Re: [cgal-discuss] Assertion violation when converting polyhedron to Nef_polyhedron
- To:
- Subject: Re: [cgal-discuss] Assertion violation when converting polyhedron to Nef_polyhedron
- Date: Mon, 17 Jan 2011 08:17:23 +0100
johnzjq wrote:
Dear all,if the points are collinear (I did not check yours), then the plane is degenerate whatever kernel you use.
I am using Nef_polyhedron with Exact_predicates_exact_constructions_kernel.
The following assertion was triggered when I was trying to convert a closed
polyhedron to Nef_polyhedron:
Error !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CGAL error: assertion violation!
Expression : pre_prev->is_border() ||
!pe_prev->facet()->plane().is_degenerate()
File : c:\program files
(x86)\cgal-3.7\include\cgal\nef_3\polyhedron_3_to_nef_3.h
Line :219
The polyhedron is produced with MinkowskiSum and was regularized. I checked
the polyhedron and found one face that caused the assertion. The vertices of
the face is as follows:
(which have been convert to double)
vertex x_coord y_coord z_coord
v1 -18219.3965 -12395.1836 -19974.9375
v2 -18185.4824 -12361.2695 -19974.9375
v3 -18215.4336 -12391.2207 -19974.9375
Questions:
1 Why did this face been judged as "degenerate", especially under an exact
kernal?
2 Is it proper to depoly simplification to eliminate such kind of face?Might be. However Minkowski sum should not produce degenerate faces (if their is no change in the number type used).
If you think this is a bug, please make a bug report as described here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS_ref/Class_HalfedgeDS_vector.html#Cross_link_anchor_1122
S.
Any suggestions?
Thanks in advance!
John
- [cgal-discuss] Assertion violation when converting Polyhedron to Nef_polyhedron, johnzjq, 01/16/2011
- <Possible follow-up(s)>
- [cgal-discuss] Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 01/16/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 01/17/2011
- Re: [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, Sebastien Loriot (GeometryFactory), 01/17/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 01/30/2011
- [cgal-discuss] Re: Assertion violation when converting polyhedron to Nef_polyhedron, johnzjq, 01/31/2011
- Re: [cgal-discuss] Assertion violation when converting polyhedron to Nef_polyhedron, Sebastien Loriot (GeometryFactory), 01/17/2011
