- To: "" <>
- Subject: Re: [cgal-discuss] Volume of a periodic voronoi cell?
- Date: Thu, 27 Jan 2011 14:33:29 +0100
Thanks! :)
Maarten
Here is one way to compute the volume you are looking for.
Note that it is not robust as the periodic translation of points
as well as circumcenter computation require exact constructions.
It should be working for both periodic and non-periodic triangulations.
S.
Maarten Moesen wrote:
Dear all,
I'm looking for a quick way to compute or estimate the volume of a
Voronoi cell around a vertex v in a periodic triangulation. Can one just
compute the volume of the incident tetrahedra and divide this by four?
Or does one really need to construct the Voronoi cell (and partition it
somehow e.g. into pyramids around v?
Many thanks,
Maarten
Maarten Moesen, PHD
Department of Metallurgy and Materials Engineering (MTM)
K.U.Leuven
Kasteelpark Arenberg 44 - Bus 02450
B-3001 Heverlee, Belgium
tel. +32 (0)16 32 13 17
fax. +32 (0)16 32 19 90
<volume_simple.cpp>
Maarten Moesen, PHD
K.U.Leuven
- [cgal-discuss] Volume of a periodic voronoi cell?, Maarten Moesen, 01/27/2011
- Re: [cgal-discuss] Volume of a periodic voronoi cell?, Sebastien Loriot (GeometryFactory), 01/27/2011
- Re: [cgal-discuss] Volume of a periodic voronoi cell?, Maarten Moesen, 01/27/2011
