurve. std::pair<Algebraic, Algebraic> t_range = _t_range (cache); Algebraic t_min, t_max; if ((_dir_right && _inc_to_right) || (! _dir_right && ! _inc_to_right)) { t_min = t_range.first; t_max = t_range.second; } else { t_min = t_range.second; t_max = t_range.first; } // The given point p must lie on (X(t), Y(t)) for some t-value. Obtain the // parameter value t0 for that point. We start by computing all t-values // such that X(t) equals the x-coordinate of p. Nt_traits nt_traits; std::list<Algebraic> t_vals; typename std::list<Algebraic>::iterator t_iter; Comparison_result res1, res2; Algebraic y0; _curve.get_t_at_x (rat_p.x(), std::back_inserter(t_vals)); CGAL_assertion (! t_vals.empty()); for (t_iter = t_vals.begin(); t_iter != t_vals.end(); ++t_iter) { // Compare the current t-value with t_min. res1 = CGAL::compare (t_min, *t_iter); if (res1 == LARGER) continue; // Make sure the y-coordinates match. y0 = nt_traits.evaluate_at (_curve.y_polynomial(), *t_iter) / nt_traits.convert (_curve.y_norm()); if (CGAL::compare (nt_traits.convert (rat_p.y()), y0) == EQUAL) { if (res1 == EQUAL) { t0 = t_min; is_endpoint = true; return (true); } // Compare the current t-value with t_max. res2 = CGAL::compare (t_max, *t_iter); if (res2 == EQUAL) { t0 = t_max; is_endpoint = true; return (true); } if (res2 == LARGER) { t0 = *t_iter; is_endpoint = false; return (true); } } } // In this case, we have not found a t-value in the range of our subcurve, // so p does not lie on the subcurve: is_endpoint = false; return (false); } // --------------------------------------------------------------------------- // Compute a y-coordinate of a point on the x-monotone subcurve with a // given x-coordinate. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Algebraic _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_get_y (const Rational& x0, Bezier_cache& cache) const { // Obtain the t-values for with the x-coordinates of the supporting // curve equal x0. std::list<Algebraic> t_vals; _curve.get_t_at_x (x0, std::back_inserter(t_vals)); // Find a t-value that is in the range of the current curve. Nt_traits nt_traits; typename std::list<Algebraic>::iterator t_iter; std::pair<Algebraic, Algebraic> t_range = _t_range (cache); const Algebraic& t_src = t_range.first; const Algebraic& t_trg = t_range.second; Comparison_result res1, res2; for (t_iter = t_vals.begin(); t_iter != t_vals.end(); ++t_iter) { res1 = CGAL::compare (*t_iter, t_src); if (res1 == EQUAL) { // Return the y-coordinate of the source point: return (_ps.y()); } res2 = CGAL::compare (*t_iter, t_trg); if (res2 == EQUAL) { // Return the y-coordinate of the source point: return (_pt.y()); } if (res1 != res2) { // We found a t-value in the range of our x-monotone subcurve. // Use this value to compute the y-coordinate. return (nt_traits.evaluate_at (_curve.y_polynomial(), *t_iter) / nt_traits.convert (_curve.y_norm())); } } // If we reached here, x0 is not in the x-range of our subcurve. CGAL_error(); return (0); } // --------------------------------------------------------------------------- // Compare the slopes of the subcurve with another given Bezier subcurve at // their given intersection point. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_compare_slopes (const Self& cv, const Point_2& p, Bezier_cache& cache) const { // Get the originators of p. Originator_iterator org1 = p.get_originator (_curve, _xid); const bool valid_org1 = (org1 != p.originators_end()); Originator_iterator org2 = p.get_originator (cv._curve, cv._xid); const bool valid_org2 = (org2 != p.originators_end()); CGAL_assertion (valid_org1 || valid_org2); // If the point is only approximated, we can carry out a comparison using // an approximate number type. if (valid_org1 && valid_org2 && ! p.is_exact()) { // If the point is inexact, we assume it is a bounded intersection // point of two curves, and therefore the bounding angle these curves // span do not overlap. const Bez_point_bound& bound1 = org1->point_bound(); const Bez_point_bound& bound2 = org2->point_bound(); Bounding_traits bound_tr; return (bound_tr.compare_slopes_at_intersection_point (bound1, bound2)); } // Obtain the parameter values t1 and t2 that correspond to the point p. // Note that it is possible that one of the curves is not an originator // of p. This can happen if p is an endpoint of the other curve (hence // it must be a ratioal point!) and lies in its interior. In this // (degenerate) case we compute the parameter value and set the appropriate // originator for p. Nt_traits nt_traits; Algebraic t1; Algebraic t2; if (valid_org1) { CGAL_assertion (org1->has_parameter()); t1 = org1->parameter(); } else { bool is_endpoint1; CGAL_assertion_code (bool in_range1 =) _is_in_range (p, cache, t1, is_endpoint1); CGAL_assertion (in_range1); p.add_originator (Originator (_curve, _xid, t1)); } if (valid_org2) { CGAL_assertion (org2->has_parameter()); t2 = org2->parameter(); } else { bool is_endpoint2; CGAL_assertion_code (bool in_range2 =) cv._is_in_range (p, cache, t2, is_endpoint2); CGAL_assertion (in_range2); p.add_originator (Originator (cv._curve, cv._xid, t2)); } // The slope of (X(t), Y(t)) at t0 is given by Y'(t0)/X'(t0). // Compute the slope of (*this). // Note that we take special care of the case X'(t0) = 0, when the tangent // is vertical and its slope is +/- oo. Polynomial derivX = nt_traits.derive (_curve.x_polynomial()); Polynomial derivY = nt_traits.derive (_curve.y_polynomial()); Algebraic numer1 = nt_traits.evaluate_at (derivY, t1) * nt_traits.convert (_curve.x_norm()); Algebraic denom1 = nt_traits.evaluate_at (derivX, t1) * nt_traits.convert (_curve.y_norm()); CGAL::Sign inf_slope1 = CGAL::ZERO; Algebraic slope1; if (CGAL::sign (denom1) == CGAL::ZERO) { inf_slope1 = is_directed_right() ? CGAL::sign (numer1) : CGAL::opposite( CGAL::sign (numer1) ); // If both derivatives are zero, we cannot perform the comparison: if (inf_slope1 == CGAL::ZERO) return (EQUAL); } else { slope1 = numer1 / denom1; } // Compute the slope of the other subcurve. derivX = nt_traits.derive (cv._curve.x_polynomial()); derivY = nt_traits.derive (cv._curve.y_polynomial()); Algebraic numer2 = nt_traits.evaluate_at (derivY, t2) * nt_traits.convert (cv._curve.x_norm()); Algebraic denom2 = nt_traits.evaluate_at (derivX, t2) * nt_traits.convert (cv._curve.y_norm()); CGAL::Sign inf_slope2 = CGAL::ZERO; Algebraic slope2; if (CGAL::sign (denom2) == CGAL::ZERO) { inf_slope2 = cv.is_directed_right() ? CGAL::sign (numer2) : CGAL::opposite( CGAL::sign (numer2) ); // If both derivatives are zero, we cannot perform the comparison: if (inf_slope2 == CGAL::ZERO) return (EQUAL); } else { slope2 = numer2 / denom2; } // Handle the comparison when one slope (or both) is +/- oo. if (inf_slope1 == CGAL::POSITIVE) return (inf_slope2 == CGAL::POSITIVE ? EQUAL : LARGER); if (inf_slope1 == CGAL::NEGATIVE) return (inf_slope2 == CGAL::NEGATIVE ? EQUAL : SMALLER); if (inf_slope2 == CGAL::POSITIVE) return (SMALLER); if (inf_slope2 == CGAL::NEGATIVE) return (LARGER); // Compare the slopes. return (CGAL::compare (slope1, slope2)); } // --------------------------------------------------------------------------- // Get the range of t-value over which the subcurve is defined. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> std::pair<typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Algebraic, typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Algebraic> _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_t_range (Bezier_cache& cache) const { Originator_iterator ps_org = _ps.get_originator (_curve, _xid); CGAL_assertion(ps_org != _ps.originators_end()); Originator_iterator pt_org = _pt.get_originator (_curve, _xid); CGAL_assertion(pt_org != _pt.originators_end()); // Make sure that the two endpoints are exact. if (! ps_org->has_parameter()) _ps.make_exact (cache); if (! pt_org->has_parameter()) _pt.make_exact (cache); return (std::make_pair (ps_org->parameter(), pt_org->parameter())); } // --------------------------------------------------------------------------- // Compare the relative y-position of two x-monotone subcurve to the right // (or to the left) of their intersection point, whose multiplicity is // greater than 1. