cgal-discuss - Re: [cgal-discuss] AABB Trees and Polyhedrons
  • To:
  • Subject: Re: [cgal-discuss] AABB Trees and Polyhedrons
  • Date: Fri, 10 Dec 2010 15:27:18 +0100
On Friday 10 December 2010 15:21:08 Arun Ramasamy wrote:
> Hi,
> I'm using the AABB tree data structure to query if a polyhedron intersects
> with planes/line segments. I'm also altering the polyhedron mesh using
> Euler operators based on the results from the query. Is it possible to
> adjust the AABB tree to the changed polyhedron, without initializing it
> completely from scratch. So in the steps below:
> 1. Polyhedron ph;
> 2. AABB_Tree tree(ph.facets_begin(), ph.facets_end());
> 3. result = tree.all_intersections(plane_query);
> 4. ph.euler_operation(result); //eg ph.split_edge();
> After altering the polyhedron like this, can I query the AABB_Tree again
> like
> 5. resultnew = tree.all_intersections(plane_query_new); //tree is not
> adjusted
> If not, is there an alternative through which I can make the tree adjust
> based only on the changed part of the polyhedron.
No. The construction of the AABB tree is static. All what you can do is
rebuild the tree, with:
tree.rebuild(ph.facets_begin(), ph.facets_end());
after the operation #4, but that will cost the construction of a new tree.
Laurent Rineau, PhD
