- To:
- Subject: [cgal-discuss] acquire mesh information
- Date: Thu, 27 Jan 2011 13:19:51 -0800 (PST)
Hello,
I am new to CGAL. I would like to use CGAL to create the 2D meshes for FEM
analysis.
My question is how to get the mesh information from the generated mesh, such
as point coordinate and each zone is defined by which three points.
For example, how to get those information from the mesh_class.cpp example
listed below.
Thanks a lot for your help.
#include <CGAL/Delaunay_mesh_size_criteria_2.h>
#include <iostream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Delaunay_mesh_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds> CDT;
typedef CGAL::Delaunay_mesh_size_criteria_2<CDT> Criteria;
typedef CGAL::Delaunay_mesher_2<CDT, Criteria> Mesher;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Point Point;
int main()
CDT cdt;
Vertex_handle va = cdt.insert(Point(-4,0));
Vertex_handle vb = cdt.insert(Point(0,-1));
Vertex_handle vc = cdt.insert(Point(4,0));
Vertex_handle vd = cdt.insert(Point(0,1));
cdt.insert(Point(2, 0.6));
cdt.insert_constraint(va, vb);
cdt.insert_constraint(vb, vc);
cdt.insert_constraint(vc, vd);
cdt.insert_constraint(vd, va);
std::cout << "Number of vertices: " << cdt.number_of_vertices() <<
std::endl;
std::cout << "Meshing the triangulation with default criterias..."
<< std::endl;
Mesher mesher(cdt);
mesher.refine_mesh();
std::endl;
std::cout << "Meshing with new criterias..." << std::endl;
// 0.125 is the default shape bound. It corresponds to abound 20.6 degree.
// 0.5 is the upper bound on the length of the longuest edge.
// See reference manual for Delaunay_mesh_size_traits_2<K>.
mesher.set_criteria(Criteria(0.125, 0.5));
std::endl;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/acquire-mesh-information-tp3243228p3243228.html
- [cgal-discuss] acquire mesh information, ppmm, 01/27/2011
- Re: [cgal-discuss] acquire mesh information, Sebastien Loriot (GeometryFactory), 01/28/2011
- Re: [cgal-discuss] acquire mesh information, Veronica E. Arriola, 01/28/2011