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_compare_to_side (const Self& cv, const Point_2& p, bool to_right, Bezier_cache& cache) const { // Get the intersection points of the two curves from the cache. Note that // we make sure that the ID of this->_curve is smaller than of cv's curve ID. const bool no_swap_curves = (_curve.id() <= cv._curve.id()); bool do_ovlp; const Intersect_list& inter_list = (no_swap_curves ? (cache.get_intersections (_curve.id(), _curve.x_polynomial(), _curve.x_norm(), _curve.y_polynomial(), _curve.y_norm(), cv._curve.id(), cv._curve.x_polynomial(), cv._curve.x_norm(), cv._curve.y_polynomial(), cv._curve.y_norm(), do_ovlp)) : (cache.get_intersections (cv._curve.id(), cv._curve.x_polynomial(), cv._curve.x_norm(), cv._curve.y_polynomial(), cv._curve.y_norm(), _curve.id(), _curve.x_polynomial(), _curve.x_norm(), _curve.y_polynomial(), _curve.y_norm(), do_ovlp))); // Get the parameter value for the point p. Originator_iterator org = p.get_originator (_curve, _xid); CGAL_assertion (org != p.originators_end()); CGAL_assertion (org->has_parameter()); const Algebraic& t0 = org->parameter(); // Get the parameter range of the curve. const std::pair<Algebraic, Algebraic>& range = _t_range (cache); const Algebraic& t_src = range.first; const Algebraic& t_trg = range.second; // Find the next intersection point that lies to the right of p. Intersect_iter iit; Algebraic next_t; Comparison_result res = CGAL::EQUAL; bool found = false; for (iit = inter_list.begin(); iit != inter_list.end(); ++iit) { // Check if the current point lies to the right (left) of p. We do so by // considering its originating parameter value s (or t, if we swapped // the curves). const Algebraic& t = (no_swap_curves ? (iit->s) : iit->t); res = CGAL::compare (t, t0); if ((to_right && ((_inc_to_right && res == LARGER) || (! _inc_to_right && res == SMALLER))) || (! to_right && ((_inc_to_right && res == SMALLER) || (! _inc_to_right && res == LARGER)))) { if (! found) { next_t = t; found = true; } else { // If we have already located an intersection point to the right // (left) of p, choose the leftmost (rightmost) of the two points. res = CGAL::compare (t, next_t); if ((to_right && ((_inc_to_right && res == SMALLER) || (! _inc_to_right && res == LARGER))) || (! to_right && ((_inc_to_right && res == LARGER) || (! _inc_to_right && res == SMALLER)))) { next_t = t; } } } } // If the next intersection point occurs before the right (left) endpoint // of the subcurve, keep it. Otherwise, take the parameter value at // the endpoint. if (found) { if (to_right == _dir_right) res = CGAL::compare (t_trg, next_t); else res = CGAL::compare (t_src, next_t); } if (! found || (to_right && ((_inc_to_right && res == SMALLER) || (! _inc_to_right && res == LARGER))) || (! to_right && ((_inc_to_right && res == LARGER) || (! _inc_to_right && res == SMALLER)))) { next_t = ((to_right == _dir_right) ? t_trg : t_src); } // Find a rational value between t0 and t_next. Using this value, we // a point with rational coordinates on our subcurve. We also locate a point // on the other curve with the same x-coordinates. Nt_traits nt_traits; const Rational& mid_t = nt_traits.rational_in_interval (t0, next_t); const Rat_point_2& q1 = _curve (mid_t); const Algebraic& y2 = cv._get_y (q1.x(), cache); // We now just have to compare the y-coordinates of the two points we have // computed. return (CGAL::compare (nt_traits.convert (q1.y()), y2)); } // --------------------------------------------------------------------------- // Clip the control polygon of the supporting Bezier curve such that it fits // the current x-monotone subcurve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> void _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_clip_control_polygon (typename Bounding_traits::Control_points& ctrl, typename Bounding_traits::NT& t_min, typename Bounding_traits::NT& t_max) const { // Start from the control polygon of the supporting curve. ctrl.clear(); std::copy (_curve.control_points_begin(), _curve.control_points_end(), std::back_inserter (ctrl)); // The x-monotone subcurve is