cgal-discuss - [cgal-discuss] Re: understanding edge_collapse
  • To:
  • Subject: [cgal-discuss] Re: understanding edge_collapse
  • Date: Tue, 1 Feb 2011 11:57:23 -0800 (PST)
i did many attempts (both on linux and windows) and my conclusion is: or cgal
mesh simplification is done really bad , or i am doing mistakes...
Please consider the following example. I want to do a surface simplification
with Edge_length_cost ( the cost is the squared distance from 2 points) and
Midpoint_placement ( the point is choosed half distance, in the exact middle
of the edge). I want to do my own stop predicate, that stops when the
collapsing cost is greater then a certain value.
so this is the code of my example (part of this is from the cgal examples):
#include <iostream>
#include <fstream>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
// Adaptor for Polyhedron_3
#include <CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h>
// Simplification function
#include <CGAL/Surface_mesh_simplification/edge_collapse.h>
// Extended polyhedron items which include an id() field
#include <CGAL/Polyhedron_items_with_id_3.h>
// Non-default cost and placement policies
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Midpoint_and_length.h>
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Edge_profile.h>
typedef CGAL::Simple_cartesian<double> Kernel;
typedef Kernel::Point_3 Point ;
// Setup an enriched polyhedron type which stores an id() field in the items
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3> Surface;
typedef Surface::Halfedge_handle Halfedge_handle ;
typedef Surface::Vertex_handle Vertex_handle ;
namespace SMS = CGAL::Surface_mesh_simplification ;
typedef SMS::Edge_profile<Surface> Profile ;
typedef boost::graph_traits<Surface>::edges_size_type size_type ;
typedef Kernel::FT FT;
typedef bool (*Max_cost_predicate)( Kernel::FT const& , Profile const& ,
size_type , size_type);
//Custom stop predicate, returning when the current cost is greater then
0.01
bool my_stop_predicate( FT const& aCurrentCost
, Profile const& //aEdgeProfile
, size_type //aInitialCount
, size_type //aCurrentCount
bool quitting= aCurrentCost>0.01;
if (quitting) std::cerr<<"Quitting, cause current cost
("<<aCurrentCost<<") is greater then target cost(0.01)"<<std::endl;
return quitting;
int main( int argc, char** argv )
Surface surface;
std::ifstream is(argv[1]) ; is >> surface ;
// The items in this polyhedron have an "id()" field
// which the default index maps used in the algorithm
// need to get the index of a vertex/edge.
// However, the Polyhedron_3 class doesn't assign any value to
// this id(), so we must do it here:
int index = 0 ;
for( Surface::Halfedge_iterator eb = surface.halfedges_begin()
, ee = surface.halfedges_end()
; eb != ee
; ++ eb
eb->id() = index++;
index = 0 ;
for( Surface::Vertex_iterator vb = surface.vertices_begin()
, ve = surface.vertices_end()
; vb != ve
; ++ vb
vb->id() = index++;
int r = SMS::edge_collapse<Surface,Max_cost_predicate>
(surface
,my_stop_predicate
,CGAL::get_cost (SMS::Edge_length_cost <Surface>())
.get_placement(SMS::Midpoint_placement<Surface>())
std::cout << "Finished...\n" << r << " edges removed.\n"
<< (surface.size_of_halfedges()/2) << " final edges.\n" ;
Surface::Halfedge_iterator itB= surface.halfedges_begin();
Surface::Halfedge_iterator itE= surface.halfedges_end();
int halfedges_with_a_greter_cost=0;
int halfedges_with_a_lower_cost=0;
for (;itB!=itE;itB++){
Surface::Halfedge_handle hhCurr= itB;
FT error=
CGAL::squared_distance(hhCurr->vertex()->point(),hhCurr->prev()->vertex()->point());
if (error>0.01) halfedges_with_a_greter_cost++;
else halfedges_with_a_lower_cost++;
std::cout<<"halfedges_with_a_greter_cost =
"<<halfedges_with_a_greter_cost<<std::endl;
std::cout<<"halfedges_with_a_lower_cost =
"<<halfedges_with_a_lower_cost<<std::endl;
std::ofstream os( argc > 2 ? argv[2] : "out.off" ) ; os << surface ;
return 0 ;
output is:
C:\Users\TroyMcLure\Desktop\cgalRel22\build\Debug>esempio zampa2.off
Quitting, cause current cost (0.0111412) is greater then target cost(0.01)
Finished...
28339 edges removed.
1000 final edges.
halfedges_with_a_greter_cost = 1688
halfedges_with_a_lower_cost = 312
// EOF //
so the output of the program tells this: the algorithm quits cause it
selects an edge with a greater cost (0.0111412) then the target cost (0.01).
But there are 312/2 edges with a cost lower then 0.01 in the final mesh!
all this 312/2 edges have no topologial issues ( i checked ). So what is it?
surface mesh simplification does not work, or i am doing mistakes? ... and
where?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/understanding-edge-collapse-tp3248855p3252842.html
