- To:
- Subject: Re: [cgal-discuss] Constraints
- Date: Mon, 20 Dec 2010 14:35:33 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=vqXgHAqZbl/JisFdA64AUn207CvS0MTyC2qbXP4noftkMtbRzGQ7qgT9uQcfy/FcFy e0WqPq8txowELe5Ls5p+kG/xmsTOfrlpo5702Z9PJ8V1wjpGwkunMYLxYfr7JSxXhqx3 93bgFN/+TLts6FUWjZABT8lLD+izgRl+beEFI=
Aycan Tutay wrote:
Hi, we are developing 3D solid modelling program using a gometric modellingIf I understand well your question, there is nothing in CGAL that allows
kernel but there is not enough capabilities about constraints in the library
of it. I wonder whether cgal package includes support for constraints
(parallel, perpendicular, coincidence, tangent, concentric, symmetric and
equal radius constraints). If you give information about that, I will be
glad.
to define constraints between geometric objects.
CGAL is a library of algorithms that operate over geometric objects without explicitly encoded relation between objects
(Some data structures are also provided)
S.
Best Regards
Aycan Tutay
Software Manager
Ege Univ. Kampusu Kosgeb EBSO
Teknoloji Gelistirme Merkezi No:2
35040 Bornova / IZMIR/TURKEY
Tel :+90 232 3730808
:+90 232 3429051 - 137
Fax:+90 232 3730808
e-mail:
- [cgal-discuss] Constraints, Aycan Tutay, 12/13/2010
- Re: [cgal-discuss] Constraints, Sebastien Loriot (GeometryFactory), 12/20/2010