defined over a parameter range // 0 <= t_min < t_max <= 1. Determine the endpoint with minimal t-value and // the one with maximal t-value. const Point_2& p_min = (_inc_to_right ? left() : right()); Originator_iterator org_min = p_min.get_originator (_curve, _xid); const Point_2& p_max = (_inc_to_right ? right() : left()); Originator_iterator org_max = p_max.get_originator (_curve, _xid); bool clipped_min = false; CGAL_assertion (org_min != p_min.originators_end()); CGAL_assertion (org_max != p_max.originators_end()); // Check if t_min = 0. If so, there is no need to clip. if (! (org_min->point_bound().type == Bez_point_bound::RATIONAL_PT && CGAL::sign (org_min->point_bound().t_min) == CGAL::ZERO)) { // It is possible that the paramater range of the originator is too large. // We therefore make sure it fits the current bounding box of the point // (which we know is tight enough). p_min.fit_to_bbox(); // Obtain two control polygons, the first for [0, t_min] and the other for // [t_min, 1] and take the second one. typename Bounding_traits::Control_points cp_a; typename Bounding_traits::Control_points cp_b; t_min = org_min->point_bound().t_max; de_Casteljau_2 (ctrl.begin(), ctrl.end(), t_min, std::back_inserter(cp_a), std::front_inserter(cp_b)); ctrl.clear(); std::copy (cp_b.begin(), cp_b.end(), std::back_inserter (ctrl)); clipped_min = true; } else { t_min = 0; } // Check if t_max = 1. If so, there is no need to clip. if (! (org_max->point_bound().type == Bez_point_bound::RATIONAL_PT && CGAL::compare (org_max->point_bound().t_max, 1) == CGAL::EQUAL)) { // It is possible that the paramater range of the originator is too large. // We therefore make sure it fits the current bounding box of the point // (which we know is tight enough). p_max.fit_to_bbox(); // Obtain two control polygons, the first for [t_min, t_max] and the other // for [t_max, 1] and take the first one. typename Bounding_traits::Control_points cp_a; typename Bounding_traits::Control_points cp_b; if (clipped_min) { t_max = (org_max->point_bound().t_min - t_min) / (1 - t_min); } else { t_max = org_max->point_bound().t_min; } de_Casteljau_2 (ctrl.begin(), ctrl.end(), t_max, std::back_inserter(cp_a), std::front_inserter(cp_b)); ctrl.clear(); std::copy (cp_a.begin(), cp_a.end(), std::back_inserter (ctrl)); t_max = org_max->point_bound().t_min; } else { t_max = 1; } return; } // --------------------------------------------------------------------------- // Approximate the intersection points between the two given curves. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_approximate_intersection_points (const Self& cv, std::list<Point_2>& inter_pts) const { typedef typename Bounding_traits::Intersection_point Intersection_point; inter_pts.clear(); // Get the supporting Bezier curves, and make local copies of their control // polygons. const Curve_2& B1 = this->_curve; const Curve_2& B2 = cv._curve; typename Bounding_traits::Control_points cp1; typename Bounding_traits::NT t_min1 = 0, t_max1 = 1; typename Bounding_traits::Control_points cp2; typename Bounding_traits::NT t_min2 = 0, t_max2 = 1; bool is_self_intersection = false; if (! B1.is_same (B2)) { // In case B1 and B2 are different curves, use their full control polygons // in order to approximate all intersection points between the two // supporting Bezier curves. std::copy (B1.control_points_begin(), B1.control_points_end(), std::back_inserter (cp1)); std::copy (B2.control_points_begin(), B2.control_points_end(), std::back_inserter(cp2)); } else { // In this case we need to approximate the (self-)intersection points of // two subcurves of the same Bezier curve. Clip the control polygons and // obtain the control polygons of the two subcurves. _clip_control_polygon (cp1, t_min1, t_max1); cv._clip_control_polygon (cp2, t_min2, t_max2); is_self_intersection = true; } // Use the bounding traits to isolate the intersection points. Bounding_traits bound_tr; std::list<Intersection_point> ipt_bounds; bound_tr.compute_intersection_points (cp1, cp2, std::back_inserter (ipt_bounds)); // Construct the approximated points. typename