cgal-discuss - Re: [cgal-discuss] Re: compiling CGAL in windows
  • To:
  • Subject: Re: [cgal-discuss] Re: compiling CGAL in windows
  • Date: Wed, 12 Jan 2011 11:24:33 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=rRWMkvwYvMMy+AztQumh2q65gBOnNnAvH+1rG1a79K8pqmkTXPXqBEFiG616GOUMLn lIqHFJy4IdHCReoExAIwq/qrlGuJK3pol/gpCfLWnAJVU1duRob+9APtMyLHyK6mhkrU urHddgNuFg1AHKF1UOKvNo8mh12mNLkUenOqI=
Visual Studio 64bits, what cmake version you have? Try to get cmake sources and build yourself.
2011/1/12 Laurent Rineau (GeometryFactory) <>
Le mercredi 12 janvier 2011 10:15:17, Laurent Saboret a écrit :
> Hi,
> Usually, the error "The C compiler XXX is not able to compile a simple test
> program" means that cmake does not have the rights to write in the folder.
> Please give read/right permissions to C:/Program Files (x86)/CGAL-3.7 and
> its sub-folders.
The CMake error log in the first message of Dror, in this thread, confirms
that. It said:
"CMake Error: Could not open file for write in copy operation C:/Program
Files (x86)/CGAL-3.7/CMakeFiles/CMakeSystem.cmake.tmp"
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
