- To:
- Subject: [cgal-discuss] Re: About Bezier curves in Arrangement
- Date: Fri, 28 Jan 2011 01:02:09 -0800 (PST)
Thanks very much for your reply!
For the first question, is that better to let the returning supporting_curve() contains the correct auxiliary data? Because the returning type of supporting_curve() is Arr_curve_data_traits_2.
In addition, I have one more question. Because I want to calculate the new control points of each sub bezier curve (X_monotone_curve_2), I use parameter_range() with de_Casteljau_2() to do that. But it seems that the returned values of parameter_range() is not so accurate for some case and hence influences the result of de_Casteljau_2(). For example, in the following code,
// ========= CODE BEGIN ==========
#include <CGAL/basic.h>
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Arr_Bezier_curve_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Arr_curve_data_traits_2.h>
#include <CGAL/Arr_walk_along_line_point_location.h>
#include <CGAL/to_rational.h>
#include <list>
using namespace std;
typedef CGAL::CORE_algebraic_number_traits Nt_traits;
typedef Nt_traits::Rational NT;
typedef Nt_traits::Rational Rational;
typedef Nt_traits::Algebraic Algebraic;
typedef CGAL::Cartesian<Rational> Rat_kernel;
typedef CGAL::Cartesian<Algebraic> Alg_kernel;
typedef Rat_kernel::Point_2 Rat_point_2;
typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel, Nt_traits> Traits_org_2;
typedef Traits_org_2::Curve_2 Bezier_curve_2;
typedef unsigned int CurveNumber;
typedef CGAL::Arr_curve_data_traits_2<Traits_org_2, CurveNumber> Traits_2;
typedef Traits_2::Curve_2 Bezier_curve_num_2;
typedef Traits_2::X_monotone_curve_2 X_monotone_curve_2;
typedef Traits_2::Point_2 Point_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
typedef CGAL::Arr_walk_along_line_point_location<Arrangement_2> Naive_pl;
#define TORAT(x) (CGAL::to_rational<Rational>((x)))
int main (int argc, char *argv[])
const char *filename = (argc > 1) ? argv[1] : "test6.dat";
std::ifstream in_file (filename);
int n_curves;
std::list<Bezier_curve_num_2> curves;
Bezier_curve_2 B;
int k;
in_file >> n_curves;
for (k = 0; k < n_curves; k++) {
in_file >> B;
Bezier_curve_num_2 bb(B, k);
curves.push_back (bb);
Arrangement_2 arr;
insert (arr, curves.begin(), curves.end());
Arrangement_2::Edge_iterator eit;
for(eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)
X_monotone_curve_2 x_curve = eit->curve();
CurveNumber num = x_curve.data();
if(num == 0) continue; // only print the curve 1
// ========= the source() and target() point is correct and accurate ==============
cout<<"Curve "<<num<<": "<<x_curve.source()<<" -> "<<x_curve.target()<<endl;
// ========= the parameter_range() to get to above points is not accurate ==========
cout<<"\tParam range: "<<x_curve.parameter_range().first<<" "<<x_curve.parameter_range().second<<endl;
return 0;
// =========== CODE END =============
with test6.dat,
// =========== DATA BEGIN ============
2
2 20 80 100 0
2 -10 14 120 40
// =========== DATA END ==============
the accurate intersection point of this two line segments is (70, 30), and the new control point should also be (70, 30). The corresponding t value of the second line segment ( (-10, 14), (120, 40) ) should be 8/13 approximates 0.6154. But the second returning value of parameter_range() is 0.625. With that, the new control point becomes (71.25, 30.25), which is incorrect.
Is that a bug? And is there any other way to calculate new control points or t values of sub cubic bezier curves?
Thanks very much!
Sincerely yours,
Stzpz
2011/1/27 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]>
Basically, Traits_2::X_monotone_curve_2 is a pairstzpz wrote:Actually, there is no bug here.