std::list<Intersection_point>::const_iterator iter; for (iter = ipt_bounds.begin(); iter != ipt_bounds.end(); ++iter) { const Bez_point_bound& bound1 = iter->bound1; const Bez_point_bound& bound2 = iter->bound2; const Bez_point_bbox& bbox = iter->bbox; // In case it is impossible to further refine the point, stop here. if (! bound1.can_refine || ! bound2.can_refine) return (false); // Create the approximated intersection point. Point_2 pt; if (bound1.type == Bounding_traits::Bez_point_bound::RATIONAL_PT && bound2.type == Bounding_traits::Bez_point_bound::RATIONAL_PT) { CGAL_assertion (CGAL::compare (bound1.t_min, bound1.t_max) == EQUAL); CGAL_assertion (CGAL::compare (bound2.t_min, bound2.t_max) == EQUAL); Rational t1 = bound1.t_min; Rational t2 = bound2.t_min; Nt_traits nt_traits; if (is_self_intersection) { // Set the originators with the curve x-monotone IDs. // Note that the parameter values we have computed relate to the // parameter range [t_min1, t_max1] and [t_min2, t_max2], respectively, // so we scale them back to the parameter range [0, 1] that represent // the entire curve. t1 = t_min1 + t1 * (t_max1 - t_min1); t2 = t_min2 + t2 * (t_max2 - t_min2); pt = Point_2 (B1, _xid, t1); pt.add_originator (Originator (B2, cv._xid, t2)); } else { // Set the originators referring to the entire supporting curves. pt = Point_2 (B1, t1); pt.add_originator (Originator (B2, nt_traits.convert (t2))); } } else { if (is_self_intersection) { // Set the originators with the curve x-monotone IDs. // Note that the parameter values we have computed relate to the // parameter range [t_min1, t_max1] and [t_min2, t_max2], respectively, // so we scale them back to the parameter range [0, 1] that represent // the entire curve. Bez_point_bound sc_bound1 = bound1; sc_bound1.t_min = t_min1 + bound1.t_min * (t_max1 - t_min1); sc_bound1.t_max = t_min1 + bound1.t_max * (t_max1 - t_min1); pt.add_originator (Originator (B1, _xid, sc_bound1)); Bez_point_bound sc_bound2 = bound2; sc_bound2.t_min = t_min2 + bound2.t_min * (t_max2 - t_min2); sc_bound2.t_max = t_min2 + bound2.t_max * (t_max2 - t_min2); pt.add_originator (Originator (B2, cv._xid, sc_bound2)); } else { // Set the originators with the curve x-monotone IDs. pt.add_originator (Originator (B1, bound1)); pt.add_originator (Originator (B2, bound2)); } } pt.set_bbox (bbox); inter_pts.push_back (pt); } // The approximation process ended OK. return (true); } // --------------------------------------------------------------------------- // Compute the intersections with the given subcurve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_intersect (const Self& cv, Intersection_map& inter_map, Bezier_cache& cache, std::vector<Intersection_point_2>& ipts, Self& ovlp_cv) const { CGAL_precondition (_curve.id() <= cv._curve.id()); ipts.clear(); // In case the two x-monotone curves are subcurves of the same Bezier curve, // first check if this base curve is not self-intersecting. If this is the // case we can avoid any attempt of computing intersection points between // the two subcurves. const bool self_intersect = (_curve.id() == cv._curve.id()); if (self_intersect) { if (_xid == cv._xid) return (false); if (_curve.has_no_self_intersections()) return (false); } // Construct the pair of curve IDs and look for it in the intersection map. Curve_pair curve_pair (_curve.id(), cv._curve.id()); Intersection_map_iterator map_iter = inter_map.find (curve_pair); std::list<Point_2> inter_pts; bool app_ok = true; if (map_iter != inter_map.end()) { // Get the intersection points between the two supporting curves as stored // in the map. inter_pts = map_iter->second; } else { // Approximate the intersection points and store them in the map. // Note that we do not store approximated self-intersections in the map, // as they realte only to the pecific x-monotone curves, and not to the // entire curve. app_ok = _approximate_intersection_points (cv, inter_pts); if (app_ok && ! self_intersect) inter_map[curve_pair] = inter_pts; } // Try to approximate the intersection points. bool in_range1, in_range2; bool correct_res; if (app_ok) { // If the