cgal-discuss - Re: [cgal-discuss] Getting started with CGAL on a mac OS X
  • To:
  • Subject: Re: [cgal-discuss] Getting started with CGAL on a mac OS X
  • Date: Mon, 3 Jan 2011 17:02:48 +0100
@Sebastian:
>> First, in 4.2 there are two variants (with or without a value of DCGAL_DIR
>> given). Which one is the right one?
> Depends if you defined CGAL_DIR as an environment variable.
I'm afraid that I don't know what you mean here... Where should I (or
shouldn't I) define this variable?
>> I did not try anything without CGAL. How should I check my cmake
>> installation?
>> Let me remind that "cmake -GXcode ." worked for the example
>> "Voronoi_diag_2". Is it a sign that "cmake" is properly installed?
> Indeed. I guess this is working with Xcode?
> The cmake error message may be indicating that you are missing
> building tools available from your terminal.
So? How can I analyze what am I missing in the terminal?
