Re: [cgal-discuss] template instantiation depth build error for examples/Mesh_3/mesh_polyhedral_domain.cpp
- To:
- Cc: Michel Audette <>
- Subject: Re: [cgal-discuss] template instantiation depth build error for examples/Mesh_3/mesh_polyhedral_domain.cpp
- Date: Thu, 9 Dec 2010 22:15:34 +0100
Le jeudi 09 décembre 2010 21:57:58, Michel Audette a écrit :
> Hi Laurent,
> I understand it's probably late if you're in France, so I appreciate your
> help.
> I'm including the source code. It's basically the
> examples/Mesh_3/mesh_polyhedral_domain.cpp example as is, except for a
> check on argv, so far.
Thanks. That also confirms that you used CGAL-3.7 (because that example
changed slightly between CGAL versions).
Can you send me the log list of errors reported by g++? By private mail,
because I know it will be a very long file.
Maybe g++-4.4.3 has a strange bug. CGAL is tested daily with a lot of g++
versions, among them g++-4.4.1 and g++-4.4.4. Maybe the minor version .3 had
a
bug. Do you have accept to another version of g++?
Laurent Rineau, PhD
- [cgal-discuss] template instantiation depth build error for examples/Mesh_3/mesh_polyhedral_domain.cpp, Michel Audette, 12/09/2010
- Re: [cgal-discuss] template instantiation depth build error for examples/Mesh_3/mesh_polyhedral_domain.cpp, Laurent Rineau (GeometryFactory), 12/09/2010
- Re: [cgal-discuss] template instantiation depth build error for examples/Mesh_3/mesh_polyhedral_domain.cpp, Michel Audette, 12/09/2010