approximation went OK, then we know that we just have simple // intersection points (with multiplicity 1). We go over the points // and report the ones lying in the parameter ranges of both curves. // Note that in case of self-intersections, all points we get are in // the respective parameter range of the curves. typename std::list<Point_2>::iterator pit; for (pit = inter_pts.begin(); pit != inter_pts.end(); ++pit) { // Check if the point is in the range of this curve - first using // its parameter bounds, and if we fail we perform an exact check. if (! self_intersect) { in_range1 = _is_in_range (*pit, correct_res); } else { in_range1 = true; correct_res = true; } if (! correct_res) { if (! pit->is_exact()) pit->make_exact (cache); Originator_iterator p_org = pit->get_originator (_curve, _xid); CGAL_assertion (p_org != pit->originators_end()); in_range1 = _is_in_range (p_org->parameter(), cache); } if (! in_range1) continue; // Check if the point is in the range of the other curve - first using // its parameter bounds, and if we fail we perform an exact check. if (! self_intersect) { in_range2 = cv._is_in_range (*pit, correct_res); } else { in_range2 = true; correct_res = true; } if (! correct_res) { if (! pit->is_exact()) pit->make_exact (cache); Originator_iterator p_org = pit->get_originator (cv._curve, cv._xid); CGAL_assertion (p_org != pit->originators_end()); in_range2 = cv._is_in_range (p_org->parameter(), cache); } if (in_range1 && in_range2) { // In case the originators of the intersection point are not marked // with x-monotone identifiers, mark them now as we know in which // subcurves they lie. Originator_iterator p_org1 = pit->get_originator (_curve, _xid); CGAL_assertion (p_org1 != pit->originators_end()); if (p_org1->xid() == 0) pit->update_originator_xid (*p_org1, _xid); Originator_iterator p_org2 = pit->get_originator (cv._curve, cv._xid); CGAL_assertion (p_org2 != pit->originators_end()); if (p_org2->xid() == 0) pit->update_originator_xid (*p_org2, cv._xid); // The point lies within the parameter range of both curves, so we // report it as a valid intersection point with multiplicity 1. ipts.push_back (Intersection_point_2 (*pit, 1)); } } // Since the apporximation went fine we cannot possibly have an overlap: return (false); } // We did not succeed in isolate the approximate intersection points. // We therefore resort to the exact procedure and exactly compute them. bool do_ovlp; const Intersect_list& inter_list = cache.get_intersections (_curve.id(), _curve.x_polynomial(), _curve.x_norm(), _curve.y_polynomial(), _curve.y_norm(), cv._curve.id(), cv._curve.x_polynomial(), cv._curve.x_norm(), cv._curve.y_polynomial(), cv._curve.y_norm(), do_ovlp); if (do_ovlp) { // Check the case of co-inciding endpoints if (left().equals (cv.left(), cache)) { if (right().equals (cv.right(), cache)) { // The two curves entirely overlap one another: ovlp_cv = cv; return (true); } Algebraic t_right; bool is_endpoint; if (_is_in_range (cv.right(), cache, t_right, is_endpoint)) { CGAL_assertion (! is_endpoint); // Case 1 - *this: s +-----------+ t // cv: s'+=====+ t' // // Take cv as the overlapping subcurve, and add originators for its // right endpoint referring to *this. ovlp_cv = cv; ovlp_cv.right().add_originator (Originator (_curve, _xid, t_right)); return (true); } else if (cv._is_in_range (right(), cache, t_right, is_endpoint)) { CGAL_assertion (! is_endpoint); // Case 2 - *this: s +----+ t // cv: s'+==========+ t' // // Take this as the overlapping subcurve, and add originators for its // right endpoint referring to cv. ovlp_cv = *this; ovlp_cv.right().add_originator (Originator (cv._curve, cv._xid, t_right)); return (true); } // In this case the two curves do not overlap, but have a common left // endpoint. ipts.push_back (Intersection_point_2 (left(), 0)); return (false); } else if (right().equals (cv.right(), cache)) { Algebraic t_left; bool is_endpoint; if (_is_in_range (cv.left(), cache, t_left, is_endpoint)) { CGAL_assertion (! is_endpoint); // Case 3 - *this: s +-----------+ t // cv: s'+=====+ t' // // Take cv as the overlapping