> Hello,
> I am willing to get the point location of a Bezier curves Arrangement, so I
> use Arr_Bezier_curve_traits_2 along with Arr_curve_data_traits_2 to
> construct the arrangement with auxiliary data (curve number) attached with
> each Bezier curve. And then I perform the point location function to get the
> outer connected boundaries of the point. Everything is fine except that the
> auxiliary data in the returning boundaries are incorrect.
> I use outer_ccb() to get the outer boundaries of the face, then use
> curve().supporting_curve() to get the original bezier curves with auxiliary
> data. The data in Bezier curves are correct. However, the auxiliary data
> corresponding with them are in correct. Here is the code:
> // =================== CODE BEGIN =====================
> #include <list>
> Traits_org_2;
> void point_loc(Arrangement_2 *arr) {
> Naive_pl pl(*arr);
> // this point is inside the face
> Point_2 p(TORAT(50), TORAT(40));
> CGAL::Object obj = pl.locate(p);
> Arrangement_2::Face_const_handle f;
> if (CGAL::assign(f, obj)) {
> if(!f->is_unbounded()) {
> Arrangement_2::Ccb_halfedge_const_circulator bound_circ = f->outer_ccb();
> // first sub curve
> Bezier_curve_num_2 curr_curve_num =
> bound_circ->curve().supporting_curve();
> Bezier_curve_2 curr_curve = curr_curve_num;
> // ================ the result is INCORRECT of the next line
> CurveNumber curve_num = curr_curve_num.data();
> cout<<"current curve num: "<<curve_num<<endl;
> int main (int argc, char *argv[]) {
> const char *filename = (argc > 1) ? argv[1] : "test5.dat";
> int n_curves;
> Bezier_curve_2 B;
> int k;
> in_file >> B;
> Arrangement_2 arr;
> for(eit = arr.edges_begin(); eit != arr.edges_end(); ++eit) {
> // ============= this result is CORRECT ==============
> int num = eit->curve().data();
> std::cout<<"Current curve number:"<<num<<std::endl;
> point_loc(&arr);
> return 0;
> // =================== CODE END =====================
> The data file test5.dat is in below
> =================== DATA BEGIN =====================
> 3
> 2 0 0 100 100
> 2 20 80 100 0
> 2 -10 14 120 40
> =================== DATA END ======================
> Could anybody help me to find out how to get the correct auxiliary data in
> the returning boundaries constructed by point location algorithm?
(Traits_org_2::X_monotone_curve_2,CurveNumber)
No information is stored to get back to Traits_2::Curve_2 used
to create the X monotone curve. However, the information hold by
the Curve_2 is always copied to the X_monotone_curve_2.
Thus replacingCurveNumber curve_num = curr_curve_num.data();by
CurveNumber curve_num = bound_circ->curve().data();
will do what you want.
At this line:Bezier_curve_num_2 curr_curve_num = bound_circ->curve().supporting_curve();the constructor of Bezier_curve_num_2 is implicitly called with no data
(we should probably had an explicit keyword to that constructor).
(looking at the doc here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_curve_data_traits_2.html#Cross_link_anchor_1223
you will see no constructor of X_monotone_curve_2 from Curve_2).The fix will be posted here.There indeed seems to have a bug here.
> Besides, it seems that Arr_Bezier_curves_traits_2 cannot handle some special
> case of curves like horizontal line segments. For example, using the code
> above and another data file below,
> 3
> 2 0 0 100 0
> 2 30 -20 30 80
> 2 100 -15 -20 75
> the program will terminate with assertion fails in line 770 of
> Bezier_curve_2.h when inserting bezier curves into arrangement. Is it a bug
> and how to fix it?
In the meantime, translating your data by 1 in the (0,1) direction
makes it work (the problem comes in the case the polynomial for y
coordinates is 0).
S.
> Does anyone know how to solve them? Thanks very much!
> Sincerely yours,
> Stzpz
--You are currently subscribed to cgal-discuss.
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3241657.htmlTo unsubscribe from About Bezier curves in Arrangement, click here.
View this message in context: Re: About Bezier curves in Arrangement
- [cgal-discuss] About Bezier curves in Arrangement, stzpz, 01/26/2011
- Re: [cgal-discuss] About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 01/27/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 01/28/2011
