cgal-discuss - Re: [cgal-discuss] Robust math using crlibm
  • To:
  • Subject: Re: [cgal-discuss] Robust math using crlibm
  • Date: Wed, 15 Dec 2010 15:27:46 +0100 (CET)
On Wed, 15 Dec 2010, Rosen Diankov wrote:
Dear CGAL developers,
We've been considering using parts of the CGAL math backend for a
robot motion planning environment named OpenRAVE (
http://openrave.programmingvision.com ) in order get much more
reliable computation results. The documentation and presentations have
really hammered in the point that CGAL cares about precision.
However, looking at the include headers, it seems that the standard
C++ implementations of atan, asin, sin, cos, etc are used. Does this
mean that CGAL considers their errors insignificant?
Basically, the answer is that CGAL doesn't use sin, cos, etc. At least not where it matters. If you try to call sin on one of the CGAL types (say CGAL::Gmpq) it will give an error.
A strong idea in CGAL is that you can do computations exactly (usually you don't because fast low-precision computations are enough to guarantee the result, but you can detect the cases were extra precision is required), which is possible for algebraic operations but not so simple for sin/cos. Besides, the usual geometric algorithms don't need trigonometric functions.
How much do you need trigonometric functions in your application, and what for? CGAL wants exactness when it evaluates predicates, and sometimes when it constructs objects in a clear geometric way (so if you construct the point of intersection p of line l with some object and then test whether p is on l you get a consistent answer). For the rest, approximations may be fine.
In search for better standard library functions, we stumbled onto crlibm
http://lipforge.ens-lyon.fr/www/crlibm/
I'm sure the developers have heard of this library, so why isn't it a
part of CGAL? Is it not as accurate as it claims?
Oh, I am sure it is very accurate (note that some standard libraries may be just as accurate). But that is not the same meaning as we use in CGAL, where we want exactness (more precisely, we don't care about the precision as long as we can guarantee that the sign is correct, which may require more precision that you can get from double). mpfr, which allows an arbitrary precision, is already closer to it, and is actually used in CGAL, in very specific ways.
Marc Glisse