subcurve, and add originators for its // left endpoint referring to *this. ovlp_cv = cv; ovlp_cv.left().add_originator (Originator (_curve, _xid, t_left)); return (true); } else if (cv._is_in_range (left(), cache, t_left, is_endpoint)) { CGAL_assertion (! is_endpoint); // Case 4 - *this: s +----+ t // cv: s'+==========+ t' // // Take this as the overlapping subcurve, and add originators for its // left endpoint referring to cv. ovlp_cv = *this; ovlp_cv.left().add_originator (Originator (cv._curve, cv._xid, t_left)); return (true); } // In this case the two curves do not overlap, but have a common right // endpoint. ipts.push_back (Intersection_point_2 (right(), 0)); return (false); } // If we reached here, none of the endpoints coincide. // Check the possible overlap scenarios. Point_2 ovrp_src, ovlp_trg; Algebraic t_cv_src; Algebraic t_cv_trg; bool is_endpoint = false; if (_is_in_range (cv._ps, cache, t_cv_src, is_endpoint) && ! is_endpoint) { if (_is_in_range (cv._pt, cache, t_cv_trg, is_endpoint) && ! is_endpoint) { // Case 5 - *this: s +-----------+ t // cv: s' +=====+ t' // // Take cv as the overlapping subcurve, and add originators for its // endpoints referring to *this. ovlp_cv = cv; ovlp_cv._ps.add_originator (Originator (_curve, _xid, t_cv_src)); ovlp_cv._pt.add_originator (Originator (_curve, _xid, t_cv_trg)); return (true); } else { // Case 6 - *this: s +-----------+ t // cv: s' +=====+ t' // // Use *this as a base, and replace its source point. ovlp_cv = *this; ovlp_cv._ps = cv._ps; ovlp_cv._ps.add_originator (Originator (_curve, _xid, t_cv_src)); // Add an originator to the target point, referring to cv: CGAL_assertion_code (bool pt_in_cv_range =) cv._is_in_range (ovlp_cv._pt, cache, t_cv_trg, is_endpoint); CGAL_assertion (pt_in_cv_range); ovlp_cv._pt.add_originator (Originator (cv._curve, cv._xid, t_cv_trg)); return (true); } } else if (_is_in_range (cv._pt, cache, t_cv_trg, is_endpoint) && ! is_endpoint) { // Case 7 - *this: s +-----------+ t // cv: s' +=====+ t' // // Use *this as a base, and replace its target point. ovlp_cv = *this; ovlp_cv._pt = cv._pt; ovlp_cv._pt.add_originator (Originator (_curve, _xid, t_cv_trg)); // Add an originator to the source point, referring to cv: CGAL_assertion_code (bool ps_in_cv_range =) cv._is_in_range (ovlp_cv._ps, cache, t_cv_src, is_endpoint); CGAL_assertion (ps_in_cv_range); ovlp_cv._ps.add_originator (Originator (cv._curve, cv._xid, t_cv_src)); return (true); } else if (cv._is_in_range (_ps, cache, t_cv_src, is_endpoint) && cv._is_in_range (_pt, cache, t_cv_trg, is_endpoint)) { // Case 8 - *this: s +---------+ t // cv: s' +================+ t' // // Take *this as the overlapping subcurve, and add originators for its // endpoints referring to cv. ovlp_cv = *this; ovlp_cv._ps.add_originator (Originator (cv._curve, cv._xid, t_cv_src)); ovlp_cv._pt.add_originator (Originator (cv._curve, cv._xid, t_cv_trg)); return (true); } // If we reached here, there are no overlaps: return (false); } // Go over the points and report the ones lying in the parameter ranges // of both curves. Intersect_iter iit; for (iit = inter_list.begin(); iit != inter_list.end(); ++iit) { if (_is_in_range (iit->s, cache) && cv._is_in_range (iit->t, cache)) { // Construct an intersection point with unknown multiplicity. Point_2 pt (iit->x, iit->y, true); // Dummy parameter. pt.add_originator (Originator (_curve, _xid, iit->s)); pt.add_originator (Originator (cv._curve, cv._xid, iit->t)); ipts.push_back (Intersection_point_2 (pt, 0)); } } // Mark that there is no overlap: return (false); } // --------------------------------------------------------------------------- // Compute the exact vertical position of the point p with respect to the // curve. // template <class RatKer, class AlgKer, class NtTrt, class BndTrt> Comparison_result _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_exact_vertical_position (const Point_2& p, bool force_exact) const { // If it is a rational point, obtain its rational reprsentation. Rat_point_2 rat_p; if (p.is_rational()) rat_p = (Rat_point_2) p; // Get a rational approximation of