cgal-discuss - [cgal-discuss] multi-domain mesh generation
  • To:
  • Subject: [cgal-discuss] multi-domain mesh generation
  • Date: Mon, 31 Jan 2011 09:21:41 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=CDQC5JJDh0LAEAI/5vtd2CoJWjdGr9jfGBN7hA5uSYIAYAXeN8j8tyZVJEUGpSZROS bkEj2jRU0fWb9lK45ETGhHGEieQNmZiU7wcmFEeXFU/WuPZtuQ8hFJBBswXVC1jmhrXM SZXX1hbwirb52Mj2SbsLnBEUGkxAwf+RSrr0M=
Hi all,
I have a biomedical application, in which I need to generate 3D mesh consisting four domains (A, B, C and D) representing regions with different properties.
In my FEM calculation, remesh is needed when the initial mesh becomes too distorted.  In this case, I need to generate a new set of mesh based upon the triangle boundary surfaces from all these regions.
The geometries are in 3D and the figure below is only for a 2D illustration.  A is inside B, but A shares a portion of its boundary surfaces with B.  C is completely inside B, and D is completely inside C.  I checked the past archive and it seems that using nef_polyhedron can solve the problem, but due to my limited experience with CGAL, it is not straightforward enough for me.  I wonder whether someone can post some portion of their program if they handled similar situation before.
Thank you all very much!
Yasheng
*      *  A  *                  *
*      *******     B           *
*      *   *     *   C     *         *
*      *   *  D  *         *         *
  • [cgal-discuss] multi-domain mesh generation, Yasheng Chen, 01/31/2011
