- To:
- Subject: Re: [cgal-discuss] gmp.h: No such file or directory
- Date: Fri, 4 Feb 2011 17:58:50 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=emRGR533V2PMh1ufRM/a5lwxkaiJP4CjLpwwNtYod0WswYOsY8xMUGhz3tpfnRM6bW 5qimXeymJHLnIRQqh6+YDIFcXaFe3o9R6v8NVKOKCgzhzQL4zeCI0cooNsYMhswxbxaC MF4nLIaxR4aZtuWVnQpAX3YEbPFiPCfAkzptk=
Yes, I downloaded version 3.7 from cgal.org and installed it manually.
That explains why I was missing the libgmp3-dev package eventually.
thanks,
Constantinos
On Fri, Feb 4, 2011 at 5:52 PM, Bruce Duncan <> wrote:
Costas,
Are you compiling CGAL yourself? I ask because ubuntu should really provide
the dependency on libgmp3-dev. If so, did you know that CGAL is in Ubuntu?
It's version 3.6, called libcgal5 and libcgal-dev. If you need it, 3.7 has
been packaged for debian and is in experimental. It's called libcgal6 and I'm
using it quite successfully.
Hope that helps,
Bruce
On Friday 04 Feb 2011 16:26:57 Costas Tsirogiannis wrote:
> ok, it worked. Thanks!
> On Fri, Feb 4, 2011 at 4:53 PM, Laurent Rineau (GeometryFactory) <
> > wrote:
> > Le vendredi 04 février 2011 16:46:13, Costas Tsirogiannis a écrit :
> > > Greetings,
> > > I've installed CGAL at my new pc (ubuntu 10.10, g++ 4:4.4.4-1) .
> > > I trythen to run some standard code that was compiling in my previous
> > > pc
> > > and I get the message:
> > > ../CGAL-3.7/include/CGAL/gmp.h:30: fatal error: gmp.h: No such file or
> > > directory
> > > g++ can't see the file so what do I do?
> > Install the Ubuntu package named libgmp3-dev. It is needed by CGAL (and
> > among
> > other things contains /usr/include/gmp.h).
> > Laurent Rineau, PhD
> > R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> > Release Manager of the CGAL Project http://www.cgal.org/
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
iEYEABECAAYFAk1MLssACgkQPTuzbr/QRF10/wCbBUZbnbvPIK49rHckJbhz564b
F8cAoLT8b6l1M3RCR2KHv+kyKU6sNEVr
=RqlK
-----END PGP SIGNATURE-----
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
- [cgal-discuss] gmp.h: No such file or directory, Costas Tsirogiannis, 02/04/2011
- Re: [cgal-discuss] gmp.h: No such file or directory, Laurent Rineau (GeometryFactory), 02/04/2011
- Re: [cgal-discuss] gmp.h: No such file or directory, Costas Tsirogiannis, 02/04/2011
- Re: [cgal-discuss] gmp.h: No such file or directory, Bruce Duncan, 02/04/2011
