cgal-discuss - [cgal-discuss] can CGAL Surface Mesh Generation fidelity to gray level boundary be controlled as a parameter?
  • To:
  • Subject: [cgal-discuss] can CGAL Surface Mesh Generation fidelity to gray level boundary be controlled as a parameter?
  • Date: Wed, 15 Dec 2010 16:42:10 -0500
Dear CGAL developers,
I would like to use your Surface Mesher with a brain volume that
features a narrow slit in the left Sylvian fissure (other sulci are
obliterated by morphological closing). This fissure was accentuated
somewhat by morphological opening. However, if I try to run the Gray
Level-based Surface Mesher, this slit, as well as a interhemispheric
space get filled out by the resulting surface mesher. Is there a
parameter that I can play with that will produce a surface with a
tigher fidelity to boundary?
The brain binary is Gaussian-filtered with a small kernel.
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
  • [cgal-discuss] can CGAL Surface Mesh Generation fidelity to gray level boundary be controlled as a parameter?, Michel Audette, 12/15/2010
