cgal-discuss - Re: [cgal-discuss] Puzzles on learning 3D surface reconstruction from point sets
  • To:
  • Subject: Re: [cgal-discuss] Puzzles on learning 3D surface reconstruction from point sets
  • Date: Mon, 03 Jan 2011 10:55:56 +0100
Hi,
I guess that your application crashed. I invite you to run it under a
debugger to see what is happening (you will need to compile CGAL in debug
mode).
Best regards,
Laurent Saboret
Le 24/12/2010 06:02, cmodel a écrit :
Hi All,
I am a newbie on learning 3D surface reconstruction from point sets, I have
met some puzzles.
I use one general .xyz file (without normals inside), to be loaded in the
demo.
Then according to the online manual, I performed:
1. analysis
2. processing
3. normal estimation
4. reconstruction
steps 1-3 are OK, but when performing 4.reconstruction, it quit by its own
without anything.
And can anyone explain the usage of those parameters needed in each step ?
Is that the cause of my incorrect parameters configuration ?
Please help me. Thanks.