the parameter values at the endpoints. Nt_traits nt_traits; Originator_iterator ps_org = _ps.get_originator (_curve, _xid); CGAL_assertion (ps_org != _ps.originators_end()); Originator_iterator pt_org = _pt.get_originator (_curve, _xid); CGAL_assertion (pt_org != _pt.originators_end()); Rational my_t_min; Rational my_t_max; if (CGAL::compare (ps_org->point_bound().t_max, pt_org->point_bound().t_min) == SMALLER) { // In case the parameter value of the source is smaller than the target's. my_t_min = ps_org->point_bound().t_max; my_t_max = pt_org->point_bound().t_min; } else { CGAL_assertion (CGAL::compare (pt_org->point_bound().t_max, ps_org->point_bound().t_min) == SMALLER); // In case the parameter value of the target is smaller than the source's. my_t_min = pt_org->point_bound().t_max; my_t_max = ps_org->point_bound().t_min; } // Start the subdivision process from the entire supporting curve. std::list<Subcurve> subcurves; Subcurve init_scv; Rational x_min, y_min, x_max, y_max; bool no_x_ovlp; Comparison_result res_y_min, res_y_max; std::copy (_curve.control_points_begin(), _curve.control_points_end(), std::back_inserter (init_scv.control_points)); init_scv.t_min = 0; init_scv.t_max = 1; subcurves.push_back (init_scv); while (! subcurves.empty()) { // Go over the list of subcurves and consider only those lying in the // given [t_min, t_max] bound. typename std::list<Subcurve>::iterator iter = subcurves.begin(); bool is_fully_in_range; while (iter != subcurves.end()) { if (CGAL::compare (iter->t_max, my_t_min) == SMALLER || CGAL::compare (iter->t_min, my_t_max) == LARGER) { // Subcurve out of bounds of the x-monotone curve we consider - erase // it and continue to next subcurve. subcurves.erase(iter++); continue; } // Construct the bounding box of the subcurve and compare it to // the bounding box of the point. iter->bbox (x_min, y_min, x_max, y_max); if (p.is_rational()) { no_x_ovlp = (CGAL::compare (x_min, rat_p.x()) == LARGER || CGAL::compare (x_max, rat_p.x()) == SMALLER); } else { no_x_ovlp = (CGAL::compare (nt_traits.convert (x_min), p.x()) == LARGER || CGAL::compare (nt_traits.convert (x_max), p.x()) == SMALLER); } if (no_x_ovlp) { // Subcurve out of x-bounds - erase it and continue to next subcurve. subcurves.erase(iter++); continue; } // In this case, check if there is an overlap in the y-range. if (p.is_rational()) { res_y_min = CGAL::compare (rat_p.y(), y_min); res_y_max = CGAL::compare (rat_p.y(), y_max); } else { res_y_min = CGAL::compare (p.y(), nt_traits.convert (y_min)); res_y_max = CGAL::compare (p.y(), nt_traits.convert (y_max)); } is_fully_in_range = (CGAL::compare (iter->t_min, my_t_min) != SMALLER) && (CGAL::compare (iter->t_max, my_t_max) != LARGER); if (res_y_min != res_y_max || ! is_fully_in_range) { // Subdivide the current subcurve and replace iter with the two // resulting subcurves using de Casteljau's algorithm. Subcurve scv_l, scv_r; scv_l.t_min = iter->t_min; scv_r.t_max = iter->t_max; scv_l.t_max = scv_r.t_min = (iter->t_min + iter->t_max) / 2; bisect_control_polygon_2 (iter->control_points.begin(), iter->control_points.end(), std::back_inserter(scv_l.control_points), std::front_inserter(scv_r.control_points)); subcurves.insert (iter, scv_l); subcurves.insert (iter, scv_r); subcurves.erase(iter++); continue; } if (res_y_min == res_y_max) { CGAL_assertion (res_y_min != EQUAL); // We reached a separation, as p is either strictly above or strictly // below the bounding box of the current subcurve. return (res_y_min); } // If we got here without entering one of the clauses above, // then iter has not been incremented yet. ++iter; } } // We can reach here only if we do not force an exact result. CGAL_assertion (! force_exact); return (EQUAL); } } //namespace CGAL #endif
- [cgal-discuss] Re: Bezier curve arrangement error, Gene, 12/01/2010
- Re: [cgal-discuss] Re: Bezier curve arrangement error, Sebastien Loriot (GeometryFactory), 12/06/2010
- Re: [cgal-discuss] Re: Bezier curve arrangement error, Sebastien Loriot (GeometryFactory), 12/09/2010
- [cgal-discuss] Re: Bezier curve arrangement error, Gene, 12/09/2010